Old 01-13-2013, 10:43 AM   #113
2forme
Was that SAE or STD corrected numbers?
Old 01-13-2013, 11:09 AM   #114
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
What are your other mods? Did you upgrade your exhaust?
Amadeus is offline   Reply With Quote
The Following User Says Thank You to Amadeus For This Useful Post:
Pete (01-13-2013)
Old 01-13-2013, 11:37 AM   #115
2forme
Actually, his results are in line with what Perrin got. 240whp on a DynaPack is around 215whp on a DynoJet. So it's well within the margin of error. I am waiting for a dyno graph.
The Following User Says Thank You to 2forme For This Useful Post:
Sportsguy83 (01-13-2013)
Old 01-13-2013, 11:39 AM   #116
Opposed
Drives: 2013 Asphalt FR-S
One thing to consider is that Perrin's stock baseline is on par with other Dynojet baselines...Im sure his DynoPack reads similar to a Dynojet. I have seen DynoPacks read all over the place. The only reason these numbers are a tad low is his high altitude location.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 01-13-2013, 11:41 AM   #117
2forme
Originally Posted by Opposed View Post
The only thing I question about Perrin's numbers is that his stock baseline is on par with other Dynojet baselines...
Yea, I've seen stock dynos ranging from 135-170. What was Perrin's baseline?
Old 01-13-2013, 11:54 AM   #118
Opposed
His baseline was 164 whp, 135 wtq.
Old 01-13-2013, 12:24 PM   #119
2forme
Maybe its a similar dyno to that of his "avo vs vortech"
Old 01-13-2013, 12:25 PM   #120
Pete
Pete's Avatar
Drives: 22 BRZ
I gotta say, this is a bit lower than I expected after correction. Not comforting to those of us waiting on delivery of the kit. There must be something else going on?
You have mentioned a few times that it feels a lot faster to you though. I wonder what your baseline would have been on that dyno.
Do you have an after market exhaust or other mods?
I'd like to see your graph when you can post it Skatery, thanks for continuing to update the thread!
Pete is offline   Reply With Quote
Old 01-13-2013, 12:36 PM   #121
Opposed
He is a mile high plus elevation in Colorado. Most likely the reason for the lower numbers.
Old 01-13-2013, 12:46 PM   #122
2forme
The numbers were corrected. I'm actually not surprised at the numbers considering the selling dynos were on dynapacks.
Old 01-13-2013, 01:13 PM   #123
skatery1989
Drives: BRZ Limited
I wish I would have done a baseline but didn't. On the 26th I am going back up for the E-85 tune. There is also going to be a stock BRZ going to ask him to baseline that one before he tunes it. I have Perrin cat-less front pipe over pipe and non-resonated cat back. also have their oil cooler. That is it as for as performance besides the supercharger. I am also running 245/40/18 in the rear and 225/40/18 in the front seen someone asked that earlier. The car is without a doubt faster. And you can feel the torque that it gains. There is a guy here that said his came in at 160 corrected. I think he said uncorrected he was at like 123. Different dyno tho. I was expecting to be somewhere around 220HP and 165TQ because of the altitude. I am happy with the results. I test about 8 different maps last night and you'll see there is change between each map this is also on 91 octane. Jeff has the timing turn down on these maps because it 91 octane. I am also looking to keep this as safe as possible and after looking through the logs everything look good.
Heres the dyno sheets.
This was the best pull with the highest numbers.
Heres most of the runs we did.
Heres boost and AFR.
Hope this helps you guys out I cant say anything but positive thing about this kit I am extremely happy with it, and the work both companies have put into it.
Heres the link to the video.
skatery1989 is offline   Reply With Quote
The Following 2 Users Say Thank You to skatery1989 For This Useful Post:
Pete (01-13-2013), Sportsguy83 (01-13-2013)
Old 01-13-2013, 01:22 PM   #124
Pete
Pete's Avatar
Drives: 22 BRZ
Looks like your whp levels off around 6200 rpm, I don't see that on Jeff's graphs. Maybe due to pulling timings for 91 octane + altitude?
Old 01-13-2013, 01:23 PM   #125
Opposed
Well now this makes sense. His dyno was done on a Dyno Dynamics, those read pretty low...
Old 01-13-2013, 01:25 PM   #126
skatery1989
Drives: BRZ Limited
Ya should have threw that in there.
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
Vortech Supercharger Kits @Pure Automotive Performance Pure Automotive Forced Induction 25 01-16-2013 12:48 AM
Circuit Motorsports - SEMA 2012 Interview - Vortech Supercharger! Circuit Motorsports Forced Induction 6 11-06-2012 02:30 PM
