#113 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
DoubleJ is favorite shop I've ever been to. I'm going to convince them to work on my BRZ if it ever needs anything since I like them so much.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#114 |
Ecutek is already working on the flex fuel to detect octane. Also the race Rom on the current tune includes the launch control. Can't wait for flex fuel!!
Sent from my flux capacitor using Taptalk |
#115 | |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Don't know why they can't do flex fuel on GT86 without adding ethanol fuel sensor. It got every thing it need from oem to make it flexfuel I mean wideband O2 ensor and knock sensor. just need to make it able to switch ignition advance map according to knock and widen fueling adaptation range. then learning will do it. Look like GT86 ECU is " retaded" compare to Bosch ME7 ECU from 2004 VWR32
#116 |
Have about 100 miles on the tune getting pretty bad idle dips with the air conditioning on.
Pretty sure no one else noticed since they probably are not running their AC. I thought it was going to stall a bunch of times last night. Sent from my flux capacitor using Taptalk |
#117 | |
Make love
Drives: H8R.. Not really
#118 | |
Pull my finger...
Drives: Silver Scion Slushbox
That wasn't my experience today. I disconnected the negative cable, cycled headlights, pressed the horn a couple times waited about 5 minutes and reconnected. All presets remained and my gas gauge returned to normal. I know that it will wipe the aforementioned settings out if you go longer than that, but not sure how much longer. I do know that when I replaced my intake tube and installed a strut bar, I lost everything, but that was at least one hour. So, if you reset the ECU this way, you should be able to accomplish the goal without losing your head unit's presets. I am inclined to start messing with the option to get the analog gauge pissed again to see if the same can be accomplished in a shorter time. I also think turning accessories on to hasten the discharge of any remaining power in components that retain a charge, hastens the process. |
#119 |
Drives: Whiteout FR-S
Might have to try that headlight & horn thing i left mine disconnected for about 6-7 minutes and it didn't do anything with the gauge.
#120 |
Got 12.2 mpg at autocross today
![]() Sent from my flux capacitor using Taptalk |
#121 |
My gas gauge goes completely to E then jumps back to half a tank so the first run is just the first half of the tank lol.
#122 |
Mine too. It will go from low fuel to 3/4.
Still having the idle dip very badly with the ac on. Had to not have it on thinking o was going to stall at red lights. Sent from my flux capacitor using Taptalk |
#123 | |
Pull my finger...
I've been filling up every weekend and I know I've been using about about 3/8 to 1/2 tank each weekend and it stay's close to full the entire time. When I did the reset today, it went from 7/8 to just under a 1/2 tank which is where I would expect it to be. I've been too chicken to run it down any further than that. So, if I understand this correctly, the reset didn't work, but you let it go down to E and then at some point it bounced up to 1/2 a tank? That sounds to me like the method for calculation is off by 25%? :scratcheshead: I dunno, maybe I have the dumb? |
#124 |
Yeah this is the second time it happened and I only had 140 miles since fill up so I knew it wasn't empty. Not that big of a deal but have some really cold weather comin so I'll go back to 93 on the next fill up.
#125 |
Grip>Slip
hmmmm... idea for a bandaid on the cold start issue, not sure how possible this would be or if it will even make sense, but maybe having the 4 switchable maps be identical, except vary the cold start paramaters on each map by +/-5-10% (or whatever interval makes the most sense).
i.e. (i have no clue what the correct terminology is here, so i'm making up my own.) - Map 1 - Baseline cold start tables Map 2 - Cold start fuel tables +5% fuel Map 3 - Cold start tables +10% fuel Map 4 - Cold start tables -5% fuel At least that way you've got a couple different options to get going give you a little peace of mind that you're not going to get stuck somewhere. |
#126 |
So with my idle dip issue when the ac is on, what do you guys think of reflashing the ecu then keeping the ac on dusting the first idle and first 50 miles. I'm thinking since I didn't have it on it may have calibrated without the additional load.
| APEX-i SMART Throttle Controller - preliminary test. | Moto-P | Engine, Exhaust, Transmission | 33 | 05-24-2015 07:01 PM |
| REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley | draggin_az | Engine, Exhaust, Transmission | 21 | 04-29-2013 04:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| FA20CLUB.com E85 Goodness | FA20Club.com | Engine, Exhaust, Transmission | 45 | 11-13-2012 01:05 PM |
| Tunehouse BRZ Tuning program preliminary details | Hachiroku | Engine, Exhaust, Transmission | 42 | 06-25-2012 07:40 PM |
