#113 |
Drives: Asphalt scion frs
So I got the exact same rims and tires ordered and everything is stock, but what about camber bolts? I'm new to aftermarket wheels
#114 | |
Drives: SOLD...
Camber bolts are only needed if you are lowering just to give you abit more adjustability to get camber back into spec.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
| The Following User Says Thank You to Skurj For This Useful Post: | Flako (03-27-2013) |
#115 |
Drives: TSX
#116 |
Drives: Scion FR-S Asphalt
Looks clean and tight!
#117 |
Drives: Scion FR-S
See below
#118 |
Drives: Scion FR-S
Miro 111 18x8.5/18x9.5
I had a lot of pics so I decided to make a thread to show fitment. They are pretty much flush all around and I am loving the ride and looks.
Wheels are Miro 111 Front: 18x8.5 +35 with 225/40 tires Rear: 18x9.5 +40 with 255/35 tires Suspension: Eibach Sportlines ![]() ![]() ![]() ![]()
| The Following User Says Thank You to phloozy For This Useful Post: | BabaYaga (03-16-2015) |
#120 |
Drives: 2013 FRS
i have eibach sport lines and want to go and pick up a set of moro type 111 18x8.5 +35 / 18x9.5 +40 with federal 225/40 all around. i think it should be good but what do you guys think?!?!?!?!
#121 |
Drives: Scion FR-S
So I'm buying these wheels do with 18x8.5 +35 and 18x9.5 +40 that will fit with stock suspension what size tires would i need to run these with no rubbing.
#122 |
Drives: Subaru BRZ Limited
Doesn't help that I'm looking for answers about this exact setup and the pictures don't load any more. (Referring to the first few posts).
Anyway, I purchased the Miro 111s (18x8.5 / 18x9.5) and new TPMS along with eibach pro-kit, my last step is tires. will 265 tires in the rear fit without rubbing issues? I'm really trying to avoid the stretched look as much as possible. I'm not sure if this thread is even alive anymore. Cheers! |
#123 |
Drives: 2015 Scion FR-S
Just curious why 18x9.5 in the backs? People are telling me not to run Staggered setup.. so I'm bit confused. I was thinking of running Fifteen52 Tarmacs 18x8.5+35 all around, on Stock suspension setup.
#124 | |
Country Boy 4 Life
Because: Looks like RACECAR. I DD staggered. It's ok, not ideal. I'm adding a 17" square setup to my collection soon. 18x8.5 +35 will look great on a stock suspension. I would get a set of camber bolts for the front; they will help keep the tire on the ground on corners and will also help with looks. I would suggest 225/40/18 tires.
I LIKE TIRES! |
| >>> Miro 111 18x8.5/18x9.5 staggered concave wheels - starting @ $1010.00 shipped | speed depot | Wheels and Tires | 37 | 12-05-2012 11:52 AM |
| Miro for Fido's Next Promo Dog! | WS12888 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 08-20-2012 12:27 AM |
