Old 09-10-2014, 08:22 AM   #113
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
Originally Posted by rocketbunny86 View Post
Picked up a TE37SL 18x9.5 +40....How do I fit these on stock suspension for now..I jacked up the car,test fitted the wheels in front ended up hitting the base of the struts...any input would be appreciated...recommended tire size...?? Thanks in advance....
You need different sized wheels (width and/or offset) or coilovers. Your wheels won't fit with the stock struts.
Cheeseballs is offline   Reply With Quote
Old 09-10-2014, 04:01 PM   #114
rocketbunny86
rocketbunny86's Avatar
Drives: gt86 and Supra Mkiv
Thanks for the input.... Will running 5mm spacer help for the time being till I get some coilover....
rocketbunny86 is offline   Reply With Quote
Old 09-10-2014, 04:21 PM   #115
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-10-2014, 05:04 PM   #116
rocketbunny86
Looks dope @Figo...I just picked up a TE37 SL in black....my stock struts are not helping...what tire size are you running...?
Old 09-11-2014, 08:51 AM   #117
Figo
Figo's Avatar
255/35R18
I run coilovers.
Old 09-12-2014, 09:26 AM   #118
rocketbunny86
Just put installed the wheels with stock suspension, running spacer up front...245/40/18 all round Dunlop Derizza..
Begging for coilover now....
Old 03-10-2015, 11:29 AM   #119
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Here's mine:
Sold them a while back to somebody in the East. I liked this look the best for my car.
TylerLieberman is offline   Reply With Quote
Old 03-10-2015, 12:09 PM   #120
scottxnizzle
scottxnizzle's Avatar
Drives: WRB BRZ
Hey guys!
I had a couple questions about this wheel set up since I just got these lol
im running 255/35/18, what air pressure are you guys running??
also, these wheels in the front stick out a lot in my opinion, how much camber are you guys running in the front?
Thanks!!
scottxnizzle is offline   Reply With Quote
Old 03-24-2015, 04:25 PM   #121
Figo
Figo's Avatar
265/35R18 MPSS on 18X9.5 +40
Old 03-26-2015, 05:06 PM   #122
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
hey guys
new to this whole fitment thing. I'm running stock struts with RCE yellows springs. I'm wondering if a square setup with 255/35/r18 would fit and clear without rubbing? if not would spacers be a good solution? or camber plates? or should I just go straight to coils
andrew5826 is offline   Reply With Quote
Old 04-30-2015, 02:24 PM   #123
CircaBRZ
CircaBRZ's Avatar
Drives: 2013 BR-Z Limited
Hey all! Does anyone have these in 18X9.0 +45 on 1" drop? Getting Fortune Auto 500 coils. Wondering if these will be ok? Any info helps! Thanks!
CircaBRZ is offline   Reply With Quote
Old 04-30-2015, 02:34 PM   #124
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Hopefully "OmegaKnight" doesnt mind I am using his picture as reference.
These are 18x9.0 +45 TE37SL with BC coilover. Not sure of the drop. But everything works just fine with this setup.
Kami Speed is offline   Reply With Quote
Old 04-30-2015, 03:01 PM   #125
CircaBRZ
CircaBRZ's Avatar
Awesome thanks Kami Speed
Old 05-13-2015, 11:36 PM   #126
Figo
Figo's Avatar
Instagram: FIGOISYOURDAD
Wheel Directory: Volk Racing TE37 18x9.0 +45 OmegaKnight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 06-24-2014 09:12 PM
Wheel Directory: Volk Racing TE37 18x8.5 +35 / 18x9.5 +45 misterknee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-03-2014 05:29 AM
Wheel Directory: Volk Racing TE37 18x8.5 +36 / 18x9.5 +40 nsx_guy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 10-17-2012 02:18 AM
Wheel Directory: Volk Racing TE37 18x9.0 +45 / 18x9.5 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-04-2012 12:25 PM
Wheel Directory: Volk Racing TE37 18x8.5 +45 / 18x9.5 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2012 05:50 PM
