Old 02-23-2017, 05:15 PM   #113
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Originally Posted by Freddy@PTUNING View Post
We have hit 207whp on pump gas. Don't know why it's so hard to believe 216whp on E85. Good header and good tune is key.
what does a stock frs/brz typically pull on this dyno? knowing that should clarify everything.
cyde01 is offline   Reply With Quote
Old 02-23-2017, 05:31 PM   #114
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
the main issue is cost and the fact the engine needs to be pulled to do any work on the heads
so you've got a big bill before you even start, compared to a FI install which is done over the weekend and gets you a 50-60% gain for starters
new cams and reworking the valvetrain to withstand 8500rpm and then doing something about the oil pump so its stops tailing off over 7000rpm ......
if you can stop the rocker / follower pins from walking out too that'd be helpful
this isn't a K20 and needs a lot of work and modification to get it to 9000rpm more than once
Matt@Cosworth is offline   Reply With Quote
Old 02-23-2017, 05:33 PM   #115
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
2013s put down around 160whp.
Freddy@PTUNING is offline   Reply With Quote
Old 02-24-2017, 12:59 AM   #116
Starkiller
Drives: 2013 Scion FR-S 10 series
What is odd to me is that the torque dip is still there. I always thought that a good header and tune got rid of that.
Starkiller is offline   Reply With Quote
Old 02-24-2017, 01:11 AM   #117
Stimmed
Stimmed's Avatar
Drives: Toyota 86
nima314: I was told in Melbourne by a respectable tuner that U.S. dynos are 15-20% more exaggerated than ours. He's been in the industry for two decades too.
Yup thats what we find as well in QLD. Dynos here read about 100rwkw for stock. 160 HP is 120kw so your looking at 15-20% for sure. But in the end power is only a number its about the curve etc and if you want to prove the power that much track/quarter mile times I guess!
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 02-24-2017, 02:08 AM   #118
steve99
Stock cars are so variable on dynos. Tune is to aggressive for a lot of countries fuels and they knock lots and ecu reduces IAM (ignition advance mutliplier) and power drops.
The stock ecu tune also resets the IAM to 0.7 every time you turn the car off. So you can make a stock car read low (im not saying people deliberately do this) by throwing it straight on dyno and doing pulls, unless you have altered the tune to make IAM initial=1 not 0.7
If you drive it round the block a few times the iam will get to 1 if fuel is good and you get the full power. Then put it on dyno without turning ignition off. If the fuel is crap like in australia/south africa the iam will actually go down to 0.3-0.5 and the power will be even less.
IAM less than 1 causes timing reduction and fueling to be richened up in stock tunes
almost every tuner will set the IAM initial to be 1 in their tuned roms, unlike the stock tune
There is so many setup parameters on dynos you get big variations dyno to dyno see chart below stock car.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
JDM4E (02-25-2017), nikitopo (03-19-2017), Reamer (02-24-2017)
Old 02-24-2017, 08:24 AM   #119
Reamer
Drives: 2015 FRS
Just want to point out this dyno sheet is also in Dyno Dynamics' "shootout mode" where it artificially calculates like a Dynojet (typically reads 12-15% higher than dyno dynamics).
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
The Following 4 Users Say Thank You to Reamer For This Useful Post:
JDM4E (02-25-2017), nikitopo (03-19-2017), SpectreRT (02-24-2017), steve99 (02-25-2017)
Old 02-27-2017, 11:52 PM   #120
Starkiller
There are even some dynojet dynos that read really low because of heavier 5,000lbs rollers. It is best to look at the percentage of increase instead of overall numbers. Just my thoughts.
Old 03-09-2017, 09:25 AM   #121
celek
Resident Gear Head
celek's Avatar
If only someone would come up with an oiling solution... hint hint
celek is offline   Reply With Quote
The Following 2 Users Say Thank You to celek For This Useful Post:
BatStig (03-09-2017), Reamer (03-09-2017)
Old 03-09-2017, 05:32 PM   #122
-Willis-86touge
Drives: Stock
Question? Isn't the oiling good til about 8100 Rpms? If not what is the safe limit?
-Willis-86touge is offline   Reply With Quote
Old 03-09-2017, 05:36 PM   #123
Reamer
Drives: 2015 FRS
I thought the stock oiling wasn't sufficient in sustained high-g turns at stock redline?
Old 03-09-2017, 06:57 PM   #124
Lantana frs
Drives: 13 frs red
9000 rpm would mean a piston speed of 5078 fpm. Isnt that a little high?
Lantana frs is offline   Reply With Quote
Old 03-09-2017, 07:43 PM   #125
sw20kosh
Drives: 2013 Black FR-S
Yes. Most of the tuning shops with built motors in japan are capping at 8200 or so from what I hear.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
-Willis-86touge (03-09-2017), Lantana frs (03-09-2017)
Old 03-09-2017, 07:44 PM   #126
sw20kosh
Testing at ACS (has a nascar oval section integrated into the track) has show no oil starvation issues at 7450 rpm redline.
The Following User Says Thank You to sw20kosh For This Useful Post:
Reamer (03-09-2017)
9000rpm, aspirated, high, naturally, revv
Let's see your computer setup! Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 81 11-06-2022 12:43 PM
AutoX Parts Setup NYC BRZ Tracking / Autocross / HPDE / Drifting 38 08-17-2012 06:42 PM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 07:23 PM
2 car setup...feasible? mankarn86 CANADA 3 03-30-2012 03:00 AM
