Old 12-12-2021, 07:56 PM   #113
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by Tatsu333 View Post
Any chance you guys can test-fit whether a 1st gen intake manifold can physically bolt to the 2nd gen FA24D motor? I'm sure Harrop and Edelbrock know already but they're not sharing at the moment...
Feels as if some crypto tips are in order for such a request. IM fittings are not a 5 min affair on an in warranty vehicle.
PulsarBeeerz is offline   Reply With Quote
Old 12-13-2021, 06:52 PM   #114
CSG CP pads with about 7 hours of track use.
~0.75 hours at Streets of Willow Springs
~2 hours at Speed Vegas
~1.25 hours at Auto Club Speedway (heavy brakes, full sessions)
~4 hours at Buttonwillow (full sessions)
Mixed drivers at all venues.
- No radial taper on the inboard pad.
- Outboard pad had a small radial taper. Suspected cause to be the caliper bracket tacoing when hot under heavier load. Inboard pad/caliper is secured onto the knuckle, but the outboard pad has no mounting at the center. Par for the crouse on stock calipers while running long sessions.
gcmak (12-13-2021)
Old 12-13-2021, 06:54 PM   #115
Originally Posted by dragoontwo View Post
Mike, what do you think about the traction control modes on the new car?
On the street, I've had zero issues with them intervening.
I haven't tried them on track, and don't really plan on it unless someone is willing to provide me with a vehicle to do so with, as TCS/VSC is inherently abusive to the vehicle if it's intervening a lot. I suspect I can do 95% driving with zero intervention, but 100% driving will be impossible.
dragoontwo (12-13-2021)
Old 12-13-2021, 06:55 PM   #116
Also falls into the category of "I just don't have time" and at the moment, plan on keeping the powertrain completely stock.
Remember, I'm doing all this on the side in my spare time. I do also have a day job.
Old 12-13-2021, 07:50 PM   #117
Tatsu333
Drives: 2020 BRZ Sport Tech RS
No worries - just thought I'd throw the idea out there.
Tatsu333 is offline   Reply With Quote
Old 12-14-2021, 09:42 AM   #118
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Its hard to sell something to people that don't need it.
Imagine if it fits basically most manifolds...
Blighty is offline   Reply With Quote
Old 01-05-2022, 11:02 AM   #119
Ed.bbfec86
Ed.bbfec86's Avatar
Drives: 2014 FRS
Hi Mike, Im curious what you think of the electronic driver aids in the new BRZ. Do you think any of the standard traction control modes are actually good for track driving?
Ed.bbfec86 is offline   Reply With Quote
Old 01-05-2022, 06:50 PM   #120
jflogerzi
jflogerzi's Avatar
Long press aka press and hold is just about equal to Pedal Dance on gen 1
2013 Series 10 FRS #553
Old 01-06-2022, 10:06 AM   #121
Ed.bbfec86
Ed.bbfec86's Avatar
Drives: 2014 FRS
I hope so. It seems like marketing wise they are embracing the motorsport side of things but well see if that transfers over to the car. They should recognize how many people have been pedal dancing and incorporate those features into a standard mode.
Old 01-06-2022, 10:16 AM   #122
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Long press TCS or long press track mode?
Old 01-06-2022, 11:09 AM   #123
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Should be TCS. I believe the track button only has one setting.
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
Yoshoobaroo (01-06-2022)
Old 01-20-2022, 08:39 PM   #124
Well.... car is at APR. Lets see what happens.
Old 01-20-2022, 10:31 PM   #125
Lantanafrs2
Drives: 2013 frs red
Tuning?
Old 01-21-2022, 03:31 AM   #126
BRZpat
Drives: BRZ Limited, V10+ R8, Macan S
Let a new journey begin.
I have no idea what direction I'll eventually take this car, but I'm certain it'll involve some sort of performance driving! Y'all need to crack the whip and regularly tag me here, so I keep the post updated.
???? - Call Irvine Subaru and request that they order me a new BRZ the moment it is available, and leave a standing deposit. I've already purchased many cars from them, and they know I'm committed.
28 Oct, 2021 - Get a message from Irvine Subaru that my BRZ has arrived and is ready for pickup. Unfortunately have to work and won't make it.
29 Oct, 2021, 9PM - Took delivery after hours, courtesy of Asher who stayed late so I could sign for the car. I attempt to connect Ecutek and an AIM Solo DL when I get home to see what data I can get. Neither are able to at this time. 6 miles on the ODO at this time.
30 Oct, 2021, 4AM - Show up at CSG to swap in CP brake pads, Endless brake fluid, and swap the terrible factory lug nuts for some RAYS Lug Nuts. CSG lug nuts have been backordered for a while, so I opted for the next best thing.
30 Oct, 2021, 6AM - hit ACH (Angeles Crest Highway) on the way up to Streets of Willow for 86CUP, to feel the car out.. Car is slightly understeery as expected. I get worried that I'm perhaps cycling the tires a bit much. I also spend some time bedding the brakes, and progressively increase engine load and RPM, to do simulated dyno break-in.
30 Oct, 2022, 8AM - I get to SoWS, dump everything out of the car in a rush, and head on track. The car definitely feels softer than before. It's easily a superior everyday driver compared to the 1st gen car.
2 Nov, 2022 - CSG FLA V2 Prototypes installed, corner balanced, and aligned.
4 Nov, 2022 - Car is being flogged at SpeedVegas, not by me. Brakes validated. Coilover may get another revision.
6 Nov, 2022 - Auto Club Speedway with 86CUP. Easily hit 6th gear, even with a passenger. Very used stock tires able to stay flat in oval without issue.
8 Nov, 2022 - Dropped car off at OEM Audio+
27 Nov, 2022 - STR38 private track day at Buttonwillow. Suspension testing with very, very dead tires.
12 Dec, 2022 - 86CUP Round 12. Mixed drivers. CP pads showing about 4.5mm of wear after ~7 hours (rounded down) of track use.
Are you living in the future? Gimmie some lotto numbers brotha!
BRZpat is offline   Reply With Quote
The Following User Says Thank You to BRZpat For This Useful Post:
timurrrr (01-21-2022)
nowforitbs
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike BRZ Second-Gen (2022+) — General Topics 25 11-05-2021 12:22 AM
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike Tracking / Autocross / HPDE / Drifting 5 11-02-2021 06:57 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 10:11 AM
Mike @ LSD Motorsports JDMenrique User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-06-2013 08:13 PM
Mike at Czp _F-R-S_ User/Vendor/Sponsor Reviews, Feedback, Comments 0 12-01-2012 10:01 PM
