#113 | |
Drives: '22 BRZ
Nah, an oversized Stoptech kit
#114 | |
Drives: Crapcan
355 I am assuming then? The 328/ST40 kit is within +/-1% of stock depending on what bias calculator or source you use.
#115 | |
Drives: 2015 FR-S
#116 | |
Drives: Crapcan
Yes, the sprint kit is close to stock. It actually has a slight rearward bias from the stock numbers.
#117 |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Flat spots in my tires.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#118 |
Drives: Nevermorange FRS
THIS.
I raced a non-ABS car for 15 years before the FRS. When your tires are $350+ each, getting a braking moment wrong and writing off $700+ worth of rubber sucks. Generally if you're leaning on your ABS, you're not fast anyway. ABS is great for extending my tire budget when I do get it wrong, it also means that upon getting it wrong with someone right in front of me, I don't hit them as hard. Big fan of ABS in club racing. Doesn't negatively impact the experience and reduces cost on metal and tire replacement.
PRO86 | WTCC | STL
#119 | |
Addressing the PD Humans have the propensity to make things bigger than they are, then divide into camps or tribes and then create a dogma around these ideologies that reinforce their thinking or previously invested mental energy... Let's not do this with Pedal Dance. I think my tire choice and the racing I do predominately affects my experience with PD. If you're on Street Tires doing autox (or something just different than me) and running with Long Press yields the better results - DO THAT. But don't stop looking at data, don't stop challenging beliefs in an effort to go faster. In fact, I would recommend not having "beliefs" to start with. Measure, test, measure, test...
PRO86 | WTCC | STL
#120 |
not playing cards
Of course. My point was in OP's context. Still nothing to fear. Also, PD does not disable ABS.
#121 | |
Drives: Crapcan
It's been a good discussion so far.
#122 | |
Drives: '13 BRZ Limited
What do you log in AIM to see individual wheel brake pressures and evaluate if the ABS is single or multi-channel?
#123 |
I don’t believe you can get individual brake pressure on this car without creating a new sensor system. What you want to log is individual wheel speed and compare the 4 to see if a wheel, or multiple wheels are locking which you’d see as them slowing down significantly.
#124 |
Custom Switch Panels!
Drives: 2015 Subaru BRZ Series.Blue
Just jumping into the fray to make two points about pedal dance (and my experience in my 2015 BRZ):
1. While I haven't won at SOLO Nationals (which I blame partially on the fact that my car is not in any way set up to be properly competitive in STX), I do have several season jackets with Chicago Region, so I'm not a complete idiot behind the wheel. I've found absolutely no need to use the Pedal Dance at autocross. 2. My personal theory as to why so many people swear by the Pedal Dance (including a lot of people in the Toyobaru Facebook groups) is that - from what I've gathered over many years driving the car - if the E-DIFF engages, that flashes the stability light on the cluster. And while the E-DIFF is merely attempting to ensure your Torsen diff can do its job properly, and therefore is - if anything - HELPING you do your shenanigans, I think a LOT of people see that blinking light on the dash and get all pissed off thinking the car is stepping in and ruining their day. That's my theory based mainly on the fact that when I'm ice racing, that light will be endlessly flashing despite the fact that the car isn't cutting power, or trying to reel me in. I'll be properly sideways at 50 MPH on a frozen lake, and the light is just blinking away, and the only logical explanation I have is that given the low traction surface, the Torsen isn't able to do LSD things, and so that blinking light is just the car saying, "Hey, I'm adding a little bit of resistance to the rear end so your diff stays locked up." And, like, I'm the guy who sells the switch panels that people most-often use in conjunction with the TracBox to easily enable the Pedal Dance, so it's not like it isn't in my best interest to go around shouting "YOU NEED PEDAL DANCE" to everyone... but I've spent SO much time defending the "3-second-hold" TCS OFF mode that the car came with from the factory it's ridiculous. That mode was fine when the car first came out, and everyone applauded how easy they had made it to "fully defeat" the driver aids. Then one day someone discovered the Pedal Dance and suddenly the other mode was "trash" and "useless" and "doesn't let you do anything." I realize there are some specific instances on track where apparently Pedal Dance does have benefits, but I'm tired of every person just trying to do some donuts in a parking lot, or trying to get the ass a bit loose on a back road, insisting that the Pedal Dance is the "ONLY WAY" to prevent the car from intervening. That's completely untrue for the vast majority of folks.
#125 |
Drives: '23 BRZ
Worth noting that for '17+ there is no E-diff with the long-hold on the TCS-Off button...
FWIW I only tried pedal dance a few times on my '17 PP, and back-to-back vs. "long-hold" at the track (no autoX) I really couldn't tell much if any difference, and for sure my lap times were not impacted either way. So I just stuck with "long-hold" as it's a whole lot easier and can be done on track during lapping if you forget before going out... |
#126 |
Drives: Crapcan
I didn't know it did that, but I haven't been able to see my trac/stability light behind my gauge pod I run on my dash.
| WTB: pedal dance box | captain awesome | Want-To-Buy Requests | 6 | 08-19-2019 12:37 AM |
| Pedal dance problem | Sapphireho | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 07-31-2017 09:25 PM |
| Pedal dance | Simqc | Issues | Warranty | Recalls / TSB | 6 | 05-22-2016 09:56 PM |
| OFT - Pedal Dance Mode. | RustySocket | Software Tuning | 2 | 08-24-2015 06:55 PM |
| Pedal Dance Device | robot | Tracking / Autocross / HPDE / Drifting | 3 | 01-10-2014 09:26 AM |
