#113 |
Drives: 2003 Corvette Z06, ECS Dry Sump 427
Here are some pics of my BRZ spec springs installed. Very impressed with these, car dropped 1", looks great. Had the car aligned and the handling feels great, although that is probably due mostly to the lower COG and better alignment. I also just switched to summer tires (Pilot SuperSports) so those made a huge handling improvement as well. I notice absolutely no decrease in ride quality, just as a previous poster mentioned. Even over some really bad roads the car feels just as compliant and stable as it did before.
Highly recommend these springs and Evasive Motorsports. ![]() ![]()
2003 Corvette Z06 - Dry Sump LS7 built by East Coast Supercharging
![]() 560rwhp & 549rwtq 10.8@134 2013 Subaru BRZ Limited - WRB, 6MT, PTuning Header, Motriv OP & FP, Perrin Res. Catback, Toms Tail Lights, Sprint Springs, Rays 57DR Wheels, 186rwhp |
#114 |
Drives: Low and slow
billy2kfrc pmed ya about your alignment on the vehicle. Curious to know what the camber and toe set at. Thanks
#115 |
Drives: 6MT
also interested in alignment, more specifically what parts, if any are needed to assist in alignment after these springs are installed
#116 |
Drives: WRB LMTD '13
will these springs pair well with Koni yellows? I will replace my stock struts once they blow up.
#117 |
is better than you
Drives: 2013 raven FRS
i have always been a swift fan, how do these compare to the other lowering springs? I mainly care about handling and at least an inch drop so the ride harshness isn't a factor.
#118 |
Drives: 2013 Scion FR-S Raven
How much should I cut the bump stops for the Swift Springs?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#119 |
#120 |
Drives: Raven Fr-S
Anybody have any numbers on weights of Swift springs vs stock?
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#121 |
Drives: DGM BRZ Limited 6MT
Other manufacturers include shorter bump stops with their springs. When you lower your car, your decreasing the travel along the shock, so I don't know why you wouldn't want to reduce the height of the bump stops. Otherwise, you're increasing the likelihood of hitting the stops during aggressive cornering, which would result in less control. Now, if your car is mostly a dd and it will never see a track, I suppose you can leave the bump stops alone but you're not hurting anything by shaving them down by 1/3rd
#122 |
I'll weigh them when I replace them
#123 |
Drives: black frs
^^ I'm waiting on this also
#124 |
Drives: black frs
Found this, shows the weight of the spring for the brz. Now how much do the swift spring weigh? 2.98Lbs front and 2.5Lbs rear.
#125 |
Drives: They have four wheels
#126 |
| Swift Springs Fitting - SoCal Only | schtebie | Southern California | 16 | 11-29-2012 03:29 PM |
| WGP Looking for a BRZ For LS Swap Prototype | Doug@WGP | Announcements, Contests, Giveaways | 25 | 10-10-2012 05:20 PM |
| FS: Swift Motorsports Motorized Plate Holder | kanundrum | Exterior Parts (Aero, Lighting, Etc.) | 4 | 06-12-2012 01:12 AM |
| Different wheels on the prototype | ft86cbx | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 06-20-2011 05:00 PM |
| Wheels on the Prototype | joshuo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 11-03-2009 07:37 PM |
