Old 04-05-2013, 09:21 AM   #113
BillY2KFRC
Drives: 2003 Corvette Z06, ECS Dry Sump 427
Here are some pics of my BRZ spec springs installed. Very impressed with these, car dropped 1", looks great. Had the car aligned and the handling feels great, although that is probably due mostly to the lower COG and better alignment. I also just switched to summer tires (Pilot SuperSports) so those made a huge handling improvement as well. I notice absolutely no decrease in ride quality, just as a previous poster mentioned. Even over some really bad roads the car feels just as compliant and stable as it did before.
Highly recommend these springs and Evasive Motorsports.
2003 Corvette Z06 - Dry Sump LS7 built by East Coast Supercharging
560rwhp & 549rwtq 10.8@134
2013 Subaru BRZ Limited - WRB, 6MT, PTuning Header, Motriv OP & FP, Perrin Res. Catback, Toms Tail Lights, Sprint Springs, Rays 57DR Wheels, 186rwhp
BillY2KFRC is offline   Reply With Quote
The Following 4 Users Say Thank You to BillY2KFRC For This Useful Post:
*KID* (04-05-2013), diirk (05-30-2013), microbionic (04-05-2013), tinger00 (05-09-2013)
Old 06-14-2013, 07:41 PM   #114
86black
Drives: Low and slow
billy2kfrc pmed ya about your alignment on the vehicle. Curious to know what the camber and toe set at. Thanks
86black is offline   Reply With Quote
Old 06-14-2013, 07:49 PM   #115
Steve
Steve's Avatar
Drives: 6MT
also interested in alignment, more specifically what parts, if any are needed to assist in alignment after these springs are installed
Steve is offline   Reply With Quote
Old 06-15-2013, 12:24 PM   #116
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
will these springs pair well with Koni yellows? I will replace my stock struts once they blow up.
hanabie is offline   Reply With Quote
Old 06-15-2013, 12:48 PM   #117
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
i have always been a swift fan, how do these compare to the other lowering springs? I mainly care about handling and at least an inch drop so the ride harshness isn't a factor.
bkblitzed is offline   Reply With Quote
Old 06-15-2013, 02:43 PM   #118
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
How much should I cut the bump stops for the Swift Springs?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 06-15-2013, 03:10 PM   #119
hanabie
hanabie's Avatar
none. keep it stock.
Old 06-16-2013, 12:21 PM   #120
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Anybody have any numbers on weights of Swift springs vs stock?
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 06-16-2013, 01:36 PM   #121
toyoman
Drives: DGM BRZ Limited 6MT
Other manufacturers include shorter bump stops with their springs. When you lower your car, your decreasing the travel along the shock, so I don't know why you wouldn't want to reduce the height of the bump stops. Otherwise, you're increasing the likelihood of hitting the stops during aggressive cornering, which would result in less control. Now, if your car is mostly a dd and it will never see a track, I suppose you can leave the bump stops alone but you're not hurting anything by shaving them down by 1/3rd
toyoman is offline   Reply With Quote
Old 06-16-2013, 05:37 PM   #122
tonystewart
I'll weigh them when I replace them
Old 06-16-2013, 11:12 PM   #123
normanb21
Drives: black frs
^^ I'm waiting on this also
normanb21 is offline   Reply With Quote
Old 06-17-2013, 09:37 AM   #124
normanb21
Drives: black frs
Found this, shows the weight of the spring for the brz. Now how much do the swift spring weigh? 2.98Lbs front and 2.5Lbs rear. Name:  ImageUploadedByTapatalk1371476274.986909.jpg
Old 06-22-2013, 11:30 PM   #125
Anaxilus
Drives: They have four wheels
How much do the stock springs weigh? Thx.
Anaxilus is offline   Reply With Quote
Old 07-26-2013, 07:18 PM   #126
Anaxilus
Did this ever happen?
Swift Springs Fitting - SoCal Only schtebie Southern California 16 11-29-2012 03:29 PM
WGP Looking for a BRZ For LS Swap Prototype Doug@WGP Announcements, Contests, Giveaways 25 10-10-2012 05:20 PM
FS: Swift Motorsports Motorized Plate Holder kanundrum Exterior Parts (Aero, Lighting, Etc.) 4 06-12-2012 01:12 AM
Different wheels on the prototype ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-20-2011 05:00 PM
Wheels on the Prototype joshuo Scion FR-S / Toyota 86 GT86 General Forum 13 11-03-2009 07:37 PM
