Old 11-29-2018, 08:29 PM   #113
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '24 CX-50 Meridian
Originally Posted by Roadcone View Post
I have no idea. I got it on eBay earlier this year for an insane deal. That's the only reason I'm running it. Overpipe has nearly zero to do with sound tho
Sent from my Pixel 2 XL using Tapatalk
I've just purchased the header so far; would it be beneficial to pick up an overpipe as well to replace the stock one? I'm going to keep the stock front pipe due to volume concerns. I like the volume level that my car is at currently with the Invidia R400 catback alone and don't want to go too crazy.
JBezugs is offline   Reply With Quote
Old 11-29-2018, 08:31 PM   #114
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Do a 2.5" overpipe and talk to jdl about getting a quiet front pipe. I noticed a change in mid-range power with stock header and stock overpipe with just a switch to a noncatted front pipe.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 11-29-2018, 08:31 PM   #115
Roadcone
StreetKart
Originally Posted by Chuckls View Post
I just want to remove any restrictions and get a full 2.5 full through exhaust.
Pick your favorite brand. 2.5" is 2.5"... Just make sure it's actually 2.5" lol
Old 11-29-2018, 08:43 PM   #116
TMF
TMF's Avatar
Drives: '14 FRS TT5
^this. Jesse had some great info. He said in regards to the overpipe: "Definite gains with a header, especially ones where the merge collector is located near the overpipe connection. The overpipe essentially becomes an extension of the merge collector at that point so making sure the diameters are match and flow is smooth is important ."
He also said that removing the cat in the front pipe is worth about 3-4hp.
I was originally going to do the header, but I figured I might as well do the whole shebang. I'm also trying for max gains for my class in NASA TT. If your budget doesn't allow for everything though, the header obviously provides the most gains.
TMF is offline   Reply With Quote
Old 11-29-2018, 08:47 PM   #117
Chuckls
Moutain Runner
Need to keep a cat conv. for STX autocross class :/
Maybe I can get away with it.
Chuckls is offline   Reply With Quote
Old 11-29-2018, 08:49 PM   #118
Roadcone
StreetKart
If you aren't running at a national level nobody cares about that crap.
Old 11-30-2018, 11:07 PM   #119
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I went with Hooker Headers catted FP with Helmholtz resonator. all the American brand exhausts should be 2.5", Japanese exhaust are 60mm = 2.36" or 70mm
SuperTom is offline   Reply With Quote
Old 11-30-2018, 11:40 PM   #120
jflogerzi
jflogerzi's Avatar
Please post your guys opinions who have it. I am thinking of upgrading to this for a bit better power band and smoother sound vs my Tomei UEL Header.
2013 Series 10 FRS #553
Old 12-01-2018, 02:33 AM   #121
jflogerzi
jflogerzi's Avatar
Well tonight was an expensive night
Parts ordered so far:
SPC LCA and front camber bolts
RCE Yellow Springs
and... JDL 4-2-1 with ceramic coating
Also eyeing a used MXP SP CB exhaust to replace my nameless axleback. I think the new combo of the JDL+MXP should give me the right sound noise I want with stock FP.
Old 12-01-2018, 06:16 AM   #122
gpvecchi
gpvecchi's Avatar
ACE header needs modding the skid plate, what about JDL?
gpvecchi is offline   Reply With Quote
Old 12-01-2018, 09:46 AM   #123
SuperTom
SuperTom's Avatar
Not hard to do. You are just hammering down 2 of the high spots on the skid plate with ACE. Takes 2 min
Nice that there is another quality EL header option
Old 12-01-2018, 11:14 PM   #124
jflogerzi
jflogerzi's Avatar
That's a good question. Does the JDL require the same modification to be installed?
Old 12-01-2018, 11:30 PM   #125
Roadcone
StreetKart
Mine touched at one of the primaries. Not a massive amount but then again I had the first one out in the wild. I told Jesse about it and I believe he has adjusted the new ones to have less of a chance of hitting.
The Following 6 Users Say Thank You to Roadcone For This Useful Post:
ATL BRZ (12-19-2018), gpvecchi (12-02-2018), jflogerzi (12-01-2018), Jyn (03-19-2019), R_E_L (12-03-2018), TMF (12-05-2018)
Old 12-24-2018, 05:09 PM   #126
R_E_L
He's got this.
R_E_L's Avatar
Drives: 50th Anni BRZ
Well, Christmas came a day early for me
It was pretty well wrapped but at some point the flange must have taken a smack. It shouldn't really be an issue though right?
Oh and my dumb butt managed to squash the merge collector gasket while trying to put everything away again.
Now I will tuck it away somewhere until tax season lol. I'm not picking up the flex kit or EcuTek stuff til then. For the others who picked one up, have you guys installed yet?
Don't worry, I'm certified... promise.
R_E_L is offline   Reply With Quote
The Following User Says Thank You to R_E_L For This Useful Post:
weederr33 (12-24-2018)
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 03:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
