Old 08-03-2018, 05:46 PM   #113
motomaster132003
Drives: Toyota 86
Originally Posted by NARFALICIOUS View Post
What specs does that region have that the U.S. TRD SE doesn't?
Mainly just more color options. I like how with the BRZ you can add the performance pack to any color. The 2019 TRD is still tempting though since I am a Toyota fan.
motomaster132003 is offline   Reply With Quote
Old 08-03-2018, 07:59 PM   #114
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
2019 Toyota 86 TRD Edition
Originally Posted by Atmo View Post
According to data on tirerack.com, it's ¾" higher than Base/GT's but no idea if TRD lowering springs are compatible with the TRD Sachs dampers.
The tire is 3/4" taller. That means that the vehicle itself rides 3/8" higher (the upper half of the tire doesn't add to the ride height).
Quentin is offline   Reply With Quote
The Following User Says Thank You to Quentin For This Useful Post:
BellaItalia (08-05-2018)
Old 08-04-2018, 12:14 AM   #115
Atmo
Drives: TBA
You sure about that? Wheels affect ride height, too.
Note that my ¾" taller estimate includes half the 18" wheel diameter plus half the tire diameter compared to stock 17".
Atmo is offline   Reply With Quote
Old 08-04-2018, 06:44 AM   #116
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
if true would make the car feel slower with worse gearing
SuperTom is offline   Reply With Quote
Old 08-04-2018, 06:57 AM   #117
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A 3/4" difference is too much. Tire size calculator gives a 1/2" diameter difference:
https://tiresize.com/calculator/
New cars have a 4.3 fd, so a bit longer gearing cause of the bigger wheel should not be an issue. In fact, what you lose in acceleration per gear you gain in top speed per gear. You lose something and you gain something else.
Old 08-04-2018, 07:18 AM   #118
Quentin
I think I was using 225/40-18 for my calcs last night. Looks like the overall diameter of the tire is only 5mm bigger which is 2.5mm ride height difference.
The Following 2 Users Say Thank You to Quentin For This Useful Post:
nikitopo (08-04-2018), SuperTom (08-04-2018)
Old 08-04-2018, 08:03 AM   #119
ermax
ermax's Avatar
Putting a wheel inside a tire doesn’t change the tire’s diameter. You only need to look at the outer diameter which is the tire. It’s not entirely accurate to go off the tire diameter though because the diameter is measured in an unloaded state. You would really have to measure the actual car to get an accurate number.
Old 08-04-2018, 09:16 AM   #120
SuperTom
SuperTom's Avatar
I just checked that too not sure where ATMO is getting his #'s its only .2" difference. Effectively only changes the Current 4.3 gear ratio to act like a 4.27 not a huge difference. The weight of the setup could be a difference but we need #'s first to determine how much.
Old 08-04-2018, 11:41 AM   #121
fireyredmystic
Drives: 2018 Subaru WRX
Can anyone who has Raven/Crystal Black confirm if their paint is metallic? I'm looking at picturesfrom the recent first driven reviews and the paint seems to have that metallic sheen.
Thanks!
fireyredmystic is offline   Reply With Quote
Old 08-04-2018, 01:12 PM   #122
Aipex8
Drives: 2017 Toyota 86 860 Special Edition
Thanks!
I have a 860SE, so my wing tips and mirrors are Raven and yes, they have metal flake.
Aipex8 is offline   Reply With Quote
Old 08-04-2018, 03:25 PM   #123
fireyredmystic
Appreciate the help! I prefer the BRZ tS interior but the TRD exhaust would be nice to hear.
Old 08-04-2018, 04:21 PM   #124
mrg666
pessimistic skeptic
mrg666's Avatar
Ugliest body kit I have ever seen on a twin, especially the rear bumper.
The Following User Says Thank You to mrg666 For This Useful Post:
TachyonBomb (08-05-2018)
Old 08-04-2018, 05:27 PM   #125
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Dang, so Thunder was only available for a year? That's probably my favorite color throughout the entire production run of 86s. If I was in the market that's probably what I would snatch up.
After hearing this sad news i did a quick search and could not find any in manual and gt trim. Only a few automatic gt blacks left. Only manual i found was the base model.
cyde01 is offline   Reply With Quote
Old 08-05-2018, 10:23 PM   #126
Atmo
Drives: TBA
I could be overthinking it, but it seems like the tire diameter is one thing, wheel diameter another. They're additive, right? So if an 18" wheel raises ride height 1/2" above a 17" wheel, and the TRD tire adds another 1/4", it's a 3/4" total ride height increase over stock since you can't mount an 18" tire to a 17" wheel.
https://www.tirerack.com/tires/tires...omCompare1=yes
Johl's Toyota 86 Blackline Edition johl Member's Car Journals 88 07-09-2019 01:07 PM
2019 Toyota 86 TRD Edition interna CANADA 8 07-08-2018 09:02 PM
2017 Toyota 86, 860 Edition Under 1K miles thatweirddude25 Cars for Sale/Trade 0 05-08-2018 02:43 PM
Toyota 86 GTS MY15 Edition M4V3R1CK Scion FR-S / Toyota 86 GT86 General Forum 2 07-15-2014 10:39 PM
