Old 04-13-2018, 12:52 PM   #113
Originally Posted by Jordanwolf View Post
Idunno if we are thinking about the same car.
Yep. A Sunfire with a body kit. I just never could get over the front end on the 04 to 08 Lancers.
why? (04-14-2018)
Old 04-13-2018, 02:53 PM   #114
Jordanwolf
Rice King
Jordanwolf's Avatar
I can't see it, besides maybe the fogs.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 04-13-2018, 03:32 PM   #115
strat61caster
strat61caster's Avatar
Originally Posted by Deorio View Post
I personally prefer running a staggered setup with 255/R18s on the driver side and 205/R17s on my passenger side. Since all the off-ramps in my city are right hooking, I get the immediate responsiveness of the passenger side narrower tires throwing me into the bend with the meaty driver side tires keeping me from spinning out. 10/10 wood recommend.
#nascarlyfe
ineedyourdiddly
Tcoat (04-13-2018)
Old 04-16-2018, 01:59 PM   #116
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A quick note on tires. Not all performance tires will perform well on a 205/55 R16 size. The specific size is VERY demanding on the tire. Check here how much deformation has the Pilot Sport 4, which in other dimensions is considered a very good tire. This one has a 94Y XL specification and again the deformation is terrible:
Check now the Advan A052 tire in same size. It is very similar with the A08b that was used in the first post video and has no deformation at all:
Even if both tires had same rubber, the second one would outperform the first every single day.
The Following User Says Thank You to nikitopo For This Useful Post:
Tristor (04-17-2018)
Old 04-16-2018, 02:16 PM   #117
Jordanwolf
Rice King
Jordanwolf's Avatar
Glorious Honda.
The Following 5 Users Say Thank You to Jordanwolf For This Useful Post:
Deorio (04-16-2018), NoHaveMSG (04-16-2018), Spuds (04-16-2018), Teseo (04-16-2018), Tristor (04-16-2018)
Old 04-16-2018, 02:34 PM   #118
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Old 04-16-2018, 08:32 PM   #119
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Do you really have any idea how to do a good comparison?
Just the picture angles and distance are way off on both of your proofs. Simple logic bro.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
Tristor (04-17-2018), venturaII (04-16-2018)
Old 04-16-2018, 09:03 PM   #120
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Two different cars, two different angles, unknown pressures, etc. Comparing apples and guinea pigs in just about the most UNscientific of methods - random pictures from the intarweb. Also LOL that 205/55R16 is somehow a magic tire size that defies all normal tire behavior in any other size.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following 2 Users Say Thank You to venturaII For This Useful Post:
JohnJuan (04-17-2018), Tristor (04-17-2018)
Old 04-16-2018, 10:57 PM   #121
RayRay88
Drives: 2017 86 860 Special Edition
An entire thread with speculation and apples to orange comparisons.
All things being equal a wider tire does more than just manage heat. Thus you need to consider slip angles, contact patch shape, tire spring rates etc.
RayRay88 is offline   Reply With Quote
Old 04-16-2018, 11:11 PM   #122
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
And you need to consider what you're going to do with the car. If it is daily driver, those wider tires do absolutely nothing for you -- and in fact, make the car worse in terms of ride quality, normal handling, and mpg. If you autocross, then they are functional and help. If you supercharge the car, you need them especially in back. But most people get wider tires for looks and ego, and not performance....
And you are right, there is lots to consider about suspension and handling if you go far from OEM specs.
rvoll is offline   Reply With Quote
The Following 2 Users Say Thank You to rvoll For This Useful Post:
Tristor (04-17-2018), why? (04-17-2018)
Old 04-16-2018, 11:34 PM   #123
RayRay88
Ofcourse, but the original argument stemmed between track testing of two different widths. Generally speaking a wider tire gives more mechanical grip than a narrower tire of equal construction and compound.
Old 04-17-2018, 02:01 AM   #124
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have the same issue with my car and it is not related with picture angle, distance, unknown pressure and so on. Do you just want to argue for whatever reason and for everything? And it is not about magic tire size, it is just that the sidewall is quite large. You really need semi-slick tires with very stiff sidewalls in this size.
Here is my car:
And I'll say again that it is not related with picture angle. The deformation is there in whatever angle.
Old 04-17-2018, 02:17 AM   #125
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes but more mechanical grip doesn't make you ALWAYS faster given that power is the same. This was the point of the original post. If it was so simple like swapping tires and wheels, then every manufacturer would provide their models with bigger combinations. The original comparison was of a much more expensive trim level with many changes but not on the engine power and a much cheaper trim level with not so many additions (the ra racing trim in Japan). The latter car outperformed the other one for a reason. But as the previous post some will argue that "the picture angle is not the same". Lol. Arguing just for the sake of arguing ...
Old 04-17-2018, 03:53 AM   #126
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Again, way too many variables from both pictures.
How do you even know the exact conditions both tires are in? Was the picture taken before a run, after a run? Or was it just sitting pretty for hours in the hot sun? Hell, do you know if they purposely under inflated the tire right before their run?
I don't want to be a **** but sometimes you just got to tap out sometimes.
The Following User Says Thank You to Mr.ac For This Useful Post:
venturaII (04-17-2018)
What am I missing with all the ultra-wide wheels & tires? Vdub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-14-2017 09:08 AM
What are some good slippery narrow tires? PowderfaceTr. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 02-07-2015 01:14 AM
Tires that run wide or narrow switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 12-08-2013 04:55 PM
I have a 18x7.5+38 wheels..How wide can i go with tires Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-23-2013 01:04 PM
235 mm tires, great fit but not too wide Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-07-2013 09:38 AM
