Old 05-19-2019, 03:09 AM   #113
Zer0
Drives: 2015 frs
Not much going on with the build. I'm still waiting on my rack and pinion so I can complete the front crossmember. I started setting up my driveline angle the trans mount is probably in its final location. I need to get my vorshlag driveshaft shortened or buy a new shorter shaft, and sell the one I have. Anyone know of a driveline shop that is willing to shorted an aluminum driveshaft in northern California.?
Zer0 is offline   Reply With Quote
Old 05-24-2019, 06:31 PM   #114
Zer0
Drives: 2015 frs
I found a shop in San Jose (South Bay Driveline) to take my driveshaft to. A few friends at work had work done, and gave good reviews for the work performed by that particular shop. They can shorter driveshafts, build new driveshafts, balance them, and more I'm sure. Hopefully I get it back next Tuesday/ Wednesday.
The Following User Says Thank You to Zer0 For This Useful Post:
JeremyR (05-24-2019)
Old 06-03-2019, 01:27 PM   #115
Zer0
Drives: 2015 frs
I picked up the driveshaft today. Test fit it. The length is perfect. I raised my differential 3/4" with P.B.M solid subframe, and differential riser bushings. Raising the differential has caused interference between the driveshaft, and heat shield under the gas tank. Hopefully this weekend I get this figured out. The custom rack and pinion should arrive thursday.
DIY (06-03-2019)
Old 06-06-2019, 01:53 PM   #116
Zer0
Drives: 2015 frs
Just Recieved my new custom rack! Old one is on top new one is on the bottom.
Old 06-06-2019, 02:23 PM   #117
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
So cool to see the updates months later, keep it up!
Marcoscrdo is offline   Reply With Quote
The Following User Says Thank You to Marcoscrdo For This Useful Post:
Zer0 (06-06-2019)
Old 06-06-2019, 06:28 PM   #118
Zer0
Drives: 2015 frs
I dropped the shield under the gas tank, and the driveshaft fits now. I'm going to reshape the bottom of the gas tank to clear the exhaust, and the driveshaft with a heat shield in place. I'm also going to get the OEM evap, and fuel system from a Z06 mounted up. Hopefully get this all done in one shot.
Old 06-09-2019, 02:26 AM   #119
rakanet
Drives: 2013
Dear,
please check this post.
https://ls1tech.com/forums/generatio...nsmission.html
rakanet is offline   Reply With Quote
Old 06-10-2019, 01:56 AM   #120
Zer0
Drives: 2015 frs
Originally Posted by rakanet View Post
I'm running a 6.2L LT4 GenV. Not sure what part of that post pertains to me? Please elaborate.
Old 06-10-2019, 03:02 AM   #121
rakanet
Drives: 2013
you need to check the input shaft not pushing the crankshaft, you may need to trim 0.5" of the input shaft.
the depth of the crankshaft is different comparing LS with LT engines,
Lt have less depth.
The Following User Says Thank You to rakanet For This Useful Post:
Zer0 (06-10-2019)
Old 06-10-2019, 01:41 PM   #122
Zer0
Drives: 2015 frs
I wouldn't cut my input shaft. I would find a different solution. I will double check my clearances. I did order a quicktime steel bellhousing for a LT4 with a T56 Magnum transmission. It is all assembled nothing has broke yet. I think the easiest way to check this at this point will be to have the transmission in gear push in the clutch spin the driveshaft and make sure it spins the transmission without binding on the back of the crank. It looked like the 5.3 had the issues, but it's good info. I will proceed with caution. Thanks. After mock up is complete I will separate the motor, and trans to verify my measurements were correct and all is well.
Old 06-12-2019, 01:06 AM   #123
Zer0
Drives: 2015 frs
Found some info to clarify how to determine which pilot bearing is correct for your particular LS swap.
Old 06-17-2019, 09:53 AM   #124
Zer0
Drives: 2015 frs
Found the correct info. Looks like ls and the Gen V LT engines use the same pilot bearing with the t56 magnum xl, and bell housing kit I have. I thought i was good but double checked to confirm.
Old 06-18-2019, 03:10 AM   #125
rakanet
Drives: 2013
Zer0 (06-18-2019)
Old 07-20-2019, 06:27 PM   #126
Zer0
Drives: 2015 frs
I got my steering rack a while back. I ordered a couple of 1.75" shaft collars to use to make the mounting brackets. I'm in the process of building the final version of my front crossmember. I would have had to modify the last one I made to fit the steering rack where I want it, and I didn't like how it looked. So instead of modifying something I wasn't completely happy with I decided to build something new I would like. I will post up some pictures later.
Andy0323's Back To Basics Build Thread <Long Term Project> andy0323 Member's Car Journals 15 02-02-2018 12:16 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Long term Bt216 Scion FR-S / Toyota 86 GT86 General Forum 3 06-06-2013 11:58 PM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
