Old 11-20-2018, 04:35 AM   #113
kurty85
Drives: 2014 FRS LS Swap
First time making brake lines. Not too bad. Just lots of patience. And do it 20 plus more times
Sent from my SM-G950F using Tapatalk
kurty85 is offline   Reply With Quote
The Following User Says Thank You to kurty85 For This Useful Post:
Sportsguy83 (11-20-2018)
Old 11-22-2018, 12:30 AM   #114
kurty85
Finally got the brake lines done except for 1 fitting (the mc). Next up is the oil drains and mounting the turbos.
The Following 2 Users Say Thank You to kurty85 For This Useful Post:
wooly35 (11-22-2018), Zer0 (11-22-2018)
Old 12-01-2018, 06:42 PM   #115
kurty85
Got the turbo oil drains plumbed, all brake parts hooked up and tightened (just need to fill and bleed), new pivot point for the brake pedal drilled to give it a 6:1 ratio, and extending the wiring for the fuse box and abs block. As soon as i get the headers, i can drop them in and start on the intercooler and downpipes. Thinking i should get the manual tensioner in the picture after reading about this belt arrangement jumping off at high rpm. Anyone use this?[IMG]https://uploads.tapatalk-cdn.com/20181201/ffb89f14fb0a7c444490a998***b2b99.jpg[/IMG]
RuyGuy2 (04-22-2020), Zer0 (12-01-2018)
Old 12-01-2018, 07:09 PM   #116
Zer0
Drives: 2015 frs
I drilled a hole higher up on the brake pedal as well to get a better pedal ratio. Let us know your thoughts on your manual brake setup after you get to try it out.
Zer0 is offline   Reply With Quote
Old 12-01-2018, 07:12 PM   #117
kurty85
I will. I need to get faster grabbing pads too to complete the setup. Any recommendation.
Old 12-01-2018, 07:33 PM   #118
Zer0
Drives: 2015 frs
I haven't driven my car still modifying it so I'm not much help as of yet.
Old 12-01-2018, 09:08 PM   #119
kurty85
I know what you mean. I drove it for a little bit but stopped with exhaust problems (needed to be redone). A lot of things have changed since then. Turbos now, manual brakes, no abs, etc...
Old 12-15-2018, 01:33 AM   #120
kurty85
Got the drift armor bar in. Put the radiator back to the original position to make room for an intercooler roughly 25x18x3.5. Still looking for one i want with 3" inlets and a 3.5" outlet. Used the old fuel tank straps which are the perfect length of the top radiator brace. 3.5" angle down and 26.5" across. Going to add some corner braces and call it good. This will open up 3.5-4.0 inches under the hood for the intercooler to throttle body pipe. Still waiting on the headers but one is done and they are working the second one. Plan is to run all 3" intercooler piping. Most likely intercooler im looking at is the treadstone TRTTC9-3.5. It is a 25x9x3.5 for the core and about 25x15x3.5 total which fits.
Joesurf79 (12-15-2018)
Old 12-17-2018, 03:36 AM   #121
kurty85
Got the headers back and test fitted everything. Already knew i am going to have to make a raised portion of the hood but i am ok with that. Everything else fit pretty well with exception of one minor spot on the radiator frame(will trim) and the oil drain line for the right turbo will have a very small angle to it vice a large angle but it is going to the front cover so i think i should be ok. Next step is to make the downpipes and ic piping.
ILLSMOQ (12-17-2018), Zer0 (12-17-2018)
Old 12-17-2018, 09:51 AM   #122
ILLSMOQ
Drives: 2017 WR BLUE BRZ
This will be awesome but I don’t think your radiator will be up to the task.
ILLSMOQ is offline   Reply With Quote
Old 12-17-2018, 10:45 AM   #123
toast
Drives: 14 BSP Edelbrock BRZ
When too much power is almost enough...
:p
toast is offline   Reply With Quote
Old 12-17-2018, 11:11 AM   #124
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Make some heat shield and run the factory fans and I think it will be good. I ran on the dyno with no fans and never got above 203 F lol
DustinS is offline   Reply With Quote
Old 12-17-2018, 11:54 AM   #125
all4spl
I'm surprised you didn't get their mirrored version of the turbo.
all4spl is offline   Reply With Quote
Old 12-17-2018, 01:10 PM   #126
kurty85
I would have but i bought those turbos in 2011 so mirror image had not happened yet. Precision still doesnt even offer 6765's in mirror image from what i could find. If anyone knows how to get a mirror image 6765H vband that would be awesome. Got these turbos brand new for 800 from real street on sale in 2011 and i sold the car i was going to use them on(6L lq9 in a third gen trans am).
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Not just another ls swap killin'_for_a_livin' Member's Car Journals 7 08-28-2016 05:58 PM
WRX SWAP!!! PowderfaceTr. BRZ Photos, Videos, Wallpapers, Gallery Forum 1 02-24-2015 07:29 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 08:59 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
