Old 02-09-2013, 11:39 PM   #113
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
Originally Posted by welllam View Post
Does it also work on 08 sti and gen 9 s204?
08 sti. Yup I'm pretty sure this is an 8 pin Denso flasher.
Gen 9 s204. Not even sure what car this is = me dunno.
scottmcphee is offline   Reply With Quote
Old 02-09-2013, 11:51 PM   #114
scottmcphee
Originally Posted by Jive Turkey View Post
installed it last night, besides my hand bleeding everywhere it went great!
set it to four blinkers. now is there ANY way to make the wig wag go on while driving without having to buy a new one of these?
Well ya, there'd be a way by adding a switch... To cut ignition power to the flasher to fool it into thinking you're parked while you're really driving. But shhh you didn't hear that from me. And you gotta remember if IGN is cut to the flasher then there is no signaling... You'd be in programming mode if you used the signal stalk without the flashers while IGN is cut. This can cause a very sketchy driving experience, and probably unsafe, so I don't recommend it.
Old 02-10-2013, 04:57 AM   #115
Pacific
Pacific's Avatar
Drives: 5 Celica since 1978.Now a GT86
Hi,
And about the easter egg, could you help in giving some idea?
Thanks
Pacific is offline   Reply With Quote
Old 02-10-2013, 09:38 AM   #116
scottmcphee
Originally Posted by Pacific View Post
Hi,
Thanks
Ya gotta wait til Easter!
Old 02-10-2013, 12:25 PM   #117
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
isnt the wig wag the easter egg? or am i being a derp again.
and s204 is the GD chassis impreza sti ultra JDM model that i rarer than unicorn blood.
Jive Turkey is offline   Reply With Quote
Old 02-10-2013, 01:00 PM   #118
scottmcphee
Derp
OK boils down to impreza chassis, so ya, good to go.
Old 02-10-2013, 03:33 PM   #119
Jive Turkey
the tuna, no crust.
damn it i wanna know!
Old 02-20-2013, 09:29 AM   #120
avusblue
avusblue's Avatar
Drives: 2013 FR-S, Manual, Argento
My Tap Turn module arrived yesterday, and I installed it last night. It works as advertised, and is a nice upgrade! I have this feature in our other cars, and came to miss it in the ’86. I like that you can very easily select the number of flashes upon tapping the turn signal lever. I set it at four; all my other cars with this feature are fixed at three blinks. My understanding is that the standard Tap Turn module makes the turn signal click quietly. So I had the seller provide the modified module, with drilled holes to make the clicking louder. I am glad I did, because in my non-scientific estimation, the new module clicks just a tiny bit louder than stock – in other words, perfect.
I did find the module more difficult to install than I expected. Nothing due to the module itself, but instead because it was very difficult to get the stock module out. I could not get it out of its press-in fixture where it is attached to the structure under the dash. With the stock module stuck in there, I also could not get the wiring bundle disconnected from it, because I did not realize there is a white pushbutton tab on the top side of the connector – it is invisible from below. After struggling with it, I ended up pulling the “guts” out of the shell of the old module, leaving its shell attached under the dash -- the guts actually snap out quite easily. At which point I could finally see that white tab, and could remove the connector from the guts. After that -- all was easy. I just plugged the new module into the connector, zip tied it to a nearby cable bundle, and voila -- done. Lastly, I snapped the guts of the original module back into the old shell, so the stock module remains in the car. The working space under there is pretty tight, but adequate.
Anyway, in conclusion, this is a nice product and a worthwhile upgrade. Highly recommended!
Cheers,
Dave
avusblue is offline   Reply With Quote
Old 02-20-2013, 11:01 AM   #121
scottmcphee
Post #83 in this thread has some install tips, about how the flasher is clipped to the car.
Old 02-20-2013, 12:08 PM   #122
avusblue
avusblue's Avatar
Thanks; I had previously read that helpful post, but it didnt work for me. Maybe I should have exerted more force... but I pulled and pulled, and mine would just not come out. I was afraid of breaking the piece if I pulled much harder on it.
But all's well that ends well. Great product.
Cheers,
Dave
Old 02-20-2013, 05:11 PM   #123
developer
Drives: BRZ Limited
Cheers,
Dave
It is really in there. I had to pull really hard to get it out, just get a good hold of it and pull straight down and nothing should break.
Good luck!
developer is offline   Reply With Quote
Old 02-22-2013, 11:25 AM   #124
BAS
Drives: Snow White
Ordered. Seems to be on back order. Excited to receive and install. Had this on my 2008 VW R32 and miss it tremendously!
TRD Exhaust/Cold Air Intake/High Pressure Radiator Cap (1.3 bar/18.5 psi)/Door Stabilizer, Cusco Front/Rear Type OS Strut Tower Brace/Power Engine Member Brace/Rear Member Brace, 215/45ZR17 PSS, Perrin Master Cylinder Brace/Shorty Antenna/Front Tow Hook License Plate Mount, TWM M1 Abrams White Pearl Shift Knob, SilverStar Ultra H11/9005, OEM Auto Dimming/Home Link Rearview Mirror, Full LED's with Switchbacks and JDM Clear Sidemarkers
BAS is offline   Reply With Quote
Old 03-04-2013, 10:48 PM   #125
Number 6
Drives: Limited 2013 Pearl White - Manual
Good luck!
Developer, what do you mean, "pull straight down", I thought it was connected to the firewall, which is the wall facing the engine. I would have thought that you would pull straight back, towards the drivers seat?
Are there no pictures of this elusive module and it's real location, and an easy procedure for removing it without cutting your hands to shreds?
Number 6 is offline   Reply With Quote
Old 03-05-2013, 08:02 PM   #126
scottmcphee
It looks like a standard flasher, which slides onto a mount rather than pushes onto a mount. The direction to slide the flasher off its mount is to slide it away from the side the plug is on. The plug comes along with the flasher. Some cars use an adapter that slides onto the flasher and then that gets mounted to the car, however it is designed to... On FRS BRZ I think the adapter is pushed into a hole. Hence you can pull that out along with the flasher when you yank it. Maybe there's not enough room to slide the flasher off its mount point in this car... But you can try that first to see if it is possible. Once you have a flasher in your hand you can see how this makes sense.
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
FINALLY My Turn! Gaiakai Scion FR-S / Toyota 86 GT86 General Forum 10 06-12-2012 12:52 AM
