Old 03-29-2020, 03:04 PM   #113
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
Originally Posted by ZDan View Post
Wow, I never see anything like that on the street...
251F I wouldn't worry. Run 5w30 and viscosity should be similar to 0w20 at 220F.
I currently run 0w40. I've thought about trying 5w30 or 5w40 to see how my pressures react at those higher temps. Maybe, my next oil change I might give a different weight a try.
I definitely agree that a quality oil even at 270 would resist breakdown quite well. It's really the pressures that have me a bit concerned.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
Old 04-07-2020, 05:07 AM   #114
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
If you go up a steep enough road in 2nd and 3rd gear at a spirited pace for 20-30 minutues straight you'll hit those temps with no oil cooler. Brake pads will fade and tires will get greasy just like on a track.
Intent > Content
Old 04-09-2020, 06:25 AM   #115
falcon_wizard
Drives: BRZ 2013
I had done some good before and after measurements when installing the Jackson dual radiator water to oil cooler. My finding ls were as follows:
-with regular 0-20 oil, driving at high rpm (say at 4000rpm or above) on the highway for 20mins or more can really crank out temps to 250F and up to 280F. I found its more a factor of rpm rather than speed.
-my recommendation would be for anyone NA Or FI that likes to drive at high rpm for extended periods to at Least go to a quality 5-40 oil. i would strongly recommend an oil cooler for Someone driving extensively at 5000rpm or more, such as on track.
-for my case, the dual jackson rad/oil cooler was very effective for an all year round solution , and kept temps below 240F (with 5-40 oil) even in high demand situations , while helping warming oil up in the winter time as well.
Link to my measurements with and without cooler with high rpm (low speed) driving on the highway: https://www.ft86club.com/forums/show...104943&page=24
Last edited by falcon_wizard; 04-09-2020 at 07:44 AM. Reason: Added link to thread
falcon_wizard is offline   Reply With Quote
The Following User Says Thank You to falcon_wizard For This Useful Post:
solidONE (04-09-2020)
Old 02-20-2023, 11:54 PM   #116
Ultramaroon
not playing cards
Ultramaroon's Avatar
@gtengr, it works beautifully. Daily driving it heats up quickly and maintains nicely between 180F and 190F
In mild ambient temps of maybe 70F-80F, with it hard over through the cooler, the engine on full boil for unlimited duty cycle can just keep up with the cooler. The oil temp remains thermostatically controlled to just above 180F but it rapidly cools as soon as I go back to cruising below 4000 RPM.
I still need to make a bracket for the valve but it sits nestled in some towels nicely for the time being. No chafing.
edit: Oh, and by 'rapidly cools," I mean it goes down to a reasonably, not shockingly 150F-160F from the thermostat bypass flow.
Bump for @timurrrr. I still haven't made a bracket for the valve because it has turned out to be perfectly comfortable laying on the towel. I'll take a pic of that if you want.
If I had to do it again, I wouldn't change a thing. Click on the image for full size
Teseo (02-21-2023)
Head unit depth bluenoserforever Electronics | Audio | NAV | Infotainment 0 07-25-2013 10:50 PM
Depth Behind Radio Opening? kmbkk Electronics | Audio | NAV | Infotainment 0 10-08-2012 12:21 AM
Detailed In-Depth Tour of the BRZ Subaruwrxfan BRZ Photos, Videos, Wallpapers, Gallery Forum 49 06-22-2012 06:38 PM
Depth of speed DIG1992 Other Vehicles & General Automotive Discussions 6 05-22-2012 02:13 PM
AE86: An In-Depth Look at A Legend Axel Scion FR-S / Toyota 86 GT86 General Forum 25 01-26-2010 11:44 PM
