Old 07-31-2013, 04:32 AM   #113
SurfAndSand
8SiX
Drives: FRS 10series
Cool...where can I get a set? If not, are swift springs pretty good?
Originally Posted by DAEMANO View Post
True to their word, RS*R USA had these ready for pickup today. Front and Rear kit. Great group of guys also had a very familiar FRS on their dyno with Innovative kit. Will post the rest of this in a build thread as to not
SurfAndSand is offline   Reply With Quote
Old 07-31-2013, 04:35 AM   #114
SurfAndSand
8SiX
Swift also has different springs for frs and brz respectively.
Are the swift springs a good alternative to the rs*r springs?
Thanks for your advice! I'd hate to mess up my cars handling at the expense of aesthetics - but let's be real, I'm going to lower it. I just want to do it right and economically.
Thanks!
Originally Posted by Moto-P View Post
RS-R has lowering springs for the FR-S and BRZ, it's called the Super-Down Sus, and it drops the cars about 30-40mm. They work with stock shock absorbers, and have different rate sets of progressive spring matched with different part# and rates for the FRS and BRZ to match to even the slightest difference in the two cars OEM shocks.
Old 07-31-2013, 10:02 AM   #115
DAEMANO
Time Traveller
PM'd you the link
Old 07-31-2013, 07:06 PM   #116
SurfAndSand
8SiX
Now when you say the SuperDown Sus springs will work with the stock struts - what does that mean?
I'm guessing because of the more aggressive spring rates, they will wear the struts faster - but by how much? Will they last 1 year, instead of 3?
Thanks for your help on this. I found a place to buy the springs (info@rs-r.com) but now I'm worried about the longevity of my stock struts. If I need to replace my struts so soon after, I may as well wait, and then look for coilovers.
Old 08-02-2013, 12:16 AM   #117
DAEMANO
Time Traveller
Had my RS*R SuperDowns installed today. Initial impressions are here:
http://www.ft86club.com/forums/showp...94&postcount=9
Old 08-02-2013, 03:14 AM   #118
SurfAndSand
8SiX
Thanks for posting your thoughts. I wonder how MOTO can chime in on this - supposedly lowering the vehicle with stock wheels/tires will worsen response. Possibly you haven't explored the true limit of the vehicle - and this makes sense, since you were testing on the street.
Old 08-06-2013, 09:19 AM   #119
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Would you mind give me some advises on my setting. I just order goodyear eagle 225/40r18 front and 245/40r18 rear with a set of 18X8.5 and 18X9.5 rims. Will this be a proper setting for street driving and some corner-fun?
I am also thinking to drop it a little bit. will these TANABE GF210 spring perform good with my new wheels? If not, any lowing spring that you recommend?
0.6" Front Drop
0.9" Rear Drop
Front Spring Rate - 2.7 kg/mm
Rear Spring Rate - 4.5 kg/mm
I just do not want to go coilovers because they are too hard for street driving.
Thank you so much !!
Summary, if you are not very versed in dynamic tuning of a sports car like the FRS.
I can elaborate on definition of soft as "compliant, well damped, and allowing enough stroke at low loads" OF course that can be had in different combinations of factors but generally, the suspension on this car needs to MOVE.
Stock Tires + Stock Tires = pretty darn good.
Low+ Stiff+ Stock tire = bad, hard to rotate, easy to understeer (plow)
Soft + mid-height -20~30mm (or plenty of stroke built into coilver) + medium grip street tire = FUN, Fairly quick, easy to handle, and close to original setup.
Low+Stiff+Race tires = proper race car setup, but requires a lot of driving skills to make it go fast.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 08-06-2013, 09:42 AM   #120
Figo
Figo's Avatar
And the main reason that I go 225 front and 245 rear is for look. I knew I will lose some oversteer and some fun.
If I already purchase these tires and rims, is there any spring or coilover setting can help me to build a car that similar to the stock setting? I do not want it to be really grip cuz I need some corner-fun on the street.
Thank you again.
Old 08-06-2013, 01:04 PM   #121
Figo
Figo's Avatar
BTW I have FR-S with five axis body kit. Do not want to drop too much, and still want some oversteer like FR-S OEM springs. Thank you MOTO
Old 08-06-2013, 01:31 PM   #122
JACK 8URT0N
Black Blood of the Earth
JACK 8URT0N's Avatar
Drives: The Porkchop Express
Where to buy the RS*R springs?
It's all in the reflexes.
JACK 8URT0N is offline   Reply With Quote
Old 08-06-2013, 02:38 PM   #123
DAEMANO
Time Traveller
PM'd you think link (since they're not a board vendor).
Old 08-06-2013, 03:00 PM   #124
SurfAndSand
8SiX
So the RS*R springs work all right with the stock tires? What's the verdict?
I would assume the increase in spring rates would overwhelm the levels of grip available to the stock tires.
Old 08-06-2013, 05:11 PM   #125
DAEMANO
Time Traveller
The stock tires work very well with the RS*R springs. The increased rates well within the range of many manufacturers and under even TRD. Source = this list http://www.ft86club.com/forums/showthread.php?t=8739
Old 08-06-2013, 07:16 PM   #126
troek
troek's Avatar
Drives: 2012 Toyota 86
i have hanook ventus v-12s with my super downs, and they seem to be an awesome combination so far.
Remotely lower windows with key fob? Kido1986 BRZ First-Gen (2012+) — General Topics 25 07-16-2012 10:11 PM
Lower car 1.5 - 2.0 inches F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-23-2012 09:30 PM
BRZ spotted in lower mainland! kidgogeta CANADA 21 04-29-2012 02:20 PM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
