#113 |
Drives: First SWP BRZ-L
I apologize if this has already been posted, but I've got a shop telling me to break in my BRZ like this:
http://www.mototuneusa.com/break_in_secrets.htm I am a little skeptical, like ahausheer. But I could be convinced with more hard data. |
#114 |
Drives: Toyota Auris
It doesn't looks like a site I would trust. But this doesn't necessarily means they aren't right...
#115 | |
Drives: 2013 Limited DGM BRZ
BRZGrincherhood |
#116 |
Drives: 2007 saturn ion(dd)
LMAO! I read the title and i thought out loud," House or car?"
2014 FRS
#117 |
Drives: Attitude
They've been around for a LONG time, hence the shitty 90s era web design. That said, a lot of motorcycle people use that routine and it's found its way into the car world. I won't be babying the car for 1000 miles. Aggressive acceleration, varying RPMs, and lots of engine-braking for 100-200 miles, then drive like usual. Maybe throw in an oil change, but I doubt it.
#118 |
Drives: ZN6 / GDB-G
let the engine warm up before driving and let it cool down before you turn it off with the hood open, always drive it gently and shift and throw all gears, but try to keep revs up to 3k only, do that for the first 1000 miles and avoid hard braking.
#119 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#120 | |
Drives: Attitude
Yeah you need a couple hundred miles to break in pads, rotors, etc.. I've specifically been talking about the engine though. |
#121 |
Drives: VW GLI 6MT
Does anyone know what really happens during those first few miles? Is there an actual “pre-break-in” procedure? Are those hard miles? Are they really monitored?
#122 | |
Drives: Honda Fit
This s a longstanding mystery, Bald. It's hard to believe that a volume manufacturer, like Toyota or GM, is bench testing and bench-breaking-in each and every one of the hundreds of thousands of engines that it produces each year. Maybe M-B or Porsche do it on some of their models. On the other hand, I suppose they could fire each engine up for a few seconds, once it reaches the end of the production line, just to look for major leaks, etc. I do not know. This is akin to that other great mystery, i.e., Is there such a thing as break-in oil from the factory? |
#123 |
Drives: prelude
Sounds like most ppl would break in their car hard and using conventional oil when Subaru manual say to keep it under 4k rpm while filling up with 0w20 synthetic.
Yet I am leaning on the hard break in method rather than follow the engineers recommendation. I really want to keep this car for a longggg time so I wouldnt mind breaking it in correctly.
#124 |
Drives: '06 AM V8V Coupe
I don't understand why people want to second guess the OEM engineers when it comes to something as complex and with so many unknown details as an engine. Only they know what's done to the engines before they're put into the cars, and if they recommend something and back it up with a warranty, why are you going to try to undo everything
Makes no sense.It's not like an aero mod where you put a skirt here, put a cover there, it's a freaking engine that's worth more than any other part on the car. |
#125 | |
Delights in pure handling
Drives: Zoom Zoom
#126 | |
Kuruma Otaku
Because titanium. |
| Tags |
| break-in |
