Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
06-08-2016, 03:06 AM | #113 |
The Fail Boat
Drives: CWP S.B.
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures)
I just got the thing installed, it's not hard looking back.... It's just a lot easier then I thought it would be looking back.
But I have a problem thou..... How to get rid of the lines on the camera? >__> Not the headunit lines since our headunit already has the proper line in it since our camera sits on the side instead of center of the vehicle. Sent from my iPhone using Tapatalk |
06-10-2016, 11:07 AM | #114 | |
Drives: SWP BRZ
i installed mine with Rydeen Mini instead of Duo. i put camera center right below Subaru emblem |
The Following User Says Thank You to zc06_kisstherain For This Useful Post: | chaoskaze (06-10-2016) |
06-10-2016, 11:48 AM | #115 |
@anthonysestito
Drives: 2013 Sterling Silver Metallic BRZ
Haven't finished reading through this thread but I wonder if this will work on the pioneer headunits?
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO |
06-10-2016, 12:45 PM | #116 | |
Senior Misanthrope
The Following User Says Thank You to kch For This Useful Post: | chaoskaze (06-10-2016) |
06-12-2016, 08:44 PM | #117 |
Drives: GTS 86 auto
The lower bolts that hold the head unit go to metal framework in the dash and thus can be a convenient earth point. The upper bolts are no good as they go to metal clips the clips over plastic.
GTS86 Auto (Australia)
09-17-2016, 07:05 PM | #118 |
Drives: 2016 Subaru BRZ
Thank you to the OP for that incredible DIY. I just installed a cam in my Canadian 2016 (Canadian 2016 BRZs do not come with a backup camera) with the FA743CS head-unit.
I ended up purchasing the full kit (CS-SUBRZ-132) from Camera Source. I know you can assemble pieces in the kit separately for cheaper, but this seemed the easiest and the camera it comes with is 6V so no requirement to find other power / ground. If anybody is looking to do the same thing, I had pull my head unit first to determine that my head unit had a 16-pin connector. The harness they sent had a pass through to attach the pre-existing plug which I believe recognizes the e-brake position. My car already had the reverse wire sensor connected (noted that before the install by checking the diagnostics screen). Install probably took ~3 hours. Some of the tips that were super helpful included using soap to lubricate the wires to pass through some of the rubber conduits, including the conduit to the trunk. I had previously installed a camera in our old Sienna and that trick would have saved me lots of time. I will need to adjust the backup lines at some point, but that's a future project. Next up is trying to retrofit a Gentex 536 mirror onto the mirror mount and installing a dash cam. |
10-22-2016, 07:54 PM | #119 |
Drives: '13 BRZ
Many many thanks to OP for this post. It was extremely helpful. I installed a Camera Source kit on my '13 BRZ today and the thorough instructions in this post were fantastic...the ones that came with the kit don't explain anything beyond the basic wiring on the head unit. Awesome post!
10-24-2016, 12:21 AM | #120 |
Drives: Frs
01-29-2021, 06:18 PM | #121 | |
Drives: 14 WRB BRZ Limited
Similar Threads | ||||
WRB BRZ - 2 step paint correction & Opti-Coat by Mr. Sparkle Detailing - Long Island | Mr. Sparkle | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 02-10-2013 10:04 PM |
step 1 :buy frs in phx, step 2: drive to pikes peak | haymaker | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 08-21-2012 10:44 AM |
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:38 AM |
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:27 AM |
