07-07-2023, 05:25 PM | #113 |
Drives: Crapcan
No, it stays in the cooler.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | OldBiker (07-07-2023) |
07-07-2023, 10:57 PM | #114 |
Drives: 23 BRZ, ex 15 BRZ
Generally speaking, people with oil coolers just leave the oil in the cooler when they do oil changes.
The Following 3 Users Say Thank You to GDIsteve For This Useful Post: |
07-10-2023, 11:24 PM | #115 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
New videeeeeo!
@KillerBMotorsport - why the need for a prefilter? The shape and size of the prefilter seems to offer a smaller surface area through which oil gets pulled through which means higher relative surface for RTV blockage if there is loose RTV? I suspect the prefilter is the primary reason of why the modified oiling solution car has such a considerably lower pressure overall.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
07-11-2023, 10:49 AM | #116 | |
You can see the product here. https://www.killerbmotorsport.net/oi...-and-gr86.html While testing in our shop BRZ, we didn't experience any drop in oil pressure, however we were not pushing the car as hard as Brian. His data is welcome and valuable. |
07-11-2023, 11:50 AM | #117 | |
Are the holes smaller?
07-23-2023, 01:32 PM | #118 |
Drives: 2020 BRZ/86, 2020 BMW 330i
Is everyone who's logging oil pressures using AEM sensor?
07-25-2023, 09:46 AM | #119 |
Drives: Mini Cooper S
Just out of curiosity, whats the price range for a dry sump kit for the last gen cars?
07-25-2023, 11:08 AM | #121 |
Drives: '23 BRZ
Potential dry-sump alternative:
I'm going to send an oil sample to Blackstone after two track events at right-hand intensive circuits (NMMP Lightning, Thompson (CT) Speedway). If bearing or other wear metal content is high, likely gonna get 2qt Accusump. |
The Following 2 Users Say Thank You to ZDan For This Useful Post: | autosenses (07-25-2023), nissanfanatic (07-25-2023) |
07-25-2023, 09:52 PM | #122 |
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
Whoa! What is this?
How does it work?
07-25-2023, 11:09 PM | #123 |
Drives: 2015 Subaru BRZ WRB
Basically it is a high pressure oil filed reservoir that is actuated when your oil pressure reads below a threshold. This will help prevent oil starvation or under-pressure catastrophes.
07-26-2023, 07:27 AM | #124 |
Drives: 2023 brz limited 6mt red
Still want data for the spirited canyon/mountain public road people....
A good data log test would be a run on the dragon.. I don't think the oil pressure drop would be near catastrophic levels if at all on public roads unless your being insanely reckless or even get near pulling high G like on the track without losing traction and hitting a guard rail. So I speculate track people/autocross people obviously need a solution. For the daily commuters/spirited public road people may need nothing and will hopefully satiate the toxic social media of "all brz and gr86 engines are time bombs."
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
07-26-2023, 07:51 AM | #125 |
Very helpful. Sounds like a possible solution before going full sump system. However, a possible issue here is too much oil being pressured into the oil pan.
I guess maybe, a 1qt option could be a good start? Worst case scenario, you have 1qt in the pan for a few moments. I don't know..
07-26-2023, 09:31 AM | #126 | |
Drives: GR86
We also don't see those drops on anything short of a hot lap, which to me says that spirited public road driving isn't going to be a problem because that's pretty on-par with warm-up lap driving. Finally, at least one of the people doing the tests say that the only conditions they see the pressure drop dangerously is track driving. If they're lying about that, none of the rest of what they're saying is worth looking at and the new data you want would be suspect. |
The Following User Says Thank You to Spektyr For This Useful Post: | vindiesel (07-26-2023) |
Similar Threads | ||||
2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 0 | 11-18-2022 05:15 PM |
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp | KillerBMotorsport | BRZ Second-Gen (2022+) -- General Topics | 50 | 10-29-2022 07:36 AM |
High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 09:51 AM |
FS: NEW Bluemoon Oil Baffle & Killer-B pick up tube. | FRSH86 | Engine, Exhaust, Bolt-Ons | 2 | 04-20-2020 10:49 AM |
Compatibility: Moroso Baffle and Killer Bee Oil sump | Nightflo | Engine, Exhaust, Transmission | 3 | 04-27-2019 09:40 PM |
