Old 07-07-2023, 05:25 PM   #113
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by OldBiker View Post
Doesn't all the oil from the cooler return back to the sump when you turn off the engine? In which case you would not know your true operating oil level! (And if the oil stays in the cooler... then you would need a separate drain plug for oil changes.)
No, it stays in the cooler.
Old 07-07-2023, 10:57 PM   #114
GDIsteve
GDIsteve's Avatar
Drives: 23 BRZ, ex 15 BRZ
Generally speaking, people with oil coolers just leave the oil in the cooler when they do oil changes.
GDIsteve is offline   Reply With Quote
Old 07-10-2023, 11:24 PM   #115
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
New videeeeeo!
@KillerBMotorsport - why the need for a prefilter? The shape and size of the prefilter seems to offer a smaller surface area through which oil gets pulled through which means higher relative surface for RTV blockage if there is loose RTV? I suspect the prefilter is the primary reason of why the modified oiling solution car has such a considerably lower pressure overall.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 07-11-2023, 10:49 AM   #116
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by Frost View Post
New videeeeeo!
Thanks for the question, The surface of our prefilter is larger than the OEM screen in the pickup. You can block up to 80% of the screen before flow is affected.
You can see the product here.
https://www.killerbmotorsport.net/oi...-and-gr86.html
While testing in our shop BRZ, we didn't experience any drop in oil pressure, however we were not pushing the car as hard as Brian. His data is welcome and valuable.
KillerBMotorsport is offline   Reply With Quote
Old 07-11-2023, 11:50 AM   #117
Frost
Frost's Avatar
Thanks!
Are the holes smaller?
Old 07-23-2023, 01:32 PM   #118
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Is everyone who's logging oil pressures using AEM sensor?
Arthur-A is offline   Reply With Quote
Old 07-25-2023, 09:46 AM   #119
BioRebel
Drives: Mini Cooper S
Just out of curiosity, whats the price range for a dry sump kit for the last gen cars?
BioRebel is offline   Reply With Quote
Old 07-25-2023, 10:06 AM   #120
Code Monkey
Drives: Subaru BRZ
Starting price is here.
Code Monkey is offline   Reply With Quote
Old 07-25-2023, 11:08 AM   #121
ZDan
ZDan's Avatar
Drives: '23 BRZ
Potential dry-sump alternative:
I'm going to send an oil sample to Blackstone after two track events at right-hand intensive circuits (NMMP Lightning, Thompson (CT) Speedway). If bearing or other wear metal content is high, likely gonna get 2qt Accusump.
Old 07-25-2023, 09:52 PM   #122
autosenses
autosenses's Avatar
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
Whoa! What is this?
How does it work?
autosenses is offline   Reply With Quote
Old 07-25-2023, 11:09 PM   #123
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Originally Posted by autosenses View Post
Whoa! What is this?
How does it work?
Basically it is a high pressure oil filed reservoir that is actuated when your oil pressure reads below a threshold. This will help prevent oil starvation or under-pressure catastrophes.
irax is offline   Reply With Quote
Old 07-26-2023, 07:27 AM   #124
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
Still want data for the spirited canyon/mountain public road people....
A good data log test would be a run on the dragon..
I don't think the oil pressure drop would be near catastrophic levels if at all on public roads unless your being insanely reckless or even get near pulling high G like on the track without losing traction and hitting a guard rail.
So I speculate track people/autocross people obviously need a solution. For the daily commuters/spirited public road people may need nothing and will hopefully satiate the toxic social media of "all brz and gr86 engines are time bombs."
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
Old 07-26-2023, 07:51 AM   #125
autosenses
autosenses's Avatar
Very helpful. Sounds like a possible solution before going full sump system. However, a possible issue here is too much oil being pressured into the oil pan.
I guess maybe, a 1qt option could be a good start? Worst case scenario, you have 1qt in the pan for a few moments.
I don't know..
Old 07-26-2023, 09:31 AM   #126
Spektyr
Drives: GR86
I'm not sure it's necessary. You can extrapolate the data from the existing race logs - they have more right turns than "problem" right turns, and the lateral forces build and wane in each corner so you can get a pretty clear idea of just how much cornering force is necessary to produce the oil pressure drops.
We also don't see those drops on anything short of a hot lap, which to me says that spirited public road driving isn't going to be a problem because that's pretty on-par with warm-up lap driving.
Finally, at least one of the people doing the tests say that the only conditions they see the pressure drop dangerously is track driving. If they're lying about that, none of the rest of what they're saying is worth looking at and the new data you want would be suspect.
Spektyr is offline   Reply With Quote
2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto Ansix Auto Engine, Exhaust, Bolt-Ons 0 11-18-2022 05:15 PM
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp KillerBMotorsport BRZ Second-Gen (2022+) — General Topics 50 10-29-2022 07:36 AM
High Flow Oil Pickup by Killer B Motorsport KillerBMotorsport Engine, Exhaust, Bolt-Ons 4 04-26-2022 09:51 AM
FS: NEW Bluemoon Oil Baffle & Killer-B pick up tube. FRSH86 Engine, Exhaust, Bolt-Ons 2 04-20-2020 10:49 AM
Compatibility: Moroso Baffle and Killer Bee Oil sump Nightflo Engine, Exhaust, Transmission 3 04-27-2019 09:40 PM
