Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-20-2023, 05:10 PM   #1233
jetvermillion
Drives: '22 BRZ Limited MT
Installed an HKS Spec L II catback. I would have gone with the regular spec L (a few db louder) but the L II tips look much nicer and are swappable.
Pretty happy with it. Sounds way better than stock despite it still being on the quiet side. However, this makes me much less worried about installing headers and being too loud/obnoxious
In person, the exhaust tone is much deeper than how it sounds on most video clips
this one
Code:
https://www.youtube.com/watch?v=FGs76FwZMwk
is probably the most accurate representation).
Cold start is noticeably louder but nothing crazy. Once the rpms drop it's actually hilariously quiet
jetvermillion is offline   Reply With Quote
Old 01-20-2023, 11:18 PM   #1234
Liquidsnake
Drives: "I drives like a Porsche"
this one
Code:
Nice, I have the premium Legamax axelback premium. While it is not that loud it is much much better thank stock, and it allowed me to turn off the fake sounds and enjoy the engine.
Liquidsnake is offline   Reply With Quote
Old 01-23-2023, 12:58 PM   #1235
DarkSunrise
DarkSunrise's Avatar
Threw on SPC 81305 camber bolts over the weekend. Swapped the lower bolts into the top holes for additional camber. Couple of notes:
- The SPC bolts I used were brand new but I couldn’t seat the nuts by hand. There was a ton of resistance in the first 1/3 of the thread (estimate around 10 ft-lbs to spin it through with a socket wrench). It took so much force the nuts actually heated up. It loosened up progressively after that towards the middle of the thread and took the full 97 ft-lbs so I’m not too worried. I had a set of SPC upper bolts on my 1st gen and didn’t run into this issue. Strange.
- I used a 3mm spacer in the front to try to clear my Apex ARC-8’s (17x9 +42; 235/40/17) on stock suspension. Clearance was fine but I only got 4.5 full turns on the lug nuts. I tried my Wedssport TC105n (17x8 +42; 235/40/17) and got 7.5 turns on the nuts. I guess the Apex wheels have a thicker center plate, not sure. Given this, I’ll probably switch to a single camber bolt + Pedders camber top hat in the future to fit my Apex wheels.
-Spacers were from Stancemagic (don’t laugh). Only ~$20 on Amazon and they’re hubcentric. Pretty good quality, no vibrations I could feel up to around 85 mph.
- The amount of camber from this setup is pretty impressive. Visually it looks close to the -2.8 degrees I was running on my 1st gen. I’d estimate somewhere between -2 to -2.5 degrees. My understanding is that toe doesn’t change in the front much with camber, so will probably drive like this for a while and see how it feel before aligning it.
2022 BRZ Build
2013 FR-S Build
Old 01-23-2023, 01:16 PM   #1236
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I had similar experience with those same camber bolts last week, the locking nut was pretty darn tight.
With stock wheels I was getting ~10 turns on my Eibach studs (10mm extended and 10m spacer) but I'll check again with the APEX wheels. I get like 8 turns with my Enkeis.
I also have stancemagic spacers to put on the car, they're really nicely made and no complaints.
Toe *barely* changed on my car going from -4.5 to -4.8, like 1/64th of an inch or so.
Old 01-23-2023, 03:31 PM   #1237
DriveDriftDogfight86
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
Delivered some tofu with a friend today
DriveDriftDogfight86 is offline   Reply With Quote
Old 01-23-2023, 04:15 PM   #1238
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by DocWalt View Post
Got some hood struts for Christmas so I installed those yesterday
Which ones did you get?
rb6freak is offline   Reply With Quote
Old 01-23-2023, 04:44 PM   #1239
DNAcomposition
DNAcomposition's Avatar
Drives: '23 BRZ Limited 6MT WRB
Nice! What city is this in CA?
DNAcomposition is offline   Reply With Quote
Old 01-23-2023, 09:00 PM   #1240
El Monte, right beside Los Angeles
Old 01-24-2023, 09:12 PM   #1241
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
The Noble non-CF. They fit great and work well.
Old 01-25-2023, 11:27 AM   #1242
KillerBMotorsport
KillerBMotorsport's Avatar
Lots of dev work going here, so we swapped back to our Street Rat muffler delete for more testing.
KillerBMotorsport is offline   Reply With Quote
Old 01-25-2023, 06:40 PM   #1243
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Had lots of fun plowing snow
Stonehorsw is offline   Reply With Quote
Old 01-26-2023, 04:25 PM   #1244
BioRebel
Drives: Mini Cooper S
For those who miss the feeling of a bite point in the clutch pedal, the mtec clutch spring is a pretty good mod. Installation is a total nightmare though, I'm not a big person (5'11") but I had to remove the driver seat to get in there and swap it out.
BioRebel is offline   Reply With Quote
Old 01-27-2023, 05:51 PM   #1245
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Wow you gave up and took the driver seat out? I just cussed harder and harder until I got it. Ain't no way this little puny spring is going to make me do EVEN MORE work.
Interceptor777 is offline   Reply With Quote
Old 01-29-2023, 03:01 AM   #1246
636
636's Avatar
Drives: '23 CWP BRZ
Finally dialed in the fitment and took it for a spin around the neighborhood.
636 is offline   Reply With Quote
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
