04-03-2014, 10:52 PM | #1205 |
Drives: 2014 Subaru BRZ
Hi!!
Soon to be new vortech owner. I've been using openflash to tune my car while n/a and I'm planning on switching over to ecutek now with the vortech kit. I haven't used ecutek before. Is it as easy as open flash for uploading maps? Do you guys recommend any tuners? I don't really like my options for local tuners, I'm in south florida. Sorry for the newb questions. Thanks advance!
Molded rb v1 BRZ on WCI LP1
instagram.com/seantejani |
04-03-2014, 11:58 PM | #1206 | |
Drives: WRB Subaru BRZ
04-04-2014, 12:03 AM | #1207 | |
BTW I just got my smaller pulley installed (3.125). Pulls significantly more especially mid range. Still waiting on revised tune before I do a red line pulls. |
The Following User Says Thank You to congiiee For This Useful Post: | Cal3000 (04-04-2014) |
04-04-2014, 12:08 AM | #1208 | |
Thanks for the response man. That seems simple enough. Similar to OFT. I don't have a windows laptop but I can figure something out. Do you recommend any tuners to get started with? I'm going to buy the ecutek cable and license now.
04-04-2014, 12:46 AM | #1209 | |
Drives: Panda FR-S
I do experience knock correction everyday, but never during WOT. Even on the stock tune, the car knocked a lot. I don't know if it's the tune or the 91 piss that I'm on I've had 3 different 4 different tunes from 3 different tuners and the same knock occurrences result. So you don't have tune for the smaller pulley?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
04-04-2014, 01:31 AM | #1210 | ||
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
The Following User Says Thank You to nelsmar For This Useful Post: | ft86me (04-04-2014) |
04-04-2014, 02:03 AM | #1211 |
Drives: 2013 FRS
[QUOTE=nelsmar;1648147]@jamesm is in florida and is a wonderful tuner. If you still cant find anyone I may be able to work something out to lend you a hand. @ft86me has been doing lots of long term testing of a vortech map for me and seems pretty happy so far.
pretty happy so far is an understatement. more like EFFING AMAZED would be the right thing to say!! @nelsmar @Red FRS |
04-04-2014, 02:26 AM | #1212 | |
Platinum Member
Drives: Toyota 86 Vortech SC
I run much higher than that on track, like 130°C oil and 100°C coolant, and I've never noticed my car pulling timing at all. I'm running Vortech SC and Uni-Q
The Following User Says Thank You to Fish Eagle For This Useful Post: | Cal3000 (04-06-2014) |
04-04-2014, 03:06 AM | #1213 | |
04-04-2014, 03:08 AM | #1214 | |
I do have a tune for it. Waiting on a revised one now. As for your knocking issues it's probably 91 as you suspect. I have yet to encounter knocking. |
04-04-2014, 08:00 AM | #1215 |
Drives: Toyota 86
Finally got my car dynoed today. Best pull was 261 hp / 173 tq @ 7,900rpm STD corrected
only about 235whp @ 7500rpm Need to have the tune tweaked. AFR was leaning out from 4,500-7900rpm. This is already with 700cc injectors and 265lph fuel pump. Not sure if this is because of an exhaust leak somewhere, or if the fuel pump backed out and does not have enough pressure. I'll be installing an AEM wideband o2 then back to the dyno for proper tuning. The car hasn't been tuned on the dyno yet, just at the street. Vortech 9psi stock pulley 100 RON pump gas 6MT Borla UEL header Milltek over pipe Milltek front pipe Milltek resonated catback Deatschwerks 700cc injectors and DW65c 265lph fuel pump tuned by Speedworks (same tuner as Blitzkrieg's 300whp Vortech 9psi) Blue line is NA with stock ECU, stock header and Milltek full exhaust. 152whp 127 tq Red line was NA with stock ECU, Borla header, Takeda intake and Milltek exhaust. 150whp 121 tq. The dyno operator today used this plot by mistake, see the red plot on the second photo for the best pull of this setup (152 whp 127tq) Green line is my best pull today with the Vortech. |
04-04-2014, 09:16 AM | #1216 |
Drives: GBS BRZ
So I'm about due for an oil change. What weight is everybody running after going FI ?
04-04-2014, 09:54 AM | #1217 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
04-04-2014, 10:11 AM | #1218 |
@nelsmar @King Tut
I am planning on driving down to Orlando to see @jamesm but first I need to install the kit and I can't drive it without a tune so I guess the best option would be to find a tuner that can send me maps.
Similar Threads | ||||
Vortech Supercharger | denverizzles | Forced Induction | 176 | 10-19-2013 06:48 PM |
New Vortech Supercharging System Information... | Brian@Vortech | Forced Induction | 306 | 11-08-2012 05:49 PM |
Supercharging the GT86 | Billy2224 | Engine, Exhaust, Transmission | 13 | 06-05-2012 03:58 PM |
Turbo/Supercharging Your FRS | BoostJunkie | Engine, Exhaust, Transmission | 123 | 05-18-2012 06:26 PM |
Supercharging: the forgotten form of FI | madfast | Engine, Exhaust, Transmission | 76 | 03-02-2012 05:06 PM |
