Old 04-05-2018, 11:45 AM   #1191
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC there were some made in relation to nameless ripoff called PLM longtube headers.
Couldn't find quickly that thread, but i see some tables in OFT Tune tips thread OP by steve99. Search for "Intake and Exhaust VVT CAM tables for NAMELESS or PLM long tube catless headers."
Old 04-05-2018, 07:41 PM   #1192
steve99
Originally Posted by DeltaEcho View Post
Where can I find the tables for nameless Headers? Would like to take a look
Sent from my G8142 using Tapatalk
You could ask shiv, but you would probably need a custom tune
Old 04-17-2018, 05:12 PM   #1193
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
Thanks for the thread. I am new to the OFT world.
2015 FRS with gruppe-s uel headers (no cats) and a nameless muffled track pipe. I assume my best bet is to run the stage 2+ 91 map (I am in California).
The other feature I would like to take advantage of is eliminating the cold start so I don't piss off my neighbors. However I have read that if you modify a file it can be easy to mess up the rom and that can make the ecu unrecoverable. Would anyone like to suggest the best way to go about getting he stage 2+ 91 rom with cold start igniting timing retard disabled?
Thanks for any help and suggestions.
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 04-17-2018, 05:24 PM   #1194
Qadthane
Qadthane's Avatar
Drives: 2013 FR-S in Asphalt
The V4 tunes have the cold start cacophony disabled by default. They are WAY quieter on startup.
Qadthane is offline   Reply With Quote
Old 04-17-2018, 05:27 PM   #1195
SkiRideDrive
Drives: 2015 FRS
That is awesome! Thanks
Old 05-06-2018, 07:59 AM   #1196
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
I just got a OFT 2 and just updated it on my laptop. However, I cannot figure out how to rotate the screen 180 degrees. I want to have the OBDII port on the bottom instead of the top so I can mount it in my car. I read the original post but there is no menu option that I can find. Can someone please assist?
SkyeHack is offline   Reply With Quote
Old 05-11-2018, 11:17 PM   #1197
2017subiebrz
Drives: 2017 Subaru BRZ Limited
I just purchased as well, and am having this exact same issue with the Open Flash Tablet 2. The best mountain point is upside-down, but it doesn't appear as OFT2 has an option to rotate the screen. Halp!
Update: there appears to be a rotate button ont he left side of the diagnostics screen, but it isn't working...
2017subiebrz is offline   Reply With Quote
Old 05-21-2018, 11:14 PM   #1198
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
I was just coming here to post about both of your points. I want to rotate it but can't find the option. Also, that button doesn't do anything on mine either. Same before and after flashing a tune.
Sevs753 is offline   Reply With Quote
Old 05-22-2018, 05:10 PM   #1199
myothercarisafanatec
Drives: 16 - BRZ MT
Both relieved and frustrated that I'm not the obly one who can't figure out how to rotate the screen on the OFT v2. Hopefully it's fixed in an update? Really limits mounting options.
Sent from my HTC 10 using Tapatalk
myothercarisafanatec is offline   Reply With Quote
Old 06-16-2018, 06:32 PM   #1200
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Holy shit the new updates made my car much quieter on startup!!
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 06-20-2018, 10:39 AM   #1201
skogs
Drives: GT86 2013
I just changed from OFH and stage 2 tune back to stock, and the auto shifts way, way smoother. Is rough shifting a known problem with OFT and automatic transmission?
skogs is offline   Reply With Quote
Old 06-20-2018, 06:15 PM   #1202
DrButtDrugs
yerp
Drives: 2015 WRX
I just got my OFT and my first flash was to the A00C v4 Stage 1 tune . Is it normal for these tunes to significantly change the engagement point of the accelerator pedal? It seems like I have to push a solid inch or more over the old tune to get the slightest bump over idle.
I know I'm sensitive to it because I have been driving on a stock tune for 2 years but it seems like something I wouldn't consider desirable.
That said, I'm loving that my car can idle smoothly now, has launch control, and smoothed out the torque dip. Just gotta wait for a free weekend to put on the header.
edit: I think I may have downloaded the world market tunes instead of US. Could that be the source of my problem even though the CALID matched?
DrButtDrugs is offline   Reply With Quote
Old 06-20-2018, 08:22 PM   #1203
alxtheoreo
alxtheoreo's Avatar
Yes. From my experience, this will happen every time you reflash the ECU.
To help speed up the learning process, I used to do the start-up procedure listed by Steve99 on the main page of this thread, and hop on a clear highway for about 50-60 miles with the cruise control set.
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 06-21-2018, 05:36 PM   #1204
DrButtDrugs
yerp
Drives: 2015 WRX
Ahh so that's what people say when they mean it needs to re-learn. Makes sense.
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
