#1191 | |
Drives: 2016 BRZ, 94 Integra GSR
#1192 |
Drives: UK GT86
Yes.
The 1st lot of data for MAF1 was minimal. To get the best results you should reduce the dV/dt parameter but this requires more logging time as you discard more. I tend to set mine to 0.3/0.25 but then I like logs of 45 mins or longer when I do this.
.: Stealth 86 :.
#1193 |
Drives: 2016 Scion FR-S
Should I flash the MAF1 rom or MAF3 rom if I wanted to do more logging to scale the maf and improve it?
#1194 |
Drives: UK GT86
No matter which one you do, the results should be the same. However sense would suggest you continue with the most recent and therefore the more accurate.
.: Stealth 86 :.
#1195 |
Drives: 2013 Pearl White Subaru BRZ Limited
First time posting in here. Just installed Borla V2 UEL yesterday and flashed the Stg. 2 UEL E85 Tune.. Let me know if everything is okay
. Idle and cruising:http://datazap.me/u/alexela/lunabuil...log=0&data=1-9 |
#1196 |
Drives: 2015 86 GTS + Mitsi Lancer GSR
I think I've done this right. Never used datazap before but here we go
EcuTek Sprintex SPS 210 700CC DW injectors Zeitronix flex fuel http://www.datazap.me/u/coo86l/delic...0cc-revision-1 |
#1197 |
Drives: 2015 Firestorm Scion FRS
So I'm a total rookie at this but I've been lots of reading and experimenting lately to try to optimize my tune over the past few weeks and wondering if anyone can guide me in the right direction to smooth out the flkc and fuel trims even further.
I started off with the OFH 93 tune as a base tried applying Wayno's settings to see if I'm getting better results. I'm running the following parts: - auto transmission - JDL catted UEL header - stock overpipe/frontpipe - TRD catback - Perrin drop-in filter - gas is Chevron 94 octane Here's the logs for the following: original OFH 93 UEL tune: http://www.datazap.me/u/gawesome/201...data=1-5-11-12 original OFT 93 UEL tune: http://www.datazap.me/u/gawesome/201...data=1-5-10-11 OFH custom tune with Wayno's auto throttle map, always-on radiator fan, 'Stg2 UEL 98 v101.AU.Rich A01G UEL' base timing b and AVCS tables: http://www.datazap.me/u/gawesome/201...0&data=1-10-11 OFH custom tune with Wayno's auto throttle map, always-on radiator fan, 'Stg2 UEL 98 v101.AU.Rich A01G UEL' base timing b and Shiv's JDL E85 AVCS tables: http://www.datazap.me/u/gawesome/201...0&data=1-10-11 So from my rookie observations, all seems to being dropping IAM slowly with the 1st custom tune being the better of the 3 tunes. It looks like the OFH custom tune with Wayno's maps seems to be less erratic with flkc with the exception of the ltft being weirdly higher at -8 compared to the other two around -4ish which I don't really understand. I haven't scaled my maf yet btw for all 3 tunes. Or maybe I'm just starting with an overly aggressive tune since I did use the OFH tune. But IAM and flkc looks worse on the OFT tune though? I'm wondering if the erratic flkc at higher rpms be a fuel issue? Or is this something that just needs refining? I could try to fuel up with the next best gas here (Shell 91oct) and reflash with a 91 tune to test it out. |
#1198 |
Drives: FR-S Whiteout
@G-awesome the calibrations you've loaded are typically used on non-catted header setups, I believe. So, it may be that the ignition advance is simply too aggressive or the acvs table not well suited for your setup. I'd load a stg 1 calibration and log just to see if the flkc goes way. A number of different things can be causing your problem though. Exhaust vibration due to improper installation, bad gas, unsuitable calibration. Although the 3rd log using wayno's 98ron cam and ignition calibration looks the least worrisome.
Intent > Content
cowardice is the mother of cruelty. |
#1199 | |
#1200 |
If the stg 1 come turns out to be free of knock (relatively) then you will have ruled out the vibration cause. Though, with a stg 1 calibration i think its safe to say you will not be taking full advantage of your headers. I'm sure ideally it's somewhere between a stg1 and stg2. Or you can try to find somebody with catted uel headers and use their cam and ignition maps as a starting point.
Intent > Content
#1201 |
Drives: Scion FRS || Ducati 899
Do you guys use a software when analyzing the csv's or just know what your looking for .-.
#1202 |
RWD addicted
Drives: BRZ 6MT OFT OFH
Hi!
here is the log i made during track session yesterday. Tuned by OFT based on v.101 Wayno's tune (+ custom MAF scale). my opinion the engine was working properly: http://datazap.me/u/ondreiko/mrw-log...zoom=7419-7481 and i am going to make some final minor changes to MAF scaling (as excellent VGI's tool shows) in field of OL mode basing on this log. |
#1203 | |
Drives: Toyota 86 GTS
Would be quicker to just multiple 3.71 and 3.91 cells by 1.01 and call it a day. Don't need any tools.
http://datazap.me/u/ondreiko/mrw-log...mark=2852-2895 Quote:
#1204 | |
looks like I'm gonna check the hardware for leaks, vibrations, etc. |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
