#1163 | |
Dismember
Drives: 2013 Red Scion FR-S
#1164 | |
Drives: FRS, Supra, Colorado D, GLC63
Like you mentioned though, you aren't driving at your full limit, which is perfectly fine. It has taken me a while to even drive at 8/10's after a nasty crash I had last year. The thing is though, finding the car's limit and your limit are two very different things. I think the trouble you are having is that you are at your limit and the car really has a TON more to give. If you want to go for more power, I'm happy to help you look at options, but I do strongly believe that you can get more enjoyment out of your car for a bit longer first, without adding 100hp. Also, I have the same braking setup as you I believe (RR-Racing stage 2 with BP20's) My brakes are dead silent on track, you need to get and keep heat in them. Another indication that you can go a lot harder! ![]() I promise you can get the car to lose grip, even if it means overheating the tires! Start at 2:28 to about 2:40 [ame="https://www.youtube.com/watch?v=VrjjKvT6-as"]The Racers Line FRS @ Thunderhill 5 Mile 5 30 16 - YouTube[/ame] |
#1165 | ||
Drives: 1993 Impreza w/ WRX Swap + FWD!
#1166 | |
#1167 |
Thats another problem for me... Throttle input is missing big time. I dont have to be cautious at all with the throttle, just bang on it on exit 100% and thats it. I'd like to be able to add oversteer of need be and do more fone control with the throttle/wheel to control it. I havent learned anything with that outside of video games.
#1168 |
The couple times ive used the dance the car goes into ice mode when braking and the pedal falls out from under me. I havent noticed the ABS kicking in early.
#1169 | |
Dismember
Go pick up some stock 2013 or '14 FR-S suspension. Give a little camber to the front. Then you'll have all the power oversteer you need, as long as you're in the proper gear.The FR-S is a car that lives on the throttle throughout every single corner. My mind is 75% on the throttle when I'm cornering. That's the entire point of the car, IMHO. If I wanted to go fast, I'd buy a race-prepped Civic for cheap.
#1170 | |
The problem with the stock setup is that it was slow... Also quite ugly :P I ran the car for awhile with a C-stock tyoe setup with a fsb, camber bolts and frs rear springs. Drove really well, so well in fact thats what I was trying to duplicate with the better wheels/tires and coilovers. I succeeded but the tires are too good as mentioned. |
#1171 | |
Dismember
Ummm... WTF, man? You don't make no sense! Autocross tires on HPDE? Check! Overly wide tires to raise lap times? Check! Frankenstein suspension setup? Check! Ignores advice of been-there-done-that, much-faster drivers? Check! Belief in own amazing suspension setup skills? Check! Blaming the car instead of the driver? Check!
#1172 | ||||
I went with the traditional 17x9 245/40 autox setup because of forum advice and witnessing properly setup cars in person. I have zero regrets with the current wheel/tire choice after going through 4 other wheel/tire sets. Quote:
I'm OK with saving the 9/10ths+ driving for autox where its safe, and I know I could risk going faster but Its not a competition so whats the point of taking that risk? There are a couple of corners I could have certainly used more advice on braking and turn-in points, that can be for next time. Quote:
Yes I could improve, but yes its risky too... I could easily have wound up like the other ft86 member who totaled his car in the second run of the day. I'm OK with that and do plan to go back again eventually. If I had a dedicated racecar and plenty of money and insurance, then things would be different. I might actually wind up in an even worse situation soon with no garage to even work on the car, which is another reason why im concerned about major power mods. |
#1173 | |
Dismember
#1174 | |
For reference, here I am exceeding 9/10ths with this corner, you can see the car get visibly upset: [ame]http://youtu.be/bCoqQL4Iswg[/ame] |
#1175 |
Dismember
I like how you explain the corner in terms of tenths. I'm not really sure what you mean by that, but whatever.
#1176 | |
| HPDE - Sebring with PCA 2/23/13 - 2/24/13 | Dave-ROR | Southeast | 2 | 01-03-2013 09:25 PM |
| How can you help somebody get into HPDE | RedRocket | Tracking / Autocross / HPDE / Drifting | 4 | 10-02-2012 07:19 PM |
| HPDE with BMW CCA | Texas BRZ | Southwest | 0 | 09-14-2012 11:46 AM |
| norcal hpde? | slaxx | Southern California | 1 | 08-18-2012 02:13 AM |
| HPDE Day video | Dragonitti | Other Vehicles & General Automotive Discussions | 34 | 06-12-2011 10:11 PM |
