Old 01-23-2014, 07:56 AM   #1135
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by Admired View Post
Question, so I'm picking up my FRS in the next day or so from my shop who installed the turbo kit. Do I need to immediately upload the base tune from Toni or can I drive it home then upload the file?
if u can do it there then do it to b safe
lbroskee is offline   Reply With Quote
Old 01-23-2014, 08:04 AM   #1136
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
The sooner the better
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 01-23-2014, 11:26 AM   #1137
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If you installed injectors, then the car won't run without a tune.
Old 01-23-2014, 11:32 AM   #1138
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Originally Posted by Fl4t fun View Post
@Ny Brz what shop is that at?
@PrimeMotoring in New Jersey, @JuniorAWD did the tune.
Ny Brz is offline   Reply With Quote
Old 01-23-2014, 11:36 AM   #1139
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You could blow the engine on the way home. Tune it there. Hope you didn't get a flex tune.
Old 01-23-2014, 12:08 PM   #1140
jamesm
fwiw it only takes about an hour or two of street driving to nail down bigger injectors on a car, and is a very, very straightforward process. i'd just do it and be done with it. easier than limping the car to a tuner states away. you could at least get them dialed in well enough to make the drive to the tuner more pleasant.
Old 01-25-2014, 07:35 AM   #1141
Admired
Drives: 2013 Scion FRS
Where is the thread where you schedule that 1 day tuning day with Ecutek software to optimize the turbo setup? Is it recommended to complete this right away or can you drive on the base tune safely for a while?
Admired is offline   Reply With Quote
Old 01-25-2014, 08:00 AM   #1142
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Email Toni @ info@fa20club.com for details on setting up your appointment for tuning.
It is recommended to be tuned as soon as possible, and ideally immediately, after install.
However, you can use your base tune but avoid boost and WOT flogging until your tuning session.
Old 01-25-2014, 11:01 AM   #1143
lbroskee
lbroskee's Avatar
Good luck. I been tryna get my basemap for a week so i can install my kit tomorow. It's getting annoying. The only reason I'm not flipping out tho is bc i no when i do get it it'll b fine and I'll have no issues
Old 01-25-2014, 11:03 AM   #1144
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I highly suggest you look for a different tuner. Highly.
slicktop is offline   Reply With Quote
Old 01-25-2014, 11:05 AM   #1145
lbroskee
lbroskee's Avatar
i may just b/c i need more timely tuning, but i still need the baseman just so i can put it on the car
Old 01-25-2014, 11:23 AM   #1146
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I wouldn't let Toni touch your car if it were me. And, FWIW, it was just a couple days ago. I, unfortunately, got the FA20Club turbo kit and I chose to have it tuned locally instead. I just installed it at my house, and drove it to the tuner. Keep it out of boost and you will be fine without a base map.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 01-25-2014, 11:25 AM   #1147
lbroskee
lbroskee's Avatar
i have no other tuners close enough and tryna stay outta boost is WAY risky to me
Old 01-25-2014, 11:30 AM   #1148
woode
Boosted Member
woode's Avatar
FWIW, I drove almost 2 hours to a tuner.. no problems. Averaged 70mph and 30mpg even
Only time I had to be mindful was accelerating up hills.. and even then it wasn't really that big of a deal.
Edit: I have the 60 trim turbo and full exhaust, which hinders spool time.. making it easier to stay out of boost.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
