Old 06-21-2013, 01:40 PM   #1135
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by sw20kosh View Post
Although very impressive...no one is talking about your car here... What are you trying to say cause it is lost on me. The car used as an example is skatery's car which made a whole lot of power on e85 and more boost.
No offense.
I believe he's visconti tuned, and his e-tunes leave much to be desired. I believe every tune he ships without refinement has knock in it. Don't get me wrong I also got swiped up in the visconti fury, but luckily enough I got a courptted tune file from him and was left stranded with a dead car, mike from moto-east came in picked up the pieces and tuned me pretty.
To sum it up, I would never look at a visconti remote tune and think its normal, if he is visconti tuned (skatery) then I think there's alot more available at that boost level with e-85, safer, with no knock. The tune visconti is proud enough with the stock vortech to post a pic of the dyno was 245whp, with no power gains above 6grand, flatliners, as I call them, and it's jagged, way jagged, even where the torque flatlines, it's jagged from an unhappy motor. I think that sums up what I'm inferring, so it's not the same, but it's still 2 apples one smaller then the other, but the shape can be compared.
Hope that helps as to why I think me and slatery can be compared.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
The Following User Says Thank You to Adeets For This Useful Post:
DBee (06-21-2013)
Old 06-21-2013, 03:11 PM   #1136
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by ft_sjo View Post
Sorry to bring this shock to you but the Sprintex supercharger kit is imported. It's not 'Made in America'. Neither is your car.
Couple things..
He didn't say it was made in America.
Importing several hundred units is FAR FAR cheaper per-unit than it is to import a single one. Counting price conversion and shipping, the kit would cost around $7000 before any import taxes. That's an extra $3K-$4K USD! So no, we can't "just import" one on a whim. That's not how global trade works.
Old 06-21-2013, 06:54 PM   #1137
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
It shouldn't be amazing to me that one person bringing up CARB has caused that to be the latest go-to reason that the kit isn't here yet, but I still manage to be shocked pretty much daily by online forums.
I think the internet is only making us dumber.
Sellout is offline   Reply With Quote
The Following User Says Thank You to Sellout For This Useful Post:
wparsons (06-22-2013)
Old 06-21-2013, 07:35 PM   #1138
Anaxilus
Drives: They have four wheels
No kidding. Especially all the people crying for dynos because all the physics, math and circumstantial data already presented simply isn't enough for these people. What's even sadder is knowing that any manufacturer will release a dyno graph that is somewhat ideal in appearance and usually 'touched up' like a swimsuit model.
Of course half of these remarks are typically from people who didn't even read anything and just jump in making off the cuff comments polluting the thread.
However, CARB has been brought up by several people in several Innovate threads. You might be late to the Innovate rodeo on that one.
Anaxilus is offline   Reply With Quote
Old 06-21-2013, 07:55 PM   #1139
Sellout
Mr. Cranky Pants
Sellout's Avatar
My favorite is the "OMG efficiency" folks. This engine is so much different than anything that's ever been done before... As if we've never seen a GT3076R max at 500ish whp on a low compression motor, and then 500ish whp on a high compression motor at lower boost.
Oh I know, I just meant that someone mentioned, a few (several?) pages back that CARB testing might be the hold up and now CARB testing is the thing we're all going to bitch about.
Old 06-21-2013, 08:59 PM   #1140
buditjoenawan
Drives: Very very slowly
You are absolutely right, because GT3076r is a >50lb/min turbocharger. So the headroom is right on the point. The difference between boost levels is only because boost doesn't measure flow, which is the only thing that matters. Anyway, signing off since it doesn't matter what the facts say.
budi
buditjoenawan is offline   Reply With Quote
Old 06-21-2013, 10:03 PM   #1141
Calum
That Guy
Drives: 2013 asphalt FRS MT
That's it, I'm just gonna go back to wedge shaped combustion chambers. Because clearly combustion chamber shape has no effect on thermal and/or mechanical efficiency. Nor does rod to stroke ratio, bore size, injection type, ring sealing capability, chamber cooling, egr, scavenging, piston cooling, oil viscosity, pumping and parasitic losses, and compression ratio. Clearly all engines are exactly the same barring the swept volume of the pistons. And brake specific fuel consumption isn't actually a measurement of how efficient an engine makes power from the fuel it's consuming, and thus the air it's consuming by virtue of the air fuel ratio. Is just a bullshit phrase thrown around by people.
The Following 2 Users Say Thank You to Calum For This Useful Post:
Sportsguy83 (06-21-2013), wparsons (06-22-2013)
Old 06-21-2013, 10:04 PM   #1142
OrbitalEllipses
Drives: Attitude
Originally Posted by Calum View Post
That's it, I'm just gonna go back to wedge shaped combustion chambers. Because clearly combustion chamber shape has no effect on thermal and/or mechanical efficiency. Nor does rod to stroke ratio, bore size, injection type, ring sealing capability, chamber cooling, egr, scavenging, piston cooling, oil viscosity, pumping and parasitic losses, and compression ratio. Clearly all engines are exactly the same barring the swept volume of the pistons. And brake specific fuel consumption isn't actually a measurement of how efficient an engine makes power from the fuel it's consuming, and thus the air it's consuming by virtue of the air fuel ratio. Is just a bullshit phrase thrown around by people to make you thnk they know what they're talking about.
I'm converting my pistons to triangles for better VE.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Calum (06-22-2013), zigzagz94 (06-21-2013)
Old 06-21-2013, 10:17 PM   #1143
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Change them to a "V" shape, I think it goes better with VE.
Old 06-21-2013, 11:22 PM   #1144
Anaxilus
Rotary huh.
The Following User Says Thank You to Anaxilus For This Useful Post:
Old 06-21-2013, 11:43 PM   #1145
Sellout
Mr. Cranky Pants
Sellout's Avatar
Yeah yeah yeah. How much more horsepower for each LB/min of air ingested do you think an FA20 can do over the F20C? F22C? How about the F20C over the 4G63?
F20C, F22C, 4G63, 4B11... They ALL max out a GT3076 somewhere real close to 500whp. Despite being different engines. Surely they don't all have the same rod ratio, piston ring sealing, bore size, cooling efficiency, compression ratio. Hell, one of them makes 120hp/L. WITHOUT direct injection and continuously variable cam timing. Surely that one should be capable of 600whp from 52lb/min...
Old 06-22-2013, 05:27 AM   #1146
ft_sjo
Drives: GT86
PI is superior for making power over DI.
Old 06-22-2013, 05:51 AM   #1147
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
I don't really agree with all the demand for dynos.. we need a machine to hook the car to, that spits out a page with two ratings: 1: a "sad face" to "happy face" scale-o-fun (can use robi's actual sh*t eating grin) and 2: the color, make, model and plate numbers of the people always trying to race me in my city, that I can now demolish.
I would pay paper money for those results, because ultimately, as my DD, I want more power on tap to make drives between meetings even more enjoyable than they already are, and to not only beat, but strike the fear into my local honda-with-a-paper-cup-exhaust-tip owners hearts!
sure a dyno graph will help with that, and I enjoy all the new "facts" about engine internals and air pumping, but really.. a couple YouTube videos, and the "feels like a solid V6" and robi's description of peoples response from ride a longs is exactly what I need. Maybe for the "American muscle" side of my brain, a couple 1/4 mile and 0-speed limit times would help haha
not trying to start anything else towards distracting the thread, but I am very much excited (and somewhat patiently waiting) for some news on this, and also to see what all the creative tuners out there can do with this kit once they get their hands on it. Until then, however.. keep up the hints robi!!!
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
The Following User Says Thank You to Batman For This Useful Post:
Subzero (06-22-2013)
Old 06-22-2013, 06:59 AM   #1148
Anaxilus
That's relative based on how you are making said power. Guess it's nice to have both then.
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 11:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 11:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 05:40 PM
