Old 10-08-2014, 11:04 AM   #1135
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Originally Posted by xDanger_208x View Post
What do you think @SubiePig between 245 and 255??
I went 255 RS3 V1 -> 255 ZII -> 245 RS3.
Due to the softer sidewall of the V2 compared to the other 2 sets its not that noticeable with them on a 9" wheel. I spray the V2's between runs and the pressures are the same about as what I ran on the V1's. They are great so far, though they don't like to get hot like the old ones which is kinda depressing if you want to do a track session.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 10-08-2014, 01:30 PM   #1136
wparsons
wparsons's Avatar
Originally Posted by BRZZZZZZZZZZ View Post
Jeezus they are $15 a tire difference from what I have seen on average.
ZII SS were around $1150 mounted taxes in locally, RS3's were $810. I needed them ASAP so ordering from tirerack wasn't an option.
flickr
Old 10-08-2014, 01:31 PM   #1137
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I use 1010tires usually and they are currently $15 a tire difference.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 10-08-2014, 02:04 PM   #1138
conedodging
conedodging's Avatar
Drives: '14 BRZ
Don't forget there will probably be more tires added to the equation next year. 200 TW R1R successor, rumors of a Rival successor, etc.
Makes me glad to live in a region that doesn't really get going until April, gives others time to do the testing.
conedodging is offline   Reply With Quote
Old 10-08-2014, 02:19 PM   #1139
BRZZZZZZZZZZ
Car Nut
Our first event this year was April 26th, and it was snowing
Old 10-08-2014, 03:12 PM   #1140
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
I vote 245-40-17 for size. Hankook RS3 V2 will have my money until something proves to be better.
2superblus is offline   Reply With Quote
Old 10-09-2014, 05:55 AM   #1141
rx3
Originally Posted by Scooby South
I will say that others that have been in the car like how it feels, and how it transitions, and these are top caliber drivers.
Wasn't there a female rally driver who was missing oversteer driving your car? Was this just an outlier or have you changed the set-up since?
Back to toe alignment: Do you know what screw turn/angle leads to what toe change? E.g. 1/2 turn in the front or rear delivers 0.05 toe change per wheel?
rx3 is offline   Reply With Quote
Old 10-09-2014, 07:19 AM   #1142
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Completely changed... spring rates, ride height and rebound/compression.. the rear is an eccentric so its limited on change..because it can rotate 360 degrees.. mine is close to the max on the lobe..
Bill
Scooby South is offline   Reply With Quote
Old 10-13-2014, 10:47 AM   #1143
conedodging
Drives: '14 BRZ
Some stuff hitched a ride home with me after the last event of the season...
Old 10-14-2014, 08:38 AM   #1144
BRZZZZZZZZZZ
Car Nut
What LCAs are those?
Old 10-14-2014, 09:32 AM   #1145
xDanger_208x
xDanger_208x's Avatar
Drives:
RacerX???
I'm curious as well.
xDanger_208x is offline   Reply With Quote
Old 10-14-2014, 10:54 AM   #1146
SubiePig
Racer-x. I have them as well, no complaints. @xDanger_208x
Old 10-14-2014, 11:24 AM   #1147
conedodging
Drives: '14 BRZ
Yup, Racer-x. I was told they're useful because you can do an axle swap without having to remove them.
Old 10-24-2014, 12:09 AM   #1148
autoXracer
Drives: 2013 WRB BRZ
How much Rear Camber is everyone running?
What's a good amount of REAR camber? I currently don't have adjustable rear camber but have SPC arms to install.
Currently running RS-3 V2 245/40-17's
Front -3.3 camber, 6.5 caster, 1/16 total toe out
Rear -2.2/2.5 camber, 1/8 total toe in (uneven left/right since I don't have adjustable camber)
autoXracer is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
