#1121 |
Drives: 2013 FRS
Wow, yea, this could explain a lot if bad set of sensors got out there! How can we test for this????
| The Following 2 Users Say Thank You to 86fun For This Useful Post: | BigFatFlip (04-08-2016), clayrush (04-08-2016) |
#1122 | |
I believe one way to tell if your MAP sensor offset is wrong is to turn the ignition to the ON position but don't start the car. Compare your barometric sensor with the MAP sensor reading. They should be equal or close it. If you're at sea level, it should ready 1 Bar! |
#1123 |
Boost Creep
Drives: 2016 HyperBlue BRZ
I have noticed my baro and MAP pressures are off by just a touch but it's like 1-2 kPa at atmosphere. Nothing too serious. My vacuum reads -18 to -19 inHg on a standalone gauge, and the Ecutek log reflects this.
This is an etune with the factory 2.5bar. I think yours is just special, lol.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
#1124 | |
That Guy
Drives: 2013 asphalt FRS MT
I've trouble shoot a lot of different things. One of the hardest parts of trouble shooting is figuring out if it's the instrumentation or the process that's off but once you eliminate one, the other is all that's left. In this case it was the instrumentation, what about this issue made that conclusion so hard to come to? |
#1125 |
DRIFT
Drives: Raven FRS 6mt
Has anyone tried another intake pipe? I have the fa20 club uel header and think it may melt the plastic intake box. A pipe come up behind the rad kinda like the nameless header and I remember reading something similar. I have the fa20club cold air intake as well that I wouldn't mind cutting up to make work. I also have stock header that I could hollow out and install but I'd rather not..
#1126 |
Drives: 2015 Raven FRS
| The Following User Says Thank You to Lunatic For This Useful Post: | strat61caster (04-08-2016) |
#1127 | |
Drives: 2015 brz
I'll check MAP sensor readings as you suggested. Was that the cause of your P0451 code? |
#1128 | |
See below link for P0451 code: https://cobbtuning.zendesk.com/hc/en...otential-Fixes |
| The Following 2 Users Say Thank You to dj2020 For This Useful Post: | Luftwaffel (04-08-2016), nstymatt (04-09-2016) |
#1129 | |
Boost Creep
I had a P0451 when I had an incorrectly scaled MAP, FWIW.
| The Following User Says Thank You to Luftwaffel For This Useful Post: | nstymatt (04-09-2016) |
#1130 | |
Drives: 2015 brz
#1132 |
Drives: 2015 brz
#1133 |
Boost Creep
Did you check your log with the car on but not running and compare atmospheric pressure with manifold pressure?
#1134 | |
Drives: 2015 brz
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
