Old 04-08-2016, 02:47 PM   #1121
86fun
Drives: 2013 FRS
Wow, yea, this could explain a lot if bad set of sensors got out there! How can we test for this????
86fun is offline   Reply With Quote
The Following 2 Users Say Thank You to 86fun For This Useful Post:
BigFatFlip (04-08-2016), clayrush (04-08-2016)
Old 04-08-2016, 03:04 PM   #1122
dj2020
On my JRSC set up, I switched to an OMNI 2.5 MAP sensor when upgraded to the HBP. It automatically threw a P0451 code for me after 2-3 drives. Not saying this is directly related to the above problems. Shawn Church eventually figured out that either the offset or scaling was off on my sensor for some reason. Now, I don't know if the sensor calibration itself was off or if the initial scaling/offset settings were incorrectly entered into my Ecutek tune. Either way, Shawn made it right.
I believe one way to tell if your MAP sensor offset is wrong is to turn the ignition to the ON position but don't start the car. Compare your barometric sensor with the MAP sensor reading. They should be equal or close it. If you're at sea level, it should ready 1 Bar!
dj2020 is offline   Reply With Quote
Old 04-08-2016, 04:02 PM   #1123
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
I have noticed my baro and MAP pressures are off by just a touch but it's like 1-2 kPa at atmosphere. Nothing too serious. My vacuum reads -18 to -19 inHg on a standalone gauge, and the Ecutek log reflects this.
This is an etune with the factory 2.5bar. I think yours is just special, lol.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 04-08-2016, 04:31 PM   #1124
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by sales@delicioustuning.com View Post
Steve,
I gave Shawn Church a call this morning to talk about your car and see exactly what was going on with it. I understand how things can sometimes get misconstrued when the topic isn't something one is an expert on, so allow me to relay exactly what the problem was with your car.
Edelbrock kits come standard with a 2.5BAR Bosch Map sensor. Aftermarket map sensors must be scaled within the tune, and map sensors typically have a standard scaling which is adhered to. Case and point, every 2.5BAR Bosch map sensor we've done, and every 2.5BAR Bosch map sensor Shawn has done up to this point, has used the exact same scaling. Turns out, your particular car, for whatever reason, did not like the standard scaling and Shawn had to SIGNIFICANTLY alter even his own scaling to get it to read properly on your vehicle. Shawn and I agreed that this kind of inconsistency is not something that has any chance of being dialed in remotely, and would absolutely need to be done in person to diagnose and address properly. If you'll recall, we as the tuners at Delicious Tuning never saw your car in person.
This accounts 100% for your P0068 code, which relies on the MAF, MAP, and throttle all playing nicely together. Since the map sensor scaling was off due to your "unicorn" sensor, the throttle also had significant issues through the usable range which made the car absolutely terrible to drive. In addition, since your scaling was again off on the standard 2.5BAR values, vacuum reflected far too high at idle even after you had fixed your leaks. Since manifold pressure read too high at idle, your fuel trims were also out of whack. These symptoms represent themselves as a vacuum leak, which is why I was telling you to continue looking for one. This explains why you could no longer find any leaks after fixing the major ones, and why we were all left scratching our heads as to why your vehicle was still having issues.
As a tuner, this kind of inconsistency is not something that could have been diagnosed, addressed, or even guessed at without seeing and touching the car in person. While I understand it is also very easy to point fingers at vendors, this is clearly a special case. Your car is running well now; drive it and enjoy it. Is it by no fault of Delicious Tuning that your map sensor was so far off compared to every other 2.5BAR we've done, and is not something we could have fixed without seeing the car in person (which was always an option).
Sincerely,
Zach
I'm gonna ask the question on my mind, but please understand I fully respect you and Bill and the tune I've been running for years now. So, this is likely gonna seem like I'm being a devil's advocate, but only because I don't understand, not because I suspect you guys don't.
I've trouble shoot a lot of different things. One of the hardest parts of trouble shooting is figuring out if it's the instrumentation or the process that's off but once you eliminate one, the other is all that's left. In this case it was the instrumentation, what about this issue made that conclusion so hard to come to?
Old 04-08-2016, 05:16 PM   #1125
86KEEBS
DRIFT
Drives: Raven FRS 6mt
Has anyone tried another intake pipe? I have the fa20 club uel header and think it may melt the plastic intake box. A pipe come up behind the rad kinda like the nameless header and I remember reading something similar. I have the fa20club cold air intake as well that I wouldn't mind cutting up to make work. I also have stock header that I could hollow out and install but I'd rather not..
86KEEBS is offline   Reply With Quote
Old 04-08-2016, 05:20 PM   #1126
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
For clarity, were you using the Edelbrock supplied BOSCH 2.5 Bar MAP sensor?
Yes.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
strat61caster (04-08-2016)
Old 04-08-2016, 05:25 PM   #1127
nstymatt
Drives: 2015 brz
Interesting, I recently installed a jrsc (stock pulley, c30) and the car threw a P0451 code after a few startups too. I've read that P0451 is likely due to either a leak somewhere, or a sensor that is used for a boost solenoid/flexfuel kit was not being disabled in the tune. I don't suspect it's a vacuum leak since idle is completely fine (ECUTek logs reflect this too). But my tuner is also said that the sensor is disabled as well, so I'm not sure what it could be.
I'll check MAP sensor readings as you suggested. Was that the cause of your P0451 code?
nstymatt is offline   Reply With Quote
Old 04-08-2016, 05:55 PM   #1128
dj2020
My P0451 was an incorrect MAP sensor calibration I believe. Either the sensor was off or the offset/scale was incorrect in the tune for my 2.5 MAP bar sensor. Once this was accounted for by my tuner, everything was running fine and no more P0451 code thrown even after re-enabling the code in the tune. When I was getting the P0451 code, my MAP sensor was easily reading 0.15-0.20 BAR less than the true 0.94 BAR reading at my elevation. Now it's always within 0.01 BAR or so compared to the baro sensor. (I hope this is not too off topic since we have JRSC set ups and we're in the Edelbrock thread, sorry.)
See below link for P0451 code:
https://cobbtuning.zendesk.com/hc/en...otential-Fixes
The Following 2 Users Say Thank You to dj2020 For This Useful Post:
Luftwaffel (04-08-2016), nstymatt (04-09-2016)
Old 04-08-2016, 06:10 PM   #1129
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Any other intake has to be tuned for, and is probably not an amazing idea in the first place. My recommendation is resell your header and pick up another one second hand if possible. I'm not going to lie, every time I see that style of header, I stare at it for a minute and marvel at the lack of forethought in their design.
I had a P0451 when I had an incorrectly scaled MAP, FWIW.
The Following User Says Thank You to Luftwaffel For This Useful Post:
Old 04-08-2016, 06:15 PM   #1130
nstymatt
Drives: 2015 brz
Thanks so much! I'll check this out. Yeah, let's not derail the edelbrock thread. Do you mind if I PM you if anything comes up?
Old 04-08-2016, 06:18 PM   #1131
dj2020
Anytime man!
The Following User Says Thank You to dj2020 For This Useful Post:
Old 04-08-2016, 06:35 PM   #1132
nstymatt
Drives: 2015 brz
I'm on moto-east tune as well...perhaps they left this out on my tune too. I'll double check with them, thanks!
Old 04-08-2016, 06:45 PM   #1133
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Did you check your log with the car on but not running and compare atmospheric pressure with manifold pressure?
Old 04-08-2016, 06:47 PM   #1134
nstymatt
Drives: 2015 brz
Not yet, I'll get around to this later today. I really really really hope this is the cause of P0451 for me, if not I'm not sure what else it could be
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
