Old 09-28-2014, 01:21 PM   #1107
xDanger_208x
xDanger_208x's Avatar
Drives:
Let's talk spring rates...
What are you all using? I have the RCE T2's with their 400lb springs all around.
I'm thinking a set of 350lb springs in the rear will help settle the back end in the high speed slaloms/sweepers.
Even with a larger front bar the back end isn't as "planted" as I'd like.
xDanger_208x is offline   Reply With Quote
Old 09-28-2014, 04:30 PM   #1108
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Whats your alignment??? That plays a BIG part of how the car reacts. I am at 1/16th Toe in Total on the rear. I have the same rates (400 squared) and 18mm STi rear bar.. Car is "Very" Planted..
Scooby South is offline   Reply With Quote
Old 09-28-2014, 04:33 PM   #1109
xDanger_208x
Drives:
I'm at zero toe all around. I'll try some toe in the rear before springs.
Old 09-30-2014, 03:32 PM   #1110
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Did you adjust meaning soften compression at all too?
2superblus is offline   Reply With Quote
Old 09-30-2014, 04:31 PM   #1111
xDanger_208x
Drives:
Yup. Still not enough imo
Old 09-30-2014, 08:29 PM   #1112
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
So I got my top hats now and will be installing them next week. I've got my camber settings figured out, but not toe.
Should I:
A) set 0 toe all around
B) set front corners to 1/32 toe out, rear to 1/32 toe in (I think I got that right?)
C) 1/32 toe out up front, 0 toe in rear
D) 0 toe up front, 1/32 toe in in the rear?
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 09-30-2014, 10:26 PM   #1113
Scooby South
Conedancer
Option: B would be my choice... Toe out in front for better turn-in...Toe in on the rear for stability ..
Bill
The Following 2 Users Say Thank You to Scooby South For This Useful Post:
fstlane (09-30-2014), Turkish (09-30-2014)
Old 10-02-2014, 03:28 PM   #1114
haison
Drives: 2014 Subaru BRZ
Bill
Is it good to daily drive with that toe? I'll be getting an alignment before the next autocross
haison is offline   Reply With Quote
Old 10-02-2014, 03:40 PM   #1115
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I don't like the idea of toe on a daily driver personally.
50+ miles of commuting with your front tires wanting to travel away from eachother, and your rear tires wanting to travel towards eachother....
-Jack Burton
Old 10-02-2014, 03:55 PM   #1116
Scooby South
Conedancer
I don't daily mine but have put extensive travel miles on it.. to and from events.. with no issues.. usually about a 750 miles at a time.. my *local events are about 275 miles round trip for me.. again with no issues.. Pretty even tire wear across the board. I have 3 sets of rim/tires but I always use one set for traveling and those are the Dunlop Z2's at this point.. I have RS3's and did have Federals but I am switching those to Z2 starspecs... since the Feds aren't legal next year.
Bill
Old 10-02-2014, 04:02 PM   #1117
Scooby South
Conedancer
I am a bit more aggressive on my own alignment.... : -3.2 front with .07 (toe out on each side, which is about 1/16th total toe out on the front. the rear is at -1.8 and .07 toe in again about 1/16th total toe in. And still have absolutely NO issues with abnormal tire wear..
Bill
fstlane (10-02-2014), haison (11-04-2014)
Old 10-02-2014, 08:45 PM   #1118
Turkish
Serial Cone Killer
Turkish's Avatar
Bill
That is pretty close to the alignment I am looking at. Would you daily drive with that alignment, knowing that the car also competes in autocross?
... his name is...
C'THULHU
Old 10-02-2014, 08:58 PM   #1119
Scooby South
Conedancer
yes I wouldn't hesitate.. since I drive on it to events anyways ...
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
Turkish (10-02-2014)
Old 10-03-2014, 08:00 AM   #1120
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Keep in mind tires are not solid objects. Also take a look at the factory alignment specs.
Front:
Camber: 0 +/- 45' (0 +/- 0.75°) (Right/Left Difference: 0°45' (0.75°) or less)
Caster (Reference): 5°54' (5.90°)
Steering Axis Inclination (Reference): 15°31' (15.52°)
Toe (Each Wheel): 0°00' +/- 0°11' (0.00° +/- 0.19°)
Toe (Total): 0 +/- 3.0 mm (0 +/- 0.1181 in.)
Rear:
Camber: -1°12' +/- 45' (-1.20° +/- 0.75°) (Right/Left Difference: 45' (0.75°) or less)
Toe (Each Wheel): C + D: 0°10' +/- 0°15' (0.16° +/- 0.24°)
Toe (Total): 2.0 +/- 3.0 mm(0.0787 +/- 0.1181 in.)
Don't like toe? Better take every brand new car you will ever own directly from the dealership to an alignment shop. The specs recommended previously for toe are well within the factory recommended specs for the front and just outside on the rear.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following 4 Users Say Thank You to Thorpedo For This Useful Post:
conedodging (10-03-2014), fstlane (10-03-2014), Scooby South (10-03-2014), Turkish (10-03-2014)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
