Old 08-02-2016, 08:17 PM   #99
JFunk
JFunk's Avatar
Drives: 2013 Scion Frs
Originally Posted by takethecake View Post
I changed my plugs on sunday at ~58k miles, took me about 7 hours to do that and an oil change. I think it'll take me 3 if I have to do it again - I'll be able to make sure I have all the sockets/extensions/adapters I need.
This came in handy for unbolting the screws holding the coil packs on. Also the telescoping magnet on a stick is a must - if you drop shit all the time like I do, you might even want to take off the metal underbody panel protecting the transmission/exhaust so everything just falls on the ground lol..
ALSO, I just ordered some thin kevlar gloves and heat sleeves - my arms and hands are covered in little cuts and scrapes.
You think you can show me all the tools you used ?
JFunk is offline   Reply With Quote
Old 08-07-2016, 12:02 PM   #100
seant2h
Drives: 2013 BRZ 6MT LTD
I changed my plugs yesterday at 100,056 miles and it took me, an amature wrencher, under 3 hours. The motor is simple to raise up after you remove 2- 14mm nuts and it raises up easily and gives you much more room to work. I found the left, drivers, side to be harder than the right when it was jacked up. My secret weapon was a short magnetic extension that was used to remove and screw in the spark plug initially. See the pics below for the tools I used and what my 100,000 mile plugs look like. I just realized I forgot to include the extendable magnet tool that was also very important in getting it done.
seant2h is offline   Reply With Quote
The Following 4 Users Say Thank You to seant2h For This Useful Post:
hmong337 (08-15-2016), Lonewolf (11-15-2016), radroach (10-12-2016), zeal86 (08-07-2016)
Old 08-07-2016, 06:26 PM   #101
humfrz
Originally Posted by seant2h View Post
I changed my plugs yesterday at 100,056 miles............ ]
Could you tell much difference between the old ones and new ones, as far as electrode erosion .. ??
humfrz
Old 08-12-2016, 12:55 PM   #102
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Is everyone here using a light coat of anti-sieze on the spark plug threads before installing?
Old 08-12-2016, 08:34 PM   #103
humfrz
You couldn't find that everyone here puts their pants on one leg at a time ......
I never have used anti-seize on spark plugs and I've never had a plug I couldn't get out.
Besides, that stuff messes with my built in, calibrated wrist, "spark plug tight" bio-sensor.
humfrz
Old 08-13-2016, 10:43 AM   #104
Black Tire
Black Tire's Avatar
humfrz
Here in the land of winter and road salt, I tend to use anti-seize on a lot of fasteners and threads, and especially on lug nuts. I will be using anti-seize when I install my new spark plugs within a month or two.
Old 08-13-2016, 02:58 PM   #105
humfrz
I have read that some manufactures of some spark plugs (usually the nickel coated ones), recommend NOT using anti-seize ........
You may wish to look into that and take that under consideration.
humfrz
Black Tire (08-13-2016)
Old 08-13-2016, 08:18 PM   #106
Urmyson
Those plugs don't look to bad for 100k, could you tell any difference after the change?
Urmyson is offline   Reply With Quote
Old 08-14-2016, 11:41 AM   #107
BRZnut
Drives: BRZ DGM Limited
would be interesting to see a pic of the tip of the old next to the new plugs. But as stated above, for 100K they don't look too bad.
Old 08-14-2016, 08:58 PM   #108
seant2h
Here you go...
The Following 2 Users Say Thank You to seant2h For This Useful Post:
hmong337 (11-19-2016), Teseo (08-14-2016)
Old 08-14-2016, 09:19 PM   #109
seant2h
When I changed the plugs I also switched back to the OEM header & tune, cleaned the K&N air filter and did an oil change so it's not Apples to apples. That said, my car is running great after all of that work.
Old 08-21-2016, 03:38 PM   #110
DJCarbine
Thupercharged
DJCarbine's Avatar
Just did mine, an hour and a half. Passenger side remove ECU driver. Driver side remove fuel line plastic clip (3 lines) and injector cover. Didn't need anything special, just a 14mm deep well, 3" 3/8 drive extension.
They key is not to push any of the socket stuff together enough for them to clip together with the ball detent. Just put the 14mm deep well on the plug, loosely insert the extension, and get the end of the extension with the ratchet. Don't let any of the pieces click together, you only need to turn it enough to break loose the plugs. Once the plug is broken loose, I used some fuel hose to remove them.
Slightly harder than my WRX, but same basic principle. And the coil harness plug/clips are easier on the FRS.
2013 FRS
Vortech V3 11psi
The Following 3 Users Say Thank You to DJCarbine For This Useful Post:
ddevl_86 (02-26-2021), gravitylover (08-21-2016), Muaddib (09-09-2017)
Old 08-22-2016, 07:14 PM   #111
Gen3MR2
Gen3MR2's Avatar
Drives: 93 MR2 gen3 3sgte, 13 FR-S
Great write up.
I just did mine like this and it took me 3 hours total. I was working slow also.
I used a 3/8" drive deepwell 9/16" socket attached to a 3/8" drive reduced to 1/4" drive to a short 1/4" extension to a 1/4" drive ratchet. This seemed to be the best. I tried 3/8" tools and couldn't fit them in there.
I had the reducer clipped onto the socket and inserted it, then I clipped the extension on with the ratchet. Used a screw driver to remove the extension from the ratchet and the extension from the reducer since I can't grab both at the same time.
Instagram @gen3mr2
Gen3MR2 is offline   Reply With Quote
The Following User Says Thank You to Gen3MR2 For This Useful Post:
Old 10-10-2016, 12:35 PM   #112
D K
Stig's dark passenger
Originally Posted by stevesnj View Post
This is just crazy to replace spark plugs. This is probably the biggest downfall of the boxer design.
I can think of MANY others
D K is offline   Reply With Quote
The Following 2 Users Say Thank You to D K For This Useful Post:
juliog (10-10-2016), SkAsphalt (03-20-2017)
Spark plugs for turbo whitefrs Forced Induction 88 05-05-2018 09:18 PM
boosted spark plugs? 350matt Forced Induction 9 08-09-2014 03:54 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
