Old 08-07-2015, 08:52 PM   #99
HachiEnam
UCSB!!!
HachiEnam's Avatar
Drives: 2017 GTI sport
Hey I'm having some difficulty getting the pin out. Does anyone have any tips? Also im pushing the pin from left to right correct? so the the pliers are on the opposite side of the e clip?
HachiEnam is offline   Reply With Quote
Old 08-07-2015, 10:20 PM   #100
mb_
Ex-MR2 owner
Drives: Scion FRS
I used a pick/pocket screw driver to get the pin out on mine
mb_ is offline   Reply With Quote
Old 08-08-2015, 05:48 AM   #101
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Zendeta View Post
I used a flathead, anger, and a hammer to get it out. Best decision of my life, although the wobble is kind of annoying it doesn't make a big deal honestly.
Yup, brute force and ignorance is how I got mine out.
Old 08-10-2015, 04:36 PM   #102
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Did this mod now my girlfriend says she can't drive my car, clutch too stiff...
headlikeahole is offline   Reply With Quote
Old 08-12-2015, 01:36 PM   #103
lextrueno
lextrueno's Avatar
Drives: 2013 Firestorm Frs
I'm planning on doing this when I get home. When I first drove the FRS I thought the clutch was insanely light.... Either I haven't been skipping leg day, or the cars I used to drive had heavy clutches. I'm thinking its the first one XD BUT SERIOUSLY, OEM CLUTCH FEEL IS SO BAD. Thanks for the write up, looks like the mod is an overall success and I will like it before I have even done the mod XD
lextrueno is offline   Reply With Quote
Old 08-13-2015, 09:20 PM   #104
Richyjc
Richyjc's Avatar
Drives: brz
Thanks! I just did this as well. Taking it off took no more than 10 mins by following your write up. However, putting back the pieces onto the pedal without the spring took forever and ended up losing the E clip. I'll buy another Clip if the pin ends up sliding out.
Richyjc is offline   Reply With Quote
Old 08-13-2015, 10:10 PM   #105
Ultramaroon
not playing cards
Ultramaroon's Avatar
It will. Not to be an alarmist but it's this kind of scenario which ends in disaster. A set of parts half fall apart and jam. Just put the removable parts on the shelf with the spring. Not necessary to reinstall.
Old 08-13-2015, 10:17 PM   #106
PNW FRS
PNW FRS's Avatar
Thanks for the detailed instructions ..... although, I'll never do it ..... my old left leg needs all the help it can get ...humfrz
Everyone once in awhile.. whether in Portland OR or Seattle WA... I'll get stuck in some bad stop and go traffic.... and I'm thankful for that little spring!!
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 08-14-2015, 01:05 AM   #107
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
Glad i saw this, just ran out in the dark and did this. Took all of 4 minutes and 2 of that was trying to get the damn clip back in.
To people having issues getting the pin out, after the clip is removed tap the pin a couple times with the needle nose then pull the pin out from the back instead of trying to push it through.
To get the spring perch off easier press in the clutch pedal and just hold the spring perch toward the firewall with pliers or screwdriver and let the pedal come back. Watch out for flying parts.
Can't wait to drive it tomorrow, this clutch has bugged me since day 1.
Kotu100 is offline   Reply With Quote
Old 08-14-2015, 10:03 AM   #108
lextrueno
lextrueno's Avatar
Had the mod in for 2 days now and the difference is night and day. Would definitely say that I was getting used to the old clutch, but this was such a much bigger improvement. All my shifts are smooth and accurate. This is a top notch mod, the hard part for me was getting the pin out of the clutch. I had to depress the clutch in and use some leverage from one of the metal bars before I could pull the pin out from the other side. Once that was done it was pretty straight forward and easy. Getting the E clip back on is kinda tricky. I put the clip entrance pointing up and used some needle nose pliers to squeeze the pin and clip together.
Old 08-14-2015, 07:52 PM   #109
Rabble
Drives: Asphalt FR-S
This was a total PITA but damn if it's not like a completely different car afterwards.
Sideways is a normal operating condition.
Rabble is offline   Reply With Quote
Old 08-17-2015, 10:56 AM   #110
HunterGreene
Hail Magnet
HunterGreene's Avatar
Took off the spring and left the other hardware in, took me a little longer than 15 minutes, but it was relatively easy. Totally feel the "slop" at the top, but its not too much to deal with. I am still a little worried about it sitting on the clutch spring alone, but the feel of the clutch is a bit more meaty and easy to read.
It has priests in it?
Old 08-18-2015, 10:26 PM   #111
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
Originally Posted by HunterGreene View Post
...I am still a little worried about it sitting on the clutch spring alone
Don't worry about it.
Clutches have been relying on the master cylinder to hold them up for the better part of a century at this point with no discernible ill effects.
Slysdexia is offline   Reply With Quote
Old 08-19-2015, 12:11 AM   #112
tracerit
Drives: '13 SSM BRZ Limited 6MT
What does it mean to go back to stock by using zip ties? I haven't tackled this yet, but I want to make sure it's completely reversible without looking tacky.
tracerit is offline   Reply With Quote
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 12:40 PM
Car dies after 15-20 minutes? PolishFrs13 Issues | Warranty | Recalls / TSB 28 10-08-2015 04:28 PM
Toyota 86 in 10 minutes. KKaWing FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 03-28-2013 09:06 PM
32 Hours 7 Minutes Wes B. Other Vehicles & General Automotive Discussions 11 12-26-2012 09:10 AM
How to hack a BMW and steal it in 3 minutes Dadhawk Other Vehicles & General Automotive Discussions 9 07-11-2012 12:11 PM
