02-27-2015, 10:22 PM | #99 |
No Money, No Problems
Sounds great though!
The Following User Says Thank You to LucidMomentum For This Useful Post: | Ernie L (02-27-2015) |
02-27-2015, 10:37 PM | #100 |
Now w/ over 400 womprats!
Drives: BRZ LZR
- The Ancient BRZ Sacrament by Zaku |
02-28-2015, 05:54 AM | #101 |
Drives: toyota mr2/ Toyota GT86
hello Jerry
looking at the pictures, are the IC core bleed screws on the back? in which case could you get away with just removing the intake rubber hose? or just loosen the intake pipe screws so you can wobble it out of the way? |
02-28-2015, 09:59 AM | #102 | |
Drives: 2014 BRZ black premium
I think that might just work...worth a try..You're a clever fellow for sure. You should write manuals for Cosworth...which in this day and age, why they don't have a you tube (or it's equivalent ) installation video posted is beyond me... I do not speak for them ,but I do believe I have some small insight as to why Rally Sport Direct did not post an instal video. This kind of instruction with no pictures had me scratching my head. "Disconnect the fuel fitting from the 3 pipes on the inner wing and plug with appropriately sized bolt or dowel to prevent fuel leaking whilst working." ...we have pipes on our cars?...and wings? .. two cultures separated by a common language ha ha ha..
♠♠♠88
The Following User Says Thank You to Ernie L For This Useful Post: | weederr33 (02-28-2015) |
02-28-2015, 11:51 AM | #103 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I'm quiet certain, your build thread has become the perfect DIY for any problems we may encounter!
02-28-2015, 02:44 PM | #104 | |
Drives: anything you let me
Is it possible that remark about interference was for the RHD models only? |
02-28-2015, 02:50 PM | #105 | |
Ugh, that's awful about the instruction order. You would think for the price tag and and name backing it (not to mention the fact that they are English so there is nothing to translate from say Japanese), the instructions would be very clear and concise. |
02-28-2015, 03:57 PM | #106 |
I'm sure that Cosworth are keeping an ey on this thread and will revise their data accordingly, Ernie is one of the 1st customers after all
03-01-2015, 01:21 PM | #107 |
350Matt your idea about just removing the elbow instead of the whole intake inorder to bleed the inter cooler was a no go. Good try though.
I took it for a test ride yesterday...Joy, dejection,joy, dejection...I'm emotionally whipped .....Upon take off there was a terrible off idle stumble..also at speed it breaks up under load unless I feather the throttle..came home found the brake booster hose barely hanging on.. Fixed it.. Joy ...took it for a ride...a little better still breaking up under load...very light throttle under cruise is fine. I also have a check engine light. It flicker at me under acceleration. Dejection ...found that I had mis attached the purge valve plumbing..fixed it JOY ...took it for a ride..no change.. Dejection I will check for other hose related air leaks...hopefully its the rear PCV pipe...of course this requires I remove the intake cold air pipe..one more damn time.. I suspect an air leak....
♠♠♠88
03-01-2015, 03:07 PM | #108 |
Drives: '15 Halo FR-S
Damn, sorry to hear it isn't going as well as it could be! Looking forward to seeing the finished product though!
The Following User Says Thank You to Bergen23 For This Useful Post: | Ernie L (03-01-2015) |
03-01-2015, 04:47 PM | #109 |
Hello Ernie
with the ECUtek kit you can read off any fault codes so it would be well worth plugging it in and using the DTC tool to see whats logged it does sound like an airleak to me though, so any any air pulled in after the MAF meter will not be 'seen' by the meter and lean the engine out |
The Following User Says Thank You to 350matt For This Useful Post: | Ernie L (03-01-2015) |
03-01-2015, 05:56 PM | #110 | |
♠♠♠88
03-02-2015, 08:04 AM | #111 |
Hello Ernie
I had something similar on mine when I fooled around on the intake check the big square connector at the back of the engine bay on the LHS, disconnect it and plug it back in in again and check the connectors to the lower / exh VVT actuator on the LHS also you mentioned earlier about disconnecting all sorts when fitting it all, if the ignition was on at any time during this process, then you'll have created a fault and need to clear theses faults using the same DTC tool |
The Following User Says Thank You to 350matt For This Useful Post: | Ernie L (03-02-2015) |
03-02-2015, 10:40 AM | #112 | |
♠♠♠88
Similar Threads | ||||
Stage 1.1 Cosworth FRS | FR-S89 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 12-22-2014 01:23 PM |
Cosworth Stage 2 | v86 | Software Tuning | 2 | 11-05-2014 07:47 PM |
Cosworth BRZ/GT86 | Vyk | Mid-Atlantic | 2 | 05-25-2014 01:49 AM |
