Old 06-19-2015, 09:44 AM   #99
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by drambo136 View Post
Lol funny story. There was a cop walking by my car the other day and he actually got down to smell my tail pipe. He them processed to tell me their is something wrong with my car lol.
Sent from my SAMSUNG-SM-N900A using Tapatalk
It actually smells that different huh..
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 06-19-2015, 11:15 AM   #100
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
If you've ever cooked with corn oil, I've been told it smells like that.
Are flex fuel kits really that easy? I thought it was along the difficulty of a new fuel system.
Rybot is offline   Reply With Quote
Old 06-19-2015, 11:22 AM   #101
yomny
yomny's Avatar
No, in my opinion its somewhat simpler its little device that analyzes the ethanol content and some lines coming from there connected inline with the main fuel line in your engine bay, something like that. Then you connect the digital display inside the car, like any other gauge, some wires and soldering.
Old 06-19-2015, 11:45 AM   #102
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
So easy! Disconnect a couple lines, plug it in, and just connect the wiring to the ecu. Other than that u just need a reflash
drambo136 is offline   Reply With Quote
Old 06-19-2015, 12:04 PM   #103
Rybot
Rybot's Avatar
That doesn't sound near as bad as I originally thought.
Are there any good mounting spots for the ethanol gauge?
Old 06-19-2015, 12:05 PM   #104
Rybot
Rybot's Avatar
You mean reflash the ecu with an e85 tune?
Old 06-19-2015, 12:12 PM   #105
yomny
yomny's Avatar
It could get confusing, some use the evap solenoid to receive the ethanol content and send signal to the ECU and some tap into the ECU directly to tell it how much ethanol it has and to adjust accordingly(aside the e85 flexfuel flash of course). Check out moto-east website's, he has some explanations and you could see the different options. Its just to give you options because some people use the evap solenoid for a boost controller so can't use that method and could only tap into the ecu itself.. I'm not 100% sure of all this stuff as I haven't done it but I've read about it. Please anyone correct me if im wrong.
Old 06-19-2015, 12:38 PM   #106
drambo136
drambo136's Avatar
The ecu tap one with the harness is so easy and I mounted the display between the gauge cluster and the radio. And yes a reflash for having the flex fuel kit
Old 06-19-2015, 02:14 PM   #107
Rybot
Rybot's Avatar
How did the mounting go?
Old 06-19-2015, 02:17 PM   #108
Rybot
Rybot's Avatar
You plan to do the system soon?
Old 06-19-2015, 02:25 PM   #109
xxscaxx
Drives: 2013 SWP BRZ
They offer kits now that use the o2 sensor and is plug and play so you don't have to splice into the ECU harness... either will work but its a bit of a PITA to get to the ecu and you have to cut a wire in the process. If they offered the o2 sensor hookup when I bought mine I definitely would have opted for that. Moto-Mikes and Delicious are all completely plug and play, even all the fuel lines as well, using the fuel line connectors and not worm drive clamps.
xxscaxx is offline   Reply With Quote
Old 06-19-2015, 02:27 PM   #110
Rybot
Rybot's Avatar
I'll have to check those out.
Old 06-19-2015, 02:31 PM   #111
drambo136
drambo136's Avatar
I just used 3m tape.
http://s336.photobucket.com/user/dra...93034.mp4.html
The Following User Says Thank You to drambo136 For This Useful Post:
Rybot (06-19-2015)
Old 06-19-2015, 02:45 PM   #112
Rybot
Rybot's Avatar
My phone doesn't like photo bucket, so I'll take a look when I get to my computer.
Thanks though!
RS*R Sports-i coilovers - install & review ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 07-27-2022 06:29 PM
Powerhouse Amuse Single Exit Exhaust + R1000 FP Review BrianJC Engine, Exhaust, Transmission 26 06-06-2016 10:09 PM
My OEM Audio Plus 400 Install and Review Yruyur Electronics | Audio | NAV | Infotainment 156 03-01-2016 05:53 PM
TRD Sharkfin Install and review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 27 07-19-2014 07:21 PM
REVIEW: Berk Technology Single Exit Track Pipe w/ Tip NYC BRZ Engine, Exhaust, Transmission 11 12-29-2012 08:22 PM
