Old 12-17-2014, 12:39 AM   #99
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Don't kill his dream. Steer into the skid you magnificent lunatic!
Old 12-17-2014, 12:39 AM   #100
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by themadscientist View Post
GM put a flat six in the back of a car once. And?
fify
Old 12-17-2014, 12:43 AM   #101
themadscientist
Hotlink Terrorist
Dammit, you're right; I had Subaru on the brain and forgot it was a six. CURSES!
Old 12-17-2014, 12:43 AM   #102
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Strumming my pain with his knowledge
Stinging my life with his words
Killing my brain cells with his wrong
Telling my whole car with his words
I read he sang a bad song
I heard he had a style
But not in a good way
To chuckle for a while
And there was this weird forum post
Total weirdness to my eyes
[ame="https://www.youtube.com/watch?v=dpNdMIAnKko"]Roberta Flack - Killing Me Softly With His Song - YouTube[/ame]
Apologies to Charles Fox and Norman Gimbel
Old 12-17-2014, 12:53 AM   #103
Ultramaroon
not playing cards
At least! Now what about the rest of us?
Old 12-17-2014, 12:57 AM   #104
Captain Snooze
Drives: Red Herring
lol
Old 12-17-2014, 01:35 AM   #105
Ultramaroon
not playing cards
Well played. Excellent recovery.
Old 12-17-2014, 10:53 AM   #106
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by KoolBRZ View Post
Calm down. My car is aligned. The way the car is designed, it will toe the outside wheel out and the inside wheel in when it leans over. It doesn't mean you can parallel park the car sideways. I'm only mentioning it because I'm not used to my car leaning in the corners. I'm changing to the stiffer FR-S springs this weekend anyway.
Please go into more mechanical detail on why you think this.
Either
A. The suspension doesn't work the way you think it does
B.You have the terminology mixed up.
Just trying to help people understand.
Old 12-17-2014, 12:34 PM   #107
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
Sounds to me that we may be talking about bump steer
TheVoiceOfReason is offline   Reply With Quote
Old 12-17-2014, 12:52 PM   #108
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
-Jack Burton
Old 12-17-2014, 01:00 PM   #109
KoolBRZ
KoolBRZ's Avatar
Either
I'll go with (B.). I just know what it does. I don't know what it's called. I just know that the rear wheels toe out on compression, and toe in on extension. The tracking link goes through an arc when the wheel is compressed or extended. At the bottom of the arc, when the suspension is extended, it pushes on the wheel. At the top of the arc, when the suspension is compressed, it pulls on the wheel. When I'm taking off the struts this weekend, and I'll see if I can get some pics of the suspension compressed and extended.
So, what I believe so far, if you want a softer ride and you have a BRZ with stock suspension, install stock FR-S suspension instead and slightly taller tires, (225/45/17), and if you have an FR-S with stock suspension, and you want a softer ride, just get slightly taller tires.
Old 12-17-2014, 01:29 PM   #110
Racecomp Engineering
First, lets call it bumpsteer.
Second, lets read the MotoIQ article that you linked to:
http://www.motoiq.com/MagazineArticl...cion-fr-s.aspx
"The rear suspension is very similar to the GE Subaru Impreza, being a somewhat unremarkable multilink. The suspension has toe in under roll, a moderate amount of camber gain under roll and a bit of anti squat in the geometry."
Like many cars, the rear of the car toes in under compression.
Third, this has nothing to do with ride quality and nothing to do with the handling difference between FR-S and BRZ since geometry is the same. The difference is the spring rates, which are mildly stiffer in the rear and mildly softer in the front for the FR-S. Both are bumpstop active at the front and rear.
Both cars ride and handle pretty well stock IMO. The difference in ride between the two is negligible. The difference in handling is subtle, but noticeable.
If you want to improve ride for cheap, Bilstein B6 HDs and the right tire would be a good choice for smoothing out larger bumps. If you really want to, you could custom valve the Bilsteins for a little extra.
- Andy
Old 12-17-2014, 02:03 PM   #111
redlined600
Drives: Fr-s
I'll go with (B.). I just know what it does. At the bottom of the arc, when the suspension is extended, it pushes on the wheel. At the top of the arc, when the suspension is compressed, it pulls on the wheel.
So you have toe in and toe out confused. That's part of the reason people are giving you such a hard time.
Toe in = front of wheel points toward center of car
Toe out = front of wheel points out from center of car
In the rear, toe in generally makes the car more stable. Toe out generally makes it less stable.
Also this is not really active steering as the amount toe change is small.
Old 12-18-2014, 07:42 PM   #112
Panman
Panman's Avatar
Drives: 86 GTS
- Andy
QFT - I have the B6 with Invos for Daily on 17x8 and love them.
Panman is offline   Reply With Quote
Well this sucks. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-16-2014 10:18 PM
Getting OLD kinda sucks... blackhawkdown Off-Topic Lounge [WARNING: NO POLITICS] 44 06-13-2014 10:41 AM
Elitism..sucks RedLeader Other Vehicles & General Automotive Discussions 60 01-29-2014 04:09 PM
NY sucks Hardrock4445 Off-Topic Lounge [WARNING: NO POLITICS] 35 01-18-2013 09:28 AM
