Old 07-15-2014, 04:17 PM   #99
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by Boofneenee View Post
Why is it bad to go WOT at 2k?
Others can speak more fluently/accurately to this, but it's basically that the motor is lugging at low rpm and if you go WOT at low rpm, it puts a lot of strain on the motor.
Such a thing is VERY noticeable if you would go WOT at, say 700 or 1000 rpm. Not as noticeable at 2000 or 2500, but it's still there.
If you went WOT at very low rpm on a carburated small bore dirt bike (for example), you might even stall the motor because you created a very rich condition. I assume that the computer and injectors on a fuel injected vehicle attempt to compensate for the condition - which I assume is what fenton meant when he said that:
"Your car is freaking out and setting the engine load to 5(max) and also setting ignition timing to 0."
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
The Following User Says Thank You to robwbright For This Useful Post:
Boofneenee (07-15-2014)
Old 07-15-2014, 04:17 PM   #100
Malt
Drives: 2015 WRX
Originally Posted by robwbright View Post
I don't have it in hooked up and in front of me, but if I recall how I found it, there's a selection titled "Info" that you can push which shows which ROM is installed in the car. Has to be hooked up to the car.
IIRC the only notification that the OFT gives is which slot was loaded (marked with an asterisk) not which map was loaded. So if you had a map loaded in slot 3 and flashed that, then moved the maps around when loading new maps on the device, it would still show that you had slot 3 flashed, even if you had moved a new map into that slot.
This information is a few months old however, so not sure if they have changed things since then.
Malt is offline   Reply With Quote
Old 07-15-2014, 04:22 PM   #101
robwbright
I just hooked it up and turned on the ignition. Clicked on "Information" which is the bottom right selection after the OFT loads. The next screen specifically says which file is loaded into the ECU.
2006 Saab 9-3 2.0t
raven1231 (07-15-2014)
Old 07-15-2014, 05:12 PM   #102
raven1231
Thank you! I knew I wasn't crazy
Old 07-16-2014, 07:30 AM   #103
reignerabellera
Drives: GTX 86 2014
hello guys, im also interested in this one, ive read some threads and i like this combo, anyone can help me here to buy a combo like this, OFT+phantom ESC. I live in Dubai UAE. I really like this upgrade cant afford FI.
reignerabellera is offline   Reply With Quote
Old 07-16-2014, 07:46 AM   #104
raven1231
Wish we could buddy. Unfortunately at the moment demand has completely overcome the supply of the ESC units. Rob is working as fast as he can to get these out as soon as possible. I believe the next batch is supposed to hopefully be done next month sometime. If you're interested the best thing to do would to pm rob and ask for your name to be added to the list. That being said, I'm not sure if he's willing to ship to Dubai yet, but I'm pretty sure a few kits went to Australia so he might
Old 07-16-2014, 12:54 PM   #105
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
FYI, Our shop car is running E85 as I type
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (07-16-2014), jflogerzi (07-16-2014), raven1231 (07-17-2014), Sojhinn (07-16-2014), WRB5titch (07-16-2014)
Old 07-16-2014, 12:54 PM   #106
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Hell yes!
Installed Mods:
Old 07-16-2014, 12:56 PM   #107
Sojhinn
Sojhinn's Avatar
*cough* do you need a tester *cough*
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (07-16-2014), neutron256 (07-16-2014)
Old 07-16-2014, 09:01 PM   #108
Sojhinn
Sojhinn's Avatar
Heres another log for the 2.0 tune. Third gear pulls.
http://www.datazap.me/u/sojhinn/15-2...og=0&data=8-12
Installed Mods:
Old 07-17-2014, 12:11 AM   #109
Sojhinn
Sojhinn's Avatar
@Shiv@Openflash
Is there any power difference in this new e85 tune vs my old one? Are you willing to share the dynos?
Thanks bud!
Installed Mods:
Old 07-17-2014, 12:31 AM   #110
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Sojhinn View Post
@Shiv@Openflash
Thanks bud!
I'm on the dyno right now finishing up the E85 OTS tune. The mapping is quit a bit different from your old tune. Much more refined much like comparing v2.0 OTS map to older v1.4 maps. Better fueling, more top end power/less roll off. started off with a tune nearly identical to your old tune and put down a decent 215whp. With the revisions, I'm at ~225whp now and still tuning. Holds peak power from 6500rpm to 7500rpm which is quite nice. No top end roll-off.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (07-17-2014), WRB5titch (07-17-2014)
Old 07-17-2014, 12:33 AM   #111
Sojhinn
Sojhinn's Avatar
Nice! I remember you were getting frustrated by that roll off when you were tuning my car last year. Sounds exciting. I can't wait to play with it!
Installed Mods:
Old 07-17-2014, 12:43 AM   #112
jflogerzi
jflogerzi's Avatar
230 WHP? What about TQ?
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 02:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 01:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 09:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 02:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-03-2012 12:18 AM
