Old 05-09-2014, 08:58 PM   #99
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Big Problem
Try reflashing the ecu?
Installed Mods:
Sojhinn is offline
Old 05-09-2014, 09:04 PM   #100
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by jpit View Post
I hooked up a diagnostic program and it's showing a code B1016, Shift Lock Circuit. Anybody know what this circuit does?
Its different for every car manufacturer, is that the specific code for this car?
In some cars its "Loss of Communications with PCM", in others its detecting a fault in the defrost system
I'm surprised the dealership didn't do at least a code check... if they had a specific fault not related to the ESC or anything directly related to it they would need to fix it.
What diagnostic program did you use?
Anything electrical related, the dealership can probably deny the warranty claim due to the use of the alternator to charge extra batteries/third party equipment that puts extra strain on the charging system.... if anything happened (short etc.) and damaged the alternator, its entirely possible for it to send noisy AC power and mess up sensitive electronics. I think they would have a reasonable ground to stand on.... but did they at least check for codes?
2013 FRS
Vortech V3 11psi
DJCarbine is offline
Old 05-09-2014, 09:10 PM   #101
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
Originally Posted by Target70 View Post
some of us would rather spend 30 minutes instead of 8 hours removing our turbo kit to take it to the dealer for warranty work.
also 185 tq at 2.5k rpm for 1/2 to 1/3rd price of conventional turbo.
Why didn't you have it towed home to spend the 30 min to remove it then
Gilwith1l is offline
The Following User Says Thank You to Gilwith1l For This Useful Post:
Boofneenee (05-09-2014)
Old 05-09-2014, 09:12 PM   #102
raven1231
Because target isn't the op? As to why the op didn't...who knows
raven1231 is offline
Target70 (05-09-2014)
Old 05-09-2014, 09:12 PM   #103
Sojhinn
Sojhinn's Avatar
Op has already admitted it was a mistake. Let's move on guys.
Installed Mods:
Sojhinn is offline
Old 05-09-2014, 09:14 PM   #104
Gilwith1l
Gilwith1l's Avatar
Put car back to stock have dealer figure it out for free. Too late for that though
Old 05-09-2014, 10:53 PM   #105
jpit
Drives: Subaru BRZ
ECU was reflashed but the car still won't start. I used the Toyota diagnostic program.
It also showed code C1237 also which is a Speed Sensor Rotor Fault. I should have called my own insurance company and had them tow it to my house. Instead I used Subaru Roadside Protection and they would only take it to the dealer. Also with the dual dump system it is a little more complicated to get back to stock.
jpit is offline
Old 05-09-2014, 11:13 PM   #106
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
jesus. I pray for the phantom charger boys. this sounds a bit hairy this far. Keep at it man, I just hope/pray its something silly
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline
Old 05-09-2014, 11:17 PM   #107
Urmyson
Any chance you can put it back to stock and try another dealership?
Urmyson is offline
Old 05-09-2014, 11:25 PM   #108
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
hmmm.. I dunno, if they red flagged it that car should pop up at any scion dealership but I could be wrong
FRS
Old 05-09-2014, 11:38 PM   #109
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
Yeah maybe if they didn't bother to update anything in the system? Try calling another dealer and give them your Vin and see what they say?
I wish we could all be more helpful... It's gotta be something electrical though.
jebuwh is offline
Old 05-10-2014, 12:17 AM   #110
Sojhinn
Sojhinn's Avatar
Big Problem
Jpit did you have a car wash on the car recently?
Also is the diagnostic tool giving you these code names? Only reason I ask is for the scion tc the c1237 deals with voltage.
Installed Mods:
Sojhinn is offline
Old 05-10-2014, 12:32 AM   #111
Sojhinn
Sojhinn's Avatar
Good information http://www.ft86club.com/forums/showthread.php?t=26737
Installed Mods:
Sojhinn is offline
Old 05-10-2014, 12:34 AM   #112
Sojhinn
Sojhinn's Avatar
Big Problem
Possible fix http://www.ft86club.com/forums/showthread.php?t=24246
Installed Mods:
Sojhinn is offline
First problem with the STX Brz Simmons Tracking / Autocross / HPDE / Drifting 94 06-23-2014 01:05 AM
Problem with car Atticus808 Other Vehicles & General Automotive Discussions 1 02-20-2014 12:14 AM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 08:07 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 05:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 11:17 AM
