Old 04-24-2015, 10:58 AM   #99
Zhangy
Drives: 2015 FRS
Originally Posted by HunterGreene View Post
Your butt dyno must be amaaaaazing. Ever heard of the "placebo effect," brah?
You do realize weight of spare is the same as weight adjustment performed during typical corner balancing with only 20-25lb adjustments. Exaplen: http://www.ft86club.com/forums/showthread.php?t=22083 Now you are actually removing the weights.
The weight of spare is also equivalent to 1/2 tank of fuel. And the difference that you can feel or no?
Zhangy is offline   Reply With Quote
The Following User Says Thank You to Zhangy For This Useful Post:
Mr.Impreza (07-30-2015)
Old 04-24-2015, 11:00 AM   #100
Zhangy
Drives: 2015 FRS
The noticeable difference of adding 20 gallons of gas to these cars would indeed be huge!
- Very irate gas station attendant for pouring 7 gallons of gas on his lot
- Possible Fire Department response
- MOE fine for environmental impact if gas flows off the pavement
- Gas from the huge pool splashing up under your car as you drive away could catch fire
- Your car would smell like crap for at least an hour or two
You do realize weight of spare is the same as weight adjustment performed during typical corner balancing with only 20-25lb adjustments. Example here: http://www.ft86club.com/forums/showthread.php?t=22083 now you are actually removing the weights.
Old 04-24-2015, 11:04 AM   #101
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by Zhangy View Post
You do realize weight of spare is the same as weight adjustment performed during typical corner balancing with only 20-25lb adjustments. As seen:
You're speaking to a totally different experience (racing, I think) than the normal DD experience most everyone else who drives this car has. Is a 25 lbs weight difference (if its even that much) that much more noticeable to me? No. Am I going to be that anal about my car? F*ck no, I'm going to enjoy it as it is and not make relatively tiny adjustments just so I can think it feels better without any objective proof of major benefit. I'm just not that hardcore, sorry.
But hey, whatever helps you sleep at night, dude.
It has priests in it?
Old 04-24-2015, 11:10 AM   #102
Zhangy
Drives: 2015 FRS
well it's 30lb of wheel and 30lb of fuel removed. there is a change, at least that's the case with 2015 stock. ima putting back the spare cuz the car becomes floppy low fuel
Old 04-24-2015, 11:26 AM   #103
D.Scrye
D.Scrye's Avatar
Drives: Hot Lava FR-S
I've already gotten one flat on I395 right before a road trip, if the nail hadn't mostly plugged the hole it would have had me stuck somewhere in the district waiting for a tow truck to headbutt its way through traffic, should I have taken out the spare. There is always construction around here generating road debris.
Why not?
D.Scrye is offline   Reply With Quote
Old 04-24-2015, 01:24 PM   #104
HunterGreene
Hail Magnet
20 lbs, 30 lbs, please be consistent if you are going to claim that amazing amount of difference that nobody else apparently can feel.
Old 04-24-2015, 06:56 PM   #105
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
[ame="https://www.youtube.com/watch?v=e5lHdZ8gF6E"]Make Your Car Faster For Free - YouTube[/ame]
Chad86 is offline   Reply With Quote
Old 04-24-2015, 08:34 PM   #106
Zhangy
Drives: 2015 FRS
There is indeed a difference with 50lb-60lb of weight removed comparable to what you 'should' experience with an empty tank vs full tank.
Old 04-24-2015, 10:24 PM   #107
You do realize that the 20 gallons of gas you put in your tank is 7 gallons more than it hold right?
You can't even get a basic spec right but you expect us to believe everything else. Grow up dude and come back with real facts not your teenage daydreams.
HunterGreene (04-27-2015)
Old 04-24-2015, 11:34 PM   #108
Zhangy
Drives: 2015 FRS
Obviously it's just a typo as specified in the edit history.
You know the 40liter/30lb difference you feel driving near empty tank vs full tank or not?
if yes, what I'm describing is the drive feeling you get from further 30lb deduction.
if no, maybe lose some weight
Old 04-25-2015, 12:01 AM   #109
No I do not notice any difference when dding. And what would my weight have to do with anything? It remains the same with a full or empty tank.
I am sure that with your obvious extensive track time and advanced skill from many years of driving race cars you can tell the difference though.
Old 04-25-2015, 12:50 AM   #110
Zhangy
Drives: 2015 FRS
Because your fat could potentially damp the underdamped motion. Yeah I agree corner balancing is pointless since no effect will ever be felt by shifting weights 20-50lb or so. Save the 300 bucks for something else.
Old 04-25-2015, 01:00 AM   #111
Why do you think I have fat?
And again how would my constant weight work into your theory?
If balanced to my weight then it does not matter if 100 or 500 pounds.
Old 04-25-2015, 01:37 PM   #112
Zhangy
Drives: 2015 FRS
low fuel with spare removed, the car does feel little bouncier... i've removed and tried.
10.5" wide tire possible?!? Xiao Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 10-11-2015 11:00 AM
"back-seat-remove" option. Z_Rocks Scion FR-S / Toyota 86 GT86 General Forum 53 06-25-2013 04:24 AM
Plus 0 tire sizing Brzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-30-2012 08:15 PM
Would you want a spare tire in your FR-S? iff2mastamatt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 120 01-12-2012 10:46 PM
NEW Bridgestone R10 Race DOT tire RRnold Other Vehicles & General Automotive Discussions 2 06-17-2011 05:58 PM
