Old 04-05-2014, 11:03 AM   #99
shif7i7down
Erected Member
Drives: frs
Idk how accurate this is but. I believe that wot at anything below 2krpm puts alot of strain on your motor and shouldn't be recommended.
I only do pulls from a minimum on 2.5krpm
Edit: wot @1.5k rpm in 1st gear is perfectly fine ��
shif7i7down is offline   Reply With Quote
The Following User Says Thank You to shif7i7down For This Useful Post:
Blu-by-U (04-05-2014)
Old 04-05-2014, 11:42 AM   #100
Kodename47
Kodename47's Avatar
Drives: UK GT86
I agree. It's not really normal driving conditions so why do it. You'd never be below 2.5k when you actually want to drive fast.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Old 05-04-2014, 04:50 PM   #101
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Update, don't remember which post it was, but I read that VD only reads above 90 percent something throttle position. Once I stripped my data file down to that parameter, I ended up with a 160 whp / 150 ftlbs. Where as I understand that this about correct. I'm still skeptical. These finds are still from original data logs which I have not yet had an opportunity to try any of the suggested pulls from earlier posts. Still learning and trying to catch up.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 05-04-2014, 05:18 PM   #102
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
150ft lbs is kinda high for stock car. What I've been doing is warm up the tires before logging and make several back to back pulls. Once I have that I upload it to Virtual dyno then I filter out all the pulls with any type of spiking in the the graphs. My results have been pretty consistent.
Here's one for bones stock vs, OFT stg1 tune on a bone stock car.
Old 05-04-2014, 08:46 PM   #103
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Are you using a complete data log or am I correct that I have to save a log with just the pull?
Old 05-04-2014, 09:18 PM   #104
solidONE
solidONE's Avatar
I take one log with multiple pulls, then I divide each pull into separate logs/files. So if I have 7 pulls in one log I'd divide it into 7 separate files with one pull in each file. IT's a bit tedious, but it beats paying $50 a pull at you local shop. lol
yes, I skate... I cheap skate. lol
The Following 2 Users Say Thank You to solidONE For This Useful Post:
Blu-by-U (05-05-2014), wparsons (05-04-2014)
Old 05-06-2014, 10:29 AM   #105
8686
8686's Avatar
Drives: 86
I am not able to select a car. Any idae what is the problem I have?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 05-06-2014, 11:11 AM   #106
wparsons
wparsons's Avatar
Have you created a new profile? You need to create a profile, then you can pick a car.
Every time you go to use the program you have to make sure you selected the right profile too.
flickr
Old 05-06-2014, 11:13 AM   #107
8686
8686's Avatar
Drives: 86
I created a profile and this the error message I am getting
************ Exception Text **************
System.Exception: E209: Object reference not set to an instance of an object.
at VirtualDyno.RunControl.cRunControl.Error(String ErrorNumber, Exception ex)
at VirtualDyno.RunControl.cRunControl.TreeView_NodeMo useDoubleClick(Object sender, TreeNodeMouseClickEventArgs e)
at System.Windows.Forms.TreeNodeMouseClickEventHandle r.Invoke(Object sender, TreeNodeMouseClickEventArgs e)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Old 05-06-2014, 11:15 AM   #108
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
If you go under the profile pulldown menu select add a profile and you should see a blank profile pop up. There is Car pulldown menu to select the make and model.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 05-06-2014, 11:29 AM   #109
8686
8686's Avatar
Drives: 86
I dont get that list to select from
Old 05-06-2014, 08:52 PM   #110
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
is there a way to change virtual dyno to read below 90% throttle? my throttle tapers off to 89% by redline and thus won't show top end numbers...
edit: just changed the throttle values in my logs to above 90%. problem solved
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 05-06-2014, 09:53 PM   #111
Apoc
Apoc's Avatar
I think you may be missing the app data. I can't remember if there was a way to update but if you are registered and online it should update automatically I think. Worst case is you go into car editor and create your car. I had to do that when I started using it in 2012 because FR-S wasn't in their data.
“The World is Flat”
[||•]=(86)=[•||]
The Following User Says Thank You to Apoc For This Useful Post:
8686 (05-06-2014)
Old 05-06-2014, 10:13 PM   #112
wparsons
wparsons's Avatar
This has already been covered in the thread, but it's not an issue below 90%... the app assumes if the TP drops more than ~5% from the peak value it's no longer at WOT. I've messaged the guy that wrote it about this, but the easy solution is to just increase the TP values to be within 5% of the peak (I normally just set them all to 100).
flickr
Data Logs! Post them here. feldy Software Tuning 2161 12-24-2025 01:17 AM
Anyone help interpreting data logs? cuddefred Engine, Exhaust, Transmission 8 10-11-2013 07:30 PM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
