Old 02-07-2014, 02:17 PM   #99
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by jamesm View Post
more like 250lbs... but yeah. the na's were around 500lbs lighter. the point is a lot of people think 'it's light... it doesn't need much power' when in reality these cars aren't all that light, and don't respond the way other 'lightweight' cars do.
Ok 250 isn't that much of a difference, but I agree. They aren't terribly light. I mean my 05 sti was ~3300 pounds...thats a 500 poundish difference and it was a sedan/awd econobox lol. Guess you aren't going to get much lighter nowadays.
xxscaxx is offline   Reply With Quote
Old 02-07-2014, 02:33 PM   #100
jamesm
damn feds and their regulations. i mean seriously, who needs airbags? learn to drive and you won't crash!
The Following 3 Users Say Thank You to jamesm For This Useful Post:
Luckrider (02-07-2014), SmsAlSuwaidi (02-07-2014), xxscaxx (02-07-2014)
Old 02-07-2014, 02:50 PM   #101
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
And super strong support beams (although that does make the chassis stiffer).
In all seriousness, there are lazy people nanny systems in many new cars that make people lazy and complacent. This may make things safer in the short run, but in the long run, it makes people more dangerous drivers.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
jamesm (02-07-2014)
Old 02-07-2014, 03:09 PM   #102
jamesm
shortsighted regulation causing unintended consequences in the long-term? no way... it can't be
The Following User Says Thank You to jamesm For This Useful Post:
enwave (02-07-2014)
Old 02-07-2014, 09:52 PM   #103
DriftEm
DriftEm's Avatar
is slower.
I guess it depends on what gen miata, the early Miata was around 2000 lbs, so with 225whp is better power/weight ratio than our cars with 250 whp, if you talking about the latest Miata, then I'm surprise since they are only around 200 lbs lighter.
DriftEm is offline   Reply With Quote
Old 02-07-2014, 10:23 PM   #104
jamesm
i've had na's and nb's. the na's were all turbo.. one nb had an ls1 and the other was the stock turbocharged mazdaspeed one. all but the last one were faster lol.
Old 02-08-2014, 11:34 AM   #105
LBC Por Siempre
LBC Por Siempre's Avatar
Drives: 2008 Toyota Prius, 2012 911 Turbo
Originally Posted by Dezoris View Post
I agree with you aside from peak power, just don't think it matters as much if you have to scale it back to meet goal 1 and 2. It's true we could probably argue the merits of lap over lap logging but the truth is you can easily find the upper limits of stability this way better than any other testing, namely for testing heat issues. If it passes there, you should never have issues with street able performance. (on the 86 platform) The same is not true in reverse.
I had a PM with Mike about this. Two schools of thought, go out and beat the car 10/10ths or just run more laps at 80-90%.
Proving a tune, or durability does not mean the car has to be run 10/10ths at the track for valuable data collection. You have been playing with tuning now you get the concepts if you were going to do tuning for somewhat what data collection would you prefer?
Exactly, you need to "run up". You're not Phil Hill who can go 11/10 right out of the paddock. It's better to take your time to warm up the bits on a properly outfitted and looked after car.
A really big issue with people who drive in weekend driving events at tracks is to remove your "COOLANT" and for some events it is a requirement. Just plain water, distilled if possible, and some "WATER WETTER".
You don't want to pop your radiator hose on a weekend track day because it makes the track more slippy than oil. As a matter of fact it is a requirement to switch over from the coolant to water to avoid such a conundrum.
LBC Por Siempre is offline   Reply With Quote
Old 02-08-2014, 12:29 PM   #106
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
2014 Mazda Miata:
Code:
Curb weight (lbs)
Manual transmission               2511 lbs
Automatic transmission            2542 lbs
Weight distribution (front/rear)  52/48
Not to mention, all but the base model MX-5 Miata cost more than the FT86.
mwjcyber is offline   Reply With Quote
Old 02-08-2014, 12:36 PM   #107
jamesm
Originally Posted by mwjcyber View Post
2014 Mazda Miata:
Code:
Curb weight (lbs)
that's an nc... not what we're talking about here. grab the same numbers on an na .
the point is that the ft86 just doesn't respond the same. it's not just weight. the dimensions and gearing are probably just as important if not more so. at the end of the day, the ft86 just doesn't respond to power like i expected it to. people thinking that it will be fast with 250whp are in for some disappointment if they're expecting it to respond like a miata or mr2. it takes significantly more power to make an 86 do the same things.
Old 02-08-2014, 01:18 PM   #108
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
....or rip out the interior. That's an option too
On a side note...wonder what a project MR2 with a FA20 heart transplant would feel like around the track...
The Following User Says Thank You to cdrazic93 For This Useful Post:
jamesm (02-08-2014)
Old 02-08-2014, 01:18 PM   #109
mwjcyber
mwjcyber's Avatar
What are you smoking. Those numbers are from Mazda for 2014 Miata's, all which have the "MZR 2.0L DOHC 16-valve 4-cylinder engine with VVT" (167-hp 140 lb-ft ) na engine. Not only is the current Miata not light anymore, but it's engine is pretty pathetic.
http://www.mazdausa.com/MusaWeb/disp...ehicleCode=MX5
Old 02-08-2014, 01:21 PM   #110
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Um you're notcorrect "nc", and an idiot.
What are you smoking. Those numbers are from Mazda for 2014 Miata's, all which have the "MZR 2.0L DOHC 16-valve 4-cylinder engine with VVT" na engine.
I think he's talking about the body style there chief...
Take a look at the generations:
http://en.m.wikipedia.org/wiki/Mazda_MX-5
jamesm (02-08-2014)
Old 02-08-2014, 01:24 PM   #111
jamesm
guy makes himself look like an idiot in the process of trying to call someone else an idiot... oh the internet lol.
cdrazic93 (02-08-2014)
Old 02-08-2014, 01:30 PM   #112
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I will agree to this though. The miata needs to take a diet for how small it is. Seems like the Elise/exige are the only cars I know of that haven't gotten fat over the years.
Has anyone taken a closer look at the gas pedal? smbstyle Engine, Exhaust, Transmission 14 04-28-2017 02:59 PM
A closer look at the optional Aero kit BenArmstrong Cosmetic Modification (Interior/Exterior/Lighting) 11 07-17-2013 06:50 PM
A closer look at the Volk and Project Mu FR-S ShowstoppersUSA FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-16-2012 10:39 AM
HKS Supercharger getting closer gtauto AUSTRALIA 166 09-03-2012 07:11 PM
Speed hunters first drive and closer look reviews (with photos of modded blue TRD 86) Spaceywilly Scion FR-S / Toyota 86 GT86 General Forum 19 11-28-2011 10:41 PM
