02-03-2014, 01:46 PM | #99 |
Drives: UK GT86
After reading some other threads, is there a parameter to log whether the ECU is in open or closed loop operation? I've usually just worked it out from the fuel trims but an actual parameter would be useful. I've scoured the list but there's nothing obviously named.
.: Stealth 86 :.
02-03-2014, 02:20 PM | #100 | |
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
The Following User Says Thank You to nelsmar For This Useful Post: | Kodename47 (02-03-2014) |
02-03-2014, 02:21 PM | #101 | |
The Following User Says Thank You to jamesm For This Useful Post: | Kodename47 (02-03-2014) |
02-03-2014, 05:13 PM | #102 |
Drives: UK GT86
Cheers guys, I did wonder if that was the one. Is injection mode really worth watching? I just monitor PI and DI volumes, not that I'm really at a point when I need to though.
.: Stealth 86 :.
02-03-2014, 05:26 PM | #103 |
I typically log what i specifically need to get the highest resolution. There are times I have done injection mode but typically i go with PI/DI volume instead. For generic logging I don't use it so much and just do PI/DI volume.
02-03-2014, 05:48 PM | #104 |
Injection mode is necessary for tuning larger injectors. Can't get good data when you can't tell where the error is coming from.
02-09-2014, 04:30 AM | #105 |
Drives: BRZ Club blanc perle
I think we need an access to the Fine Learning Correction Table to monitor knock events.
RomRaider Learning View does it, but you need an extra cable... |
02-09-2014, 06:08 AM | #106 | |
Drives: UK GT86
You can log it, it's just not in a tabular view.
.: Stealth 86 :.
02-09-2014, 08:58 AM | #107 |
You just have the advance correction, not the moment the knock occurs... It is hardly usable...
You see the Advance Multiplier moving down, with no understandable link with the knock correction... |
02-09-2014, 09:20 AM | #108 | |
Eliminating all fine learning correction is huge, since you can't have repeatable, consistent performance with it present, even if it's only a -1. |
02-09-2014, 09:57 AM | #109 |
That's why such a table could be useful : you see at what load/RPM knocking occurs, and modify your advance table in consequence.
02-09-2014, 11:32 AM | #110 |
but it's applied in buckets. so the table only tells you generally where it is... i.e. between 0.6 and 0.9 load and between 4 and 6k rpm. by watching the actual log of the value being applied you can see exactly when it was written into the correction table and make more refined adjustments. you wouldnt want to go slashing timing out of an entire load/rpm range when really you only needed to pull from a single cell to solve the problem.
02-09-2014, 03:43 PM | #111 |
Drives: toyota mr2/ Toyota GT86
its when the advance multiplier switches
so if you modify the load site at the moment the multiplier switches from 1.0 to 0.7 for example |
02-09-2014, 03:49 PM | #112 |
but flkc doesn't always cause the advance multiplier to drop, only when the written in value is really bad. like -3.1 or worse, and a number of other conditions are met. the correlation between the 3 knock control modes is far too complex to say 'when x happens, y will always happen as a result'. you have to log it in real time and watch it take place. for instance logging kclv. if you only could log kclv you'd have no idea what timing was being pulled from flkc and what was being pulled from coarse correction, it'd just be a guess. you may be able to infer based on the incrementation, but that's not a good way to go about it. you could easily be misled into pulling timing across the board (if you didn't know better) when in reality it was just one small load/rpm cell that needed a bit of timing pulled. same thing goes for flkc. once it's there, if you just look at where it's being applied you don't know where to pull the timing from with any degree of certainty.
The Following User Says Thank You to jamesm For This Useful Post: | banane63 (02-10-2014) |
Similar Threads | ||||
Gas tank | laley81 | Issues | Warranty | Recalls / TSB | 1 | 07-31-2013 01:45 AM |
TANK Vs. FRS | chae | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 06-05-2013 04:23 PM |
The need of a oil catch tank... | davey90 | AUSTRALIA | 17 | 12-23-2012 05:01 AM |
gas tank lid | htdonato | Issues | Warranty | Recalls / TSB | 1 | 11-30-2012 02:43 AM |
How many miles per tank on E85 | Innova | Engine, Exhaust, Transmission | 2 | 09-21-2012 10:02 PM |
