Old 11-23-2013, 11:54 AM   #99
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Malt View Post
I'm also having issues. I logged on the way to work yesterday morning and when I got home this morning I attempted to open the log within openflash manager. I when I click on Read OpenFlash Manager just locks up.
Suggestions?
As jeebus said, make sure you are running openflash manager v1.03. Earlier versions won't work.
Old 11-23-2013, 11:55 AM   #100
Malt
Drives: 2015 WRX
Originally Posted by jeebus View Post
Was your tablet updated to the very latest version before you logged? Mine did the freeze up until the most recent update. Also, I assume you are on OpenFlash 1.3?
Pretty sure yes to the first one since I actually tested it for shiv and definitely yes to the question. I'm definitely running 1.03
Malt is offline   Reply With Quote
Old 11-23-2013, 11:58 AM   #101
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Ondreiko View Post
Hi Shiv!
Strange case with my OFT device - it is updated, new gauges appeared (but my lovely intake air temp scale disappeared), but Adv. Multiplier doesnot show anything. The gauge of Adv. Multiplier is present, but it's dead.
And it writes the log file, but there is no A.M. data available.
What went wrong there? How to fix? Should i fix OFT or car itself?
Will next OFT FW upgrade cure it?
This is the first time I've heard this. So you are saying that the other data is present in the logs but adv multiplier vulues are all zero? Or there is no adv multiplier column at all.
What rom type do you have?
Old 11-23-2013, 12:02 PM   #102
8686
8686's Avatar
Drives: 86
@shiv@vishnu
Hi shiv,
I sent you an email yesterday. I hope you will have time to look at it. also waiting for K series xdf file.
appreciate your continuos effort and awsome products.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 11-23-2013, 12:02 PM   #103
jeebus
Drives: 2015 Mustang GT (on order)
@shiv@vishnu -- what sort of engine loads are you seeing at WOT on e85?
jeebus is offline   Reply With Quote
Old 11-23-2013, 12:09 PM   #104
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by 8686 View Post
@shiv@vishnu
Hi shiv,
Thanks! Slowly getting caught up on emails. Hopefully will be done by the end of the weekend
Old 11-23-2013, 12:11 PM   #105
Shiv@Openflash
Drives: 2013 FRS
On a cold night I'll see as high as 1.25g/rev at around 5500-6000rpm. Maybe 1.15g/rev on a more temperate day.
Old 11-23-2013, 12:17 PM   #106
jeebus
ok great. I'm seeing around 1.15 on mine with the stock header at ~60 degrees. My intake is stock other than a K&N.
You have a modded snorkel, correct?
My logs are looking damn clean...I've done a number of them. You might be able to start recommending this map to non-header users.
Old 11-23-2013, 12:18 PM   #107
Shiv@Openflash
Drives: 2013 FRS
Yes, making it shorter and wider definitely helped.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
jeebus (11-23-2013)
Old 11-23-2013, 12:30 PM   #108
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Having G-series ROM.
The column Adv. Multiplier is present, but it doesnot work.
OFT doesnot read/show any activity in this column and doesnot write the data of A.M. to log file.
I have log file and datazap shows straight line on 0 level for Adv. Multiplier as well as your log veiwing application.
http://datazap.me/u/ondreiko/trial1-0?1-4-9
Ondreiko is offline   Reply With Quote
Old 11-23-2013, 12:36 PM   #109
Shiv@Openflash
Drives: 2013 FRS
Ok... I'll do some testing on Monday with your Euro ROM and see what I can find. Perhaps the rom needs a patch to be able to log advance multiplier.
akyp (11-23-2013)
Old 11-23-2013, 12:42 PM   #110
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
But is the stock scaling the same as this? If so, I don't see much issue with just leaving it.
Stock scaling in the actual rom is the raw throttle angle value, divided by 84. e.g. :
Code:
mov.l   #E_Target_Throttle_Plate_PositionExt_E57, r2
fmov.s  @R2, fr4
mov.w   @(h'12,r5), r0
mov     r0, r14
mov.w   @(h'14,r5), r0
mov     r0, r13
extu.w  r6, r0
shlr8   r0
mov.b   r0, @(0,gbr)
extu.w  r4, r0
shlr8   r0
mov.b   r0, @(h'30,gbr)
mova    flt_83214, r0
fmov.s  @r0, fr8
fdiv    fr8, fr4
ROM:00083214 flt_83214:      .float 84.0             ; DATA XREF: sub_82FD4+2Co
That's why you will see in some of the maps the 'max' value is 84% - which actually transalates to 100%. Other maps use converted throttle values (2 byte, or 1 byte) which do not use this conversion.
Either which way, it's only scaling - it will not change anything, unless you make the wrong assumptions based on it
Td-d is offline   Reply With Quote
The Following 3 Users Say Thank You to Td-d For This Useful Post:
jeebus (11-23-2013), Robert@Openflash (11-25-2013), Shiv@Openflash (11-23-2013)
Old 11-23-2013, 01:54 PM   #111
Ondreiko
RWD addicted
Ondreiko's Avatar
thank you
Old 11-25-2013, 12:35 PM   #112
Shiv@Openflash
Drives: 2013 FRS
New OFT update today:
-MAF Voltage data logging channel is now active and functional
-Throttle angle value has been rescaled (divided by 0.84) so full throttle should show 100% now. Thank you @Td-d
Only one currently known bug: if you cycle ignition power while in a data display screen, MAF v and Adv multiplier will stop logging (display 0) while the other channels will continue to log as normal. Not a big deal but will be fixed later this week. But if I didn't mention this some users may be worried to see their adv mult erroneously read 0 if they were to do this
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
