#99 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
I refer to this stuff as white gold. It's really nice stuff, just a pain to clean if you get it on car windows (I put just a dab along the window-track, keeps all operating surfaces happy). Works great on slider doors around the house too.
#100 |
Drives: '13 Scion fr-s
So I tried using some white lithium grease on the shaft as shown in the video. I noticed the shaft was very dry and it seemed like any grease that might have been there has been long gone.
I applied the grease, pressed in the clutch fully a few times to help spread more inside the rubber part, and let it sit overnight and tried driving this morning. I didn't notice any honking noise for 80% of the trip and was starting to think it worked. I tried different levels of aggressiveness with shifts, let the clutch slip a few times, and no noise. Then I tried downshifting from 3rd to 2nd moderately aggressively and got a nice honk sound. Problem not solved ![]() @Tcoat |
| The Following User Says Thank You to H_K For This Useful Post: | Tcoat (02-20-2020) |
#101 | |
OK step two. Clutch fork. A little more difficult but still not horrid. https://www.ft86club.com/forums/showthread.php?t=99578
#102 | |
![]() (not an fr-s I know, but the assembly is close enough) So if I don't need to drop the transmission, where would I need to grease up? I've already greased the shaft that connects to the fork. I can't think of where else I could add grease to that's reachable. Maybe only around the fork where the rubber is? I don't see how that could make the honking noise... Last edited by H_K; 02-20-2020 at 02:15 PM. |
#103 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | H_K (02-20-2020) |
#104 |
#105 | |
You have to get up inside the car and grease up the master cylinder rod. Top of picture.
#106 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I've heard a "honk" once in a while if I apply too much throttle with the clutch partially disengaged.
I always associated that with the pilot bearing fluttering a bit and try not to do that. Get the clutch engaged fully before romping on it is my solution. May be totally unhinged speculation. No promises. edit: listened to the harmonica tune on the first page. My noise was a couple octaves lower frequency than on the YouTube clip
"I gotta rock." -- Charley Brown |
#107 |
The one pictured is for the brake cylinder rod but I'm looking for the clutch one, correct? Should look similar from the inside I think. I'll tackle that at the same time.
#108 |
OOPS. I haven't been able to find a good picture of the clutch one. It is up in there.
#109 | |
I also greased up the cylinder inside the footwell as best I could. Wasn't too hard to find the right one by pushing the clutch pedal in. Took a drive this morning, and didn't hear any issues. Since this is an intermittent thing I'm not fully convinced it's good, so I'll continue to monitor it. |
| The Following User Says Thank You to H_K For This Useful Post: | Tcoat (02-21-2020) |
#110 | |
#111 |
After a week of more driving... Haven't heard the honking once.
Thank you for all the help @Tcoat . I guess it just needed some grease! Not sure if I can pinpoint exactly where of the three places I greased up really fixed it, but it seems to have solved the issue! So thankful I don't need to take to the dealership where they'd drop the transmission, spend a lot of time investigating, and cost me a lot of money. |
| The Following User Says Thank You to H_K For This Useful Post: | Tcoat (03-03-2020) |
#112 |
| The Following User Says Thank You to Tcoat For This Useful Post: | H_K (03-04-2020) |
| For the not faint of heart.. NX NOS!!! Kit | Sportsguy83 | Engine, Exhaust, Transmission | 84 | 03-01-2015 03:54 PM |
| South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway | RussellM | Northwest | 13 | 09-05-2013 10:57 AM |
| Faint Clutch Smell - 6,000 Miles | FnFast | Issues | Warranty | Recalls / TSB | 8 | 08-16-2013 05:17 PM |
| Amp no sound | asher187 | Electronics | Audio | NAV | Infotainment | 8 | 08-15-2013 07:03 PM |
| What should the FR-S sound like? | 1660 | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 07-31-2011 02:33 AM |
