Old 02-14-2020, 02:26 PM   #99
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
No. I used a lithium grease that I had kicking around. You don't need much just a thin coat (not like he put on).
I refer to this stuff as white gold. It's really nice stuff, just a pain to clean if you get it on car windows (I put just a dab along the window-track, keeps all operating surfaces happy). Works great on slider doors around the house too.
ROFL it's Waffle is offline   Reply With Quote
Old 02-20-2020, 09:39 AM   #100
H_K
Drives: '13 Scion fr-s
So I tried using some white lithium grease on the shaft as shown in the video. I noticed the shaft was very dry and it seemed like any grease that might have been there has been long gone.
I applied the grease, pressed in the clutch fully a few times to help spread more inside the rubber part, and let it sit overnight and tried driving this morning.
I didn't notice any honking noise for 80% of the trip and was starting to think it worked. I tried different levels of aggressiveness with shifts, let the clutch slip a few times, and no noise. Then I tried downshifting from 3rd to 2nd moderately aggressively and got a nice honk sound. Problem not solved
@Tcoat
H_K is offline   Reply With Quote
Old 02-20-2020, 09:59 AM   #101
@Tcoat
OK step two. Clutch fork. A little more difficult but still not horrid.
https://www.ft86club.com/forums/showthread.php?t=99578
Old 02-20-2020, 12:52 PM   #102
H_K
So for this part, I'm only adding the grease around the top of the clutch fork, right? I'm not going to need to drop the transmission and get access to the rest of the fork, will I? IF that's the case, I might as well take to the dealership because I don't have the equipment to drop the transmission.
(not an fr-s I know, but the assembly is close enough)
So if I don't need to drop the transmission, where would I need to grease up? I've already greased the shaft that connects to the fork. I can't think of where else I could add grease to that's reachable. Maybe only around the fork where the rubber is? I don't see how that could make the honking noise...
Old 02-20-2020, 01:23 PM   #103
Reach as far down as you can and smear it in. No disassembly required.
Old 02-20-2020, 01:37 PM   #104
H_K
I'll give it a try tonight then! Seems like it can be done solo. I'll let it sit again overnight and drive in the morning and report back
Old 02-20-2020, 01:43 PM   #105
There is one more thing you can do but it is tricky.
You have to get up inside the car and grease up the master cylinder rod.
Top of picture.
Old 02-20-2020, 01:59 PM   #106
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I've heard a "honk" once in a while if I apply too much throttle with the clutch partially disengaged.
I always associated that with the pilot bearing fluttering a bit and try not to do that.
Get the clutch engaged fully before romping on it is my solution.
May be totally unhinged speculation. No promises.
edit: listened to the harmonica tune on the first page.
My noise was a couple octaves lower frequency than on the YouTube clip
Old 02-20-2020, 01:59 PM   #107
H_K
Top of picture.
The one pictured is for the brake cylinder rod but I'm looking for the clutch one, correct? Should look similar from the inside I think. I'll tackle that at the same time.
Old 02-20-2020, 02:15 PM   #108
OOPS. I haven't been able to find a good picture of the clutch one. It is up in there.
Old 02-21-2020, 09:34 AM   #109
H_K
So I greased up the clutch fork as much as I could. Had a tough time getting past the rubber boot.
I also greased up the cylinder inside the footwell as best I could. Wasn't too hard to find the right one by pushing the clutch pedal in.
Took a drive this morning, and didn't hear any issues. Since this is an intermittent thing I'm not fully convinced it's good, so I'll continue to monitor it.
Old 02-21-2020, 10:03 AM   #110
Old 03-03-2020, 01:15 PM   #111
H_K
After a week of more driving... Haven't heard the honking once.
Thank you for all the help @Tcoat . I guess it just needed some grease! Not sure if I can pinpoint exactly where of the three places I greased up really fixed it, but it seems to have solved the issue!
So thankful I don't need to take to the dealership where they'd drop the transmission, spend a lot of time investigating, and cost me a lot of money.
Old 03-03-2020, 01:52 PM   #112
For the not faint of heart.. NX NOS!!! Kit Sportsguy83 Engine, Exhaust, Transmission 84 03-01-2015 02:54 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
Faint Clutch Smell - 6,000 Miles FnFast Issues | Warranty | Recalls / TSB 8 08-16-2013 04:17 PM
Amp no sound asher187 Electronics | Audio | NAV | Infotainment 8 08-15-2013 06:03 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
