Old 07-31-2012, 06:50 AM   #99
-max-
Drives: Firestorm FRS
(225) 931-2290. Chris Carver
He does corner balancing in BR.
-max- is offline   Reply With Quote
Old 07-31-2012, 09:17 AM   #100
Genomaxter
Drives: 2013 firestorm FRS
Well, I got my SSR wheels in and my Nameless downpipe.
Word of warning. The stock overpipe is a bitch to get off. You need a 10, 12, 14 socket & open end wrench and a very "colorful" use of the english language (also a dremmel in my case because the LAST nut was cross threaded from the factory.... lucky me!!!!!). Oh, and a full set of jack stands, a regular jack, and a bottle jack for lifting the engine up. You will know the meaning of rage when you try to get the overpipe between the engine and frame.
Genomaxter is offline   Reply With Quote
Old 07-31-2012, 02:35 PM   #101
Enigmus
Enigmus's Avatar
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
awesome! type c's? what tires? and crank pulley incoming?
Enigmus is offline   Reply With Quote
Old 07-31-2012, 05:22 PM   #102
Genomaxter
17x8.5 type c with 245/40 RS-3 all around. Already have a Perrin crank pulley installed.
Old 07-31-2012, 06:13 PM   #103
-max-
Notice a difference with the pulley?
Old 08-01-2012, 01:47 AM   #104
-max-
Mitch, are you flipping the springs front to rear on the KWs? They come with 400# rear and 350# front. Most people are flipping them around and still saying the rear is pretty loose. I flipped mine.
Old 08-01-2012, 12:19 PM   #105
Genomaxter
The engine does rev a bit faster, but I only notice it on throttle blips for downshifting.
Old 08-01-2012, 01:03 PM   #106
Mitch
form follows function
Drives: RIP '13 BRZ
I haven't decided. The last thing I want to do is induce understeer. Factory setup is stiffer in the back than the front. Kind of curious that even with them swapped the back end is loose. I'll do some more research and get back to you on that one. I take it you're planning on swapping?
Mitch is offline   Reply With Quote
Old 08-01-2012, 01:10 PM   #107
Derik210
That Army Guy
Derik210's Avatar
Drives: Firestorm FR-S MT
I'm in fort polk and i got one, but yesterday someone switched lanes and hit me so yeah I'm kinda pissed off right now >:-/
Derik210 is offline   Reply With Quote
Old 08-01-2012, 02:50 PM   #108
-max-
Yes, mine are swapped. Bill, the guy with the huge write up, has them flipped and went as far as disconnecting the rear sway bar and said it was still loose.
Im thinking tihs car is going to need a lot of rear camber. I mean it comes with about 0 front and .5 rear and is pretty neutral. Then people go to 2.5+ front and 1.7 rear and complain its loose. Time will tell I suppose.
Old 08-01-2012, 02:56 PM   #109
-max-
Thats effed up! How bad? Pics?
Old 08-01-2012, 04:03 PM   #110
Enigmus
Enigmus's Avatar
i can tell you on stock suspension it oversteering quite eagerly at the north track of nola motor. spun out twice but then again it was user error going fast on a track with no track experience. lol
Old 08-01-2012, 05:35 PM   #111
Derik210
That Army Guy
Derik210's Avatar
na no pics, it was pretty bad. when he switched lanes i guess it got hold of the bumper and ripped the drive side of the bumper off. I'm pretty sure the frame and subframe are messed up. words can't describe how fucking mad i am
Old 08-03-2012, 11:36 AM   #112
-max-
Just got the KWs on. About 2 1/4 hours by my self. EXACTLY the same as my 2011 WRX. The rear camber bolts will add some time to this, mine are not due in till Monday. You will need a set of hollow sockets and ratchet, and allen wrenches. Did not need spring compressors for the rear. Did not have to take apart the front as I used the Whiteline tops. Make sure you put the front endlink back on before you tighten the coilover. I did not and had to loosen them to get it in on one side.
Initial drop is 1 3/4" without adjusting anything. Went from 14 1/2" to 12 3/4" hub to fender. Still within specs, but I think I will raise quite a bit.
Miami-Dade, Broward, Palm Beach Counties Sportsguy83 Southeast 1150 07-11-2014 05:07 PM
South Coast Subaru and Irvine Subaru SPCorBUST Southern California 63 04-06-2012 10:43 AM
Are there any south Africans on this forum?? Didierm BRZ First-Gen (2012+) — General Topics 6 11-29-2011 01:39 AM
