View Poll Results: What would you like?
Halo Ring: Yes 228 47.70%
Halo Ring: No 213 44.56%
Top LED: to be used as a Day Time Running Strip. 250 52.30%
Top LED: to be used as a signal. 151 31.59%
LED to be used as a Day Time Running Strip. 178 37.24%
LED to be used as a signal. 92 19.25%
Use Top and Bottom LED as a Day time running light and cancel out signal. 71 14.85%
Lens: Chrome 73 15.27%
Lens: Flat Black 233 48.74%
Lens: Gloss Black 132 27.62%
Lens: Smoke housing 112 23.43%
Multiple Choice Poll. Voters: 478. You may not vote on this poll
Old 07-18-2013, 11:21 PM   #99
Luis_GT
Originally Posted by Trashed675 View Post
Am i just missing it, or are there no hi beams?
HID's normally have the high beams integrated... they are called bi-xenon
[ame]http://youtu.be/hrNiCVmn2ko[/ame]
Old 07-19-2013, 12:34 AM   #100
bear89103
Old Fart
bear89103's Avatar
There's a whole mess of varying opinions here. Looks like making a couple of versions is needed.
bear89103 is offline   Reply With Quote
Old 07-19-2013, 08:44 AM   #101
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Motor? The one time i did a hi low retro fit sorta like this, the projector has a little servo in it that basically just blocks off the top part of the light spread(when low beams are on) then when the high beams are on, the light block thing(for lack of a better term) moves so that you get the full power of the bulb. Somebody correct me if i'm wrong, but its really not an expensive setup.
Nigel has actual GT86 lights for $2300 for the pair, we all know genuine OEM parts are WAAAAY more expensive then they really should be. I'm drawing the line at $1000 for the set...fingers crossed
What exactly do you think a servo is?
$2300 a pair ummm take another look its 2700 a pair for what you actually NEED to run them correctly...lets take a look at the BRZ headlights that cost 673? a piece...with no ecu and such...still think $1000 is going to happen? Maybe with no bulbs or ballasts...everyone wants something for nothing. You get what you pay for in this game. Buy cheap stuff get cheap stuff, simple as that. If you find a deal that seems to good to be true more then likely it is because A its stolen B its crap. Their price point is going to be based on the market and the only competition are those two lights all they have to do is beat that price and make a quality product to get business.
Fett4Real is offline   Reply With Quote
The Following User Says Thank You to Fett4Real For This Useful Post:
turbos86 (07-21-2013)
Old 07-19-2013, 09:02 AM   #102
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Originally Posted by Fett4Real View Post
Your sadly mistaken...have you heard of DEPO lights or any aftermarket manufacturer of car parts at all?
I think they buy a license from the manufacturer to be able to sell OEM replacements. At least I think that is they way it goes. Now there are small companies making OEM style diffusers but I think they come from China where there is not such thing as intellectual property.
I am not 100% on that but I think that is the way it works. I may very well be wrong as I see knock off OEM spoilers on ebay but once again I think they come from China.
jadewbj is offline   Reply With Quote
The Following User Says Thank You to jadewbj For This Useful Post:
Fett4Real (07-19-2013)
Old 07-19-2013, 09:30 AM   #103
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
FRS owners seem to forget that us BRZ guys need turn signals in our headlamps, so please keep that in some capacity (whether on the unit or as an option).
Perihelion is offline   Reply With Quote
Old 07-19-2013, 11:40 AM   #104
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Thats a good point...wouldnt be terrible to have the DRL strip function as both a DRL and a turn signal...could always make the lower light a flasher only...or a DRL like the BRZ...
Old 07-19-2013, 12:25 PM   #105
jadewbj
jadewbj's Avatar
Why would a BRZ want to change their headlights, j/k. They at least get the same headlights as everyone else as opposed to us FR-S owners who got the crappy us version of the headlights.
Old 07-19-2013, 12:35 PM   #106
Perihelion
Perihelion's Avatar
True, getting these would be less of an upgrade for us, but an upgrade nonetheless. I was just chiming in, I don't plan on changing mine. Have plenty of other things to spend money on.
Old 07-19-2013, 12:54 PM   #107
jadewbj
jadewbj's Avatar
If a BRZ did change it the could sell the factory lights for more than then ones they bought lol. Are the HID ballast integrated into the BRZ headlights? If so not sure these would even work.
Old 07-19-2013, 01:08 PM   #108
Perihelion
Perihelion's Avatar
Not sure about the ballasts, too hot to go outside and check lol
Old 07-19-2013, 01:17 PM   #109
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
I just want a black housing is all
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 07-19-2013, 05:57 PM   #110
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
http://www.nigel-jdmparts.com/vehicl...head-light-rhd
Option #3 = $2320. You could spend $2700 with the leveling ecu, but this kit most likely won't come with those, so i didn't compare the two.
My point was the servo would cost almost nothing and is part of the projector.
I'm not trying to start an argument, i was just saying that it shouldn't cost as much as OEM GT86 or even close. Bi xenon projectors are $150/pair, LED's are extremely cheap now days, and they should be sold without bulbs/ballasts (or as an option). Yes I understand that making the housing is relatively expensive and R&D isn't cheap, but it shouldn't cost more then about $500(once the R&D is done) to make a pair of headlights like this.
Trashed675 is offline   Reply With Quote
Old 07-19-2013, 11:01 PM   #111
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Originally Posted by Enraged21 View Post
Closest to JDM/EDM Headlights and you got a buyer
X2
Cessblood is offline   Reply With Quote
Old 07-20-2013, 04:10 PM   #112
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
We cant do the JDM headlights because of copyrights.
Evasive Motorsports is offline   Reply With Quote
Age and Profession Survey Wix Scion FR-S / Toyota 86 GT86 General Forum 2472 06-19-2017 05:55 AM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
Another PNW Car meet? Vote on a date and vote on what to do! NickFRS Northwest 45 01-07-2013 07:23 PM
Scion Product Quality Survey & Maritz Survey Amadeus Scion FR-S / Toyota 86 GT86 General Forum 14 11-09-2012 12:51 PM
BRZ has AWD says survey gdi2290 BRZ First-Gen (2012+) — General Topics 15 10-04-2012 11:24 PM
