Old 03-04-2012, 06:18 PM   #99
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by Buggy51 View Post
I'm certainly not a mechanic, and at most I know how to do an oil change... but from what you guys can see, is there any places that might seem prone to structural problem? Or for the most part, it seems pretty solid in the long run?
Why do you mean?
tranzformer is offline   Reply With Quote
Old 03-04-2012, 06:34 PM   #100
OrbitalEllipses
Drives: Attitude
Originally Posted by Calum View Post
I'm talking about the two holes, one at 6 o'clock and one at 5 o'clock.
[\IMG]http://www.ft86club.com/forums/attachment.php?attachmentid=5165&stc=1&d=133065688 8[/IMG]
as for the rest of your post...
IIRC, I believe those are where you insert a tool to hold the pulley in one place while doing the timing/undoing the crank-bolt. Could be wrong, though.
Old 03-04-2012, 06:45 PM   #101
Calum
That Guy
Drives: 2013 asphalt FRS MT
I can't say you're wrong, but I haven't seen a pulley with an arrangement like that. I've seen plenty of pulleys with holes to inset a holding tool but the holes were always on opposite sides.
Old 03-04-2012, 06:53 PM   #102
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Nope, they're balancing hole. They drill out some metal on the damper to subtract weight at specific locations to balance it.
Old 03-04-2012, 07:06 PM   #103
Buggy51
Drives: Put Put
Originally Posted by tranzformer View Post
Why do you mean?
Hmmm more like are there any weak points that might be prone to being damaged/bent under normal driving conditions?
Buggy51 is offline   Reply With Quote
Old 03-04-2012, 07:18 PM   #104
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
Nothing should be damaged or bent under normal driving conditions.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 03-04-2012, 09:28 PM   #105
Buggy51
Drives: Put Put
Gotcha. And sorry for the question. Not an expert with mechanics of a car, so unsure if these modifications alluded to by some of the earlier posters might affect structural integrity.
Old 03-04-2012, 09:29 PM   #106
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
I thought you guys could use this, a vid of the engine close up;
[u2b]LXkhxnsX3-s[/u2b]
Old 03-04-2012, 09:51 PM   #107
serialk11r
Drives: '06 AM V8V Coupe
Battery says 55d23r, Google searching gives 60Ah ~525 CCA wet plate design. Must be hefty :O AGM batteries with half the capacity are over 20 pounds.
Old 03-04-2012, 10:21 PM   #108
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by serialk11r View Post
Must be hefty :O
The interweb suggests a weight of ~35.5lbs.
old greg is offline   Reply With Quote
Old 03-05-2012, 09:16 AM   #109
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Want to know a secret?
Want a lightweight battery you can palm in one hand? (if you don't have small hands )
Want to pay less than $40?
Don't laugh.
I use these in my WRX that I race in SCCA RallyCross. They weigh 17lbs, 23lbs LESS than what a full group 35 battery weighs. The U1R has about 270-300CCA which is enough for a small 4 cyl engine. I've even started the car in the winter with one of these. And the best part is that at less than $40 (even better when on sale) I can go through 3 of these for the price of a new full size.
Run the light L&G battery in the summer and put the stock one on a tender for the winter.
Old 03-06-2012, 01:25 PM   #110
Calum
That Guy
Don't laugh.
Why take it out for winter? Mine had no trouble starting the car every day for two years before I swapped it out for other reasons.
Old 03-06-2012, 01:36 PM   #111
Draco-REX
Corner Junkie
Draco-REX's Avatar
Depends on the area. As above, I got it to turn my WRX over in the middle of winter without a problem. But if it's an area with constant sub zero temps, a larger battery might not be a bad idea.
Though a battery warmer would solve that too. And if someone's in an area with temps like that, they might well have a battery and block warmer anyways.
But yeah, Braille doesn't want you to know about the L&G batteries.
Old 03-06-2012, 02:13 PM   #112
Calum
That Guy
Depends on the area. if it's an area with constant sub zero temps, a larger battery might not be a bad idea.
That's why I spoke up. Today is pretty warm for this time of year, it's -3 right now.
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
Subframe/Drivetrain Thoughts.... TrackDog Scion FR-S / Toyota 86 GT86 General Forum 12 11-10-2011 10:53 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
Drivetrain experts! Name this car! :) aspera Engine, Exhaust, Transmission 200 08-15-2010 11:41 PM
