Old 05-01-2013, 06:13 PM   #99
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by mad_sb View Post
did you use a boost leak tester? That is the coupler on the throttle body yes? That would be the source of your boost leak, or at least one of them in case there are multiple.
I would remove both clamps, re-seat the coupler and pipe, put the clamps back on. check for leak again, then drive it AFTER you verify that leak is fixed.
no boost leaker test but soapy water
i tight the clamp really good, spray more soapy water and no bubbles
Old 05-01-2013, 06:19 PM   #100
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Also, did you get your gauge sorted out so you can see both AFR and boost?
not yet about the gauge
Old 05-01-2013, 06:31 PM   #101
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Went to test it and still same shit
Old 05-01-2013, 06:36 PM   #102
mad_sb
Drives: 2013 Asphalt FR-S
OK, well, i don't understand how you pressurized the charge pipe without a tester but regardless. That was the most likely place to have a leak that would cause you to run rich (after the maf). You can take it for an easy drive and SLOWLY roll into boost. I would advise you get your gauge sorted first but it's your car and your call.
Old 05-01-2013, 07:06 PM   #103
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
When the car stops making power all of a sudden, does your AFR go to LEAN, or stay very rich?
Old 05-01-2013, 07:10 PM   #104
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
goes to 8 so rich
Old 05-01-2013, 07:24 PM   #105
Sportsguy83
Drives: Limited BRZ
goes to 8 so rich
One more sign its boost leak. Tow it with the friend back to the shop.You'll be glad later.
Old 05-01-2013, 07:47 PM   #106
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
where to check for leak?
Old 05-01-2013, 07:49 PM   #107
Sportsguy83
Drives: Limited BRZ
Every single clamped intake pipe connection. From the filter, to the compressor, to the intercooler and all the way to the throttle body.
start with all the connections that are between the MAF sensor and the throttle body.
Old 05-01-2013, 08:04 PM   #108
lexusb3
Drives: FRS
if you cant find the "boost leak" i say just tow it.. you will look back and be like im glad i did!! better safe than sorry 10K(rebuilt motor) < $700 (tow) IMO of course...and if you cant tow and rather drive like said before you can easily drive out of boost set your REV limit light under so it can remind you lol
lexusb3 is offline   Reply With Quote
Old 05-01-2013, 08:43 PM   #109
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
All the clamps that are in the engine bay are tight
The only ones i couldnt reach was the intercooler ones
Old 05-01-2013, 09:01 PM   #110
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Well take the bumper off and check it out, it takes no more then 10 minutes to do it
Silverdub is offline   Reply With Quote
The Following User Says Thank You to Silverdub For This Useful Post:
Sportsguy83 (05-02-2013)
Old 05-01-2013, 10:01 PM   #111
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Ok guys
Great news!!!!!!!
While i was waiting for my friend to help me do some data logging i took all the clamps off (not the intercooler ones) and put them back and tight them good.
When we were doing the data logging my car went in to boost fine
My AFR was around 10-10.5 and my psi was from 6.8 to 7.2
Now i feel that my car is working fine
Thanks very much to @brichard0625 for making this long trip and helping me out.
I think he brought me luck.
Thanks to all the people here who help me out too.
Just waiting on John to check my logs and go from there.
Now i need to figure out how to install windows on a mac
Old 05-01-2013, 10:45 PM   #112
DJCarbine
Thupercharged
DJCarbine's Avatar
Luck doesn't seal boost leaks, glad you got it sorted
The Following User Says Thank You to DJCarbine For This Useful Post:
ATL BRZ (05-02-2013)
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 01:36 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
